I saw this. The data filled by static void schema_fill_sample_sgie_vehicle_metadata (NvDsObjectMeta* obj_params, NvDsVehicleObject* obj) is dummy. I want the actual inference data. How can I get that?
Hi
Could you please tell you run with default test5 or your customized? if run with your customized, suggest you verify test5 first, option -m set to 1 to let analytic processing and metadata filled.
This option is to demonstrate the code which can read
PGIE, Tracker, and SGIE Metadata from NvDsBatchMeta and fill
NvDsEventMsgMeta in bbox_generated_probe_after_analytics()
for the nvmsgconv schema and JSON-metadata-generation.
For more details run the below command on terminal post DS installation:
gst-inspect-1.0 nvmsgconv
NOTE: Customers using -m 0 with custom PGIE, SGIE models,
please read the documentation under “IMPORTANT Note 1” tag
in deepstream_test5_app_main.c for changes in code required
to relay SGIE Classifier-Metadata to nvmsgconv
6.1 -m 0 (Model(s) used are unknown)
$ ./deepstream-test5-app -c test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt -m 0
