No signal from Intel Realsense camera D455 in Isaac sim
Hi everyone,
I am trying to create a D455 camera in my isaac sim environment by python code. But after I run my program, I cannot see the D455 camera model although I still can see the d455 Xform in my stage (as in the photo).
It also shows me the viewpoints from the realsense camera, but when I select one one of the viewpoints, it was just white view.
My code is as following. Please help me to solve the problem.
Thank you !
#launch Isaac Sim before any other imports
#default first two lines in any standalone application
from omni.isaac.kit import SimulationApp
simulation_app = SimulationApp({"headless": False}) # we can also run as headless.
from omni.isaac.core import World
from omni.isaac.core.objects import DynamicCuboid
from object_utils.object_utils import ObjectUtils
from omni.isaac.core.utils.nucleus import find_nucleus_server, get_assets_root_path
from omni.isaac.core.utils.stage import add_reference_to_stage
from pxr import Sdf, Usd, UsdGeom, Gf
import carb
import numpy as np
import carb
# D455_USD_PATH = "/home/huynn/huynn_ws/edge-server-project/isaac_sim_learning/cameras/rsd455/rsd455.usd"
class RobotJuggler:
    def __init__(self,):
        self.ou = ObjectUtils()
        kp=1.0
        ki=0.0
        kd=0.0
        self.ou.pid_controller.update_params(kp, ki, kd)
        self.goal_position = np.array([10.0, 5.0, 0.0])
        # Khởi tạo mô phỏng
        time_step = 1/60 # 1000 time faster then realtime
        self.world = World(physics_dt = time_step, rendering_dt = time_step)
        self.setup_scene()
        self.stop_sim = False
    def setup_scene(self,):
        # Thiết lập môi trường
        self.world.scene.add_default_ground_plane(
            z_position=0,
            name="fancy_ground_plane",
            prim_path="/World/fancy_ground_plane",
            static_friction=0.0,
            dynamic_friction=0.0,
            restitution=0.01,
        self.ou.add_dome_light("/fancy_dome_light", 1000.0, [1.0, 1.0, 1.0])
        self.fancy_cube_prim_path = "/World/fancy_cube"
        self.fancy_cube = self.ou.add_box(self.world, self.fancy_cube_prim_path,
                                          position=[0, 0, 0.05],
                                          scale=[0.1, 0.1, 0.1],
                                          color=[1.0, 0.0, 1.0])
        nucleus_server = get_assets_root_path()
        # if result is False:
        #     carb.log_error("Could not find nucleus server with /Isaac folder")
        print("nucleus_server: ", nucleus_server)
        d455_usd_path = nucleus_server + "/Isaac/Sensors/Intel/RealSense/rsd455.usd"
        d455:Usd.Prim = add_reference_to_stage(usd_path=d455_usd_path, prim_path="/World/d455")
        stage = self.world.stage
        d455 = stage.GetPrimAtPath("/World/d455")
        d455_xform = UsdGeom.Xform(d455)
        # Đặt vị trí (translation)
        translation = Gf.Vec3f(1, 0, 0.1)  # Giá trị dịch chuyển theo các trục x, y, z
        d455_xform.AddTranslateOp().Set(translation)
        # Đặt hướng (rotation)
        rotation = Gf.Vec3f(0, 0, 90)  # Giá trị xoay theo các trục x, y, z (đơn vị độ)
        d455_xform.AddRotateXYZOp().Set(rotation)
        print('-------------------------------------------- ', type(d455))
        # Reset thế giới để cập nhật các thay đổi
        self.world.reset()
        # Create an example timeline callback
        self.world.add_timeline_callback('template_timeline_callback', self.timeline_callback)
    def timeline_callback(self, timeline_event):
        """An example timeline callback. It will get invoked every time a timeline event occurs. In this example,
        we will check if the event is for a 'simulation stop'. If so, we will attempt to close the app
        Args:
            timeline_event: A timeline event
        if self.world.is_stopped():
            self.stop_sim = True
    def run_simulation(self,):
        Method that implements the application main loop, where the physics steps are executed.
        # print('----------------------------------------------------------------------------')
        # self.timeline.play()
        # Chạy mô phỏng
        # self.ou.apply_velocity(self.fancy_cube_prim_path, 1.0, 0, 3.0)
        while simulation_app.is_running() and not self.stop_sim:
            # self.ou.apply_velocity(self.fancy_cube_prim_path, 5.0, 0, 5.0)
            self.world.step(render=True)  # Bước mô phỏng vật lý và rendering
        carb.log_warn("Template Simulation App is closing.")
        # self.timeline.stop()
        simulation_app.close()
# Sử dụng class
if __name__ == "__main__":
    simulation = RobotJuggler()
    simulation.run_simulation()
@Huynn i tried to replicate in GUI but can’t seem to recreate the issue. i presume you are using 2023.1.1? and if you were to expand the reference in the stage panel, are you able to confirm the asset path is mapped properly and you are able to see the mesh prims inside of rsd455.usd?
Hi my friend,
I found the cause. I need to fix the position of the camera unless, when running the simulation, the camera keep falling down haha
