I think you should be able find it in the kernel sources.
The pinmux did not work (unless I put it in the wrong file), I get same pin register values for spi as I did before.
I added the header-40pin-pinmux to:
./nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi -
then rebuilt:
export CROSS_COMPILE=$HOME/nvidia/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
export CROSS_COMPILE=/home/asei/nvidia/l4t-gcc/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
export TEGRA_KERNEL_OUT=$HOME/nvidia/kernel_compiled
export LOCALVERSION=-tegra
cd ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/sources/kernel/kernel-4.9/
make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j2 -
move the files to correct place
cd ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/kernel
cp $TEGRA_KERNEL_OUT/arch/arm64/boot/Image Image
cd dtb
cp -a $TEGRA_KERNEL_OUT/arch/arm64/boot/dts/. . -
Change to flash directory
cd ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra -
Flash command
sudo ./flash.sh -r -k kernel-dtb jetson-xavier-nx-devkit-emmc mmcblk0p1 -
I also tried
sudo ./flash.sh -r jetson-xavier-nx-devkit-emmc mmcblk0p1
You can check if the dtb was applied by dmesg | grep -i kernel
Also confirm the context was add to dtb by using dtc to un-compile it to dts to confirm it.
There was no change in the inctrl_reg
The dtb file was loaded:
dmesg_grep_kernel.txt (1.6 KB)
here is the dts from the dtb., based on the pinctrl you gave me.
kernel_tegra194-p3668-all-p3509-0000.dts (256.3 KB)
Note:
If I use the jetson_io.py tool the pinctrl_reg look good.
There are differences in the dts files, but both have the pins defined but use different but similar names for the 40pin hdr.
kernel_tegra194-p3668-all-p3509-0000-user-custom.dts (254.4 KB)
Well, you can check the un-compile the dtb file to dts that generate by jetson-io to check if any different to clarify the problem.
Here is a dts generated by Jetson_io:
Here is the one using your 40 pin hdr:
There are differnces in how the hdr is referenced, also a symbol is defined in the custom that is not in the other.
I copied the generated (custom) 40pin hdr into my spi dtsi file, It did not work either.
I will get that dto off the target and generate a dts and a custom dts.
When i use jetson_io I get the correct pinctrl_reg values.
Here is the DTS where I copied header-pinmux into my DTSI file then built the kernel.
kernel_tegra194-p3668-all-p3509-0000.dts (254.3 KB)
Here is the DTS using jetson_io:
Here are the two DTSI files I have changed for SPI.
tegra194-soc-base.dtsi (70.0 KB)
tegra194-soc-spi.dtsi (4.0 KB)
ShaneCCC Is there any information on why the SPI does not work when I add it via the tegra194-soc-spi.dtsi file?
I would suggest to configure it by jetson-io then extract it by “sudo dtc -I fs -O dts -o extracted_proc.dts /proc/device-tree” and add customized context to the extracted_proc.dts and compile it to dtb by dtc
That really does not fix the problem of not generating a working DTB from the SPI DTSI file, just goes around it.
I didn’t figure out the root cause now.
Please modify below cfg file to correct value and reflash the device by sudo ./flash.sh -r jetson-xavier-nx-devkit-xxx mmcblk0p1 to verify it.
../JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/Linux_for_Tegra/bootloader$ find -name tegra19x-mb1-pinmux-p3668-a01.cfg
