No SPI Device is listing under /dev/spi* - AGX Xavier 32 GB module with L4T32.7.2
kernel_tegra194-p2888-0001-p2822-0000.dts.txt (355.7 KB)
After running the command “sudo modprobe spidev” we were able to see the spidev under lsmod but there is no SPI Device listing under /dev/spi*
Below is the dmesg log ,lsmod log and dts file.
What could be the issue here?
Processing: dmesg_log.txt…
lsmod_log.txt (1.2 KB)
Hi vbhm,
Are you using the devkit or custom board for AGX Xavier?
Your dmesg file seems not uploaded successfully, please share it again.
Please share the result of the following command on your board.
$ cat /etc/nv_tegra_release
$ ls -l /dev/spi*
Here is the log detail:
nvidia@nvidia-desktop:~$ cat /etc/nv_tegra_release
R32 (release), REVISION: 7.2, GCID: 30192233, BOARD: t186ref, EABI: aarch64, DATE: Sun Apr 17 09:53:50 UTC 2022
nvidia@nvidia-desktop:~$ ls /dev/spidev*
ls: cannot access ‘/dev/spidev*’: No such file or directory
Please upload the dmesg again for further check.
