No streaming output IMX477 through FPD Link ds90ub95x
Hello ALL,
We are tweaking the driver ds90ub95x FPD Link for NVIDIA Jetson NANO.
Linux R32.7.4
Original source GitHub - InES-HPMM/FPD-LinkIII_ds90ub95x: FDP Link III driver for ds90ub954/ds90ub953
Sensor imx477
Deser ds90ub954 connected to the channel MIPI-2 via 2 lanes.
In looking at the logs below, the IMX477 can be initiated via I2C and ser ds90ub953
Our DTS
DTS
#include <dt-bindings/media/camera.h>
#include <dt-bindings/platform/t210/t210.h>
#include <dt-bindings/gpio/gpio.h>
#define CAM1_PWDN TEGRA_GPIO(S,7)
#define CAM2_PWDN TEGRA_GPIO(T,0)
#define CAM3_PWDN_GPIO TEGRA_GPIO(V,0)
#define CAM4_PWDN TEGRA_GPIO(H,6)
#define CAMERA_I2C_MUX_BUS(x) (0x1E + x)
host1x {
gpio@6000d000 {
camera-control-output-low {
gpio-hog;
output-low;
// gpios = <CAM1_PWDN 0 CAM2_PWDN 0>;
gpios = < TEGRA_GPIO(S,7) 0 TEGRA_GPIO(T,0) 0>;
label = "cam1-pwdn", "cam2-pwdn";
//vi_base: vi {
vi{
status = "okay";
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0{
status = "okay";
reg = <0>;
ds_imx477_vi_in0: endpoint {
status = "okay";
// IMX477
port-index = <4>; // MIPI0 -> CSI-A-B
bus-width = <2>; // Use CSI-A and CSI-B
remote-endpoint = <&ds_imx477_csi_out0>;
};//end ports
};//end vi
nvcsi{
status = "okay";
num-channels = <1>;
#size-cells = <0>;
channel@0 {
status = "okay";
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
status = "okay";
reg = <0>;
ds_imx477_i2c_csi_in0: endpoint@0 {
status = "okay";
port-index = <4>; // MIPI4 -> CSI-C
bus-width = <2>; // Use CSI-C and CSI-D
remote-endpoint = <&imx477_i2c_out0>;
port@1 {
status = "okay";
reg = <1>;
ds_imx477_csi_out0: endpoint@1 {
status = "okay";
remote-endpoint = <&ds_imx477_vi_in0>;
};//end chanel@0
};//end nvcsi
};//end host1x
i2c@7000c500 {
fpdlink: ds90ub954@30 {
status = "okay";
compatible = "ti,ds90ub954";
reg = <0x30>;
csi-lane-count = <0x02>;
csi-lane-speed = <1600>;
continuous-clock;
//test-pattern;
pdb-gpio = <&gpio TEGRA_GPIO(E, 0) 0>;
pass-gpio = <&gpio TEGRA_GPIO(S, 7) 0>;
lock-gpio = <&gpio TEGRA_GPIO(T, 0) 0>;
i2c_address_s0: num-alias-pairs0 {list-cells = <1>;};
serializers {
status = "okay";
num-channels = <0x01>;
#size-cells = <0>;
serializer@0 {
status = "okay";
rx-channel=<0x00>;
i2c-address=<0x18>;
continuous-clock;
//i2c-pass-through-all;
virtual-channel-map = <0x0>;
// test-pattern;
gpio0-output-enable = <1>;
gpio0-control = <0x9>;
i2c-slave = <&i2c_address_s0 0x1a>;// 0x11>;
slave-alias = <&i2c_address_s0 0x1a>;// 0x21>;
imx477_a@1a {
status = "okay";
compatible = "ridgerun,imx477";
// compatible = "nvidia,imx477";
// I2C device address
reg = <0x1a>;
// V4L2 device node location
devnode = "video0";
// Physical dimensions of sensor
physical_w = "3.680";
physical_h = "2.760";
sensor_model = "imx477";
use_sensor_mode_id = "true";
// reset-gpios = <&gpio CAM1_PWDN GPIO_ACTIVE_HIGH>;
reset-gpios = <&gpio CAM4_PWDN GPIO_ACTIVE_HIGH>;
clocks = <&tegra_car TEGRA210_CLK_CLK_OUT_3>;
clock-names = "clk_out_3";
clock-frequency = <24000000>;
mclk = "clk_out_3";
mode0 { /* IMX477_MODE_3264x2464_21FPS */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
dynamic_pixel_bit_depth = "10";
csi_pixel_bit_depth = "10";
mode_type = "bayer";
pixel_phase = "rggb";
active_w = "4056";
active_h = "3040";
pixel_t = "bayer_rggb";
readout_orientation = "90";
line_length = "13048";
serdes_pix_clk_hz = "924768000";//"160000000";
inherent_gain = "1";
mclk_multiplier = "200";
pix_clk_hz = "840000000";
gain_factor = "10";
min_gain_val = "10"; /* 1.00x */
max_gain_val = "3510"; /* 10.66x */
step_gain_val = "1";
default_gain = "10"; /* 1.00x */
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "1500000"; /* 1.5 fps */
max_framerate = "15000000"; /* 15 fps */
step_framerate = "1";
default_framerate = "15000000"; /* 15.0 fps */
exposure_factor = "1000000";
min_exp_time = "16"; /* us */
max_exp_time = "710227"; /* us */
step_exp_time = "1";
default_exp_time = "710227"; /* us */
embedded_metadata_height = "2";
mode1 { /* IMX477_MODE_1920X1080 */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
line_length = "9024";
serdes_pix_clk_hz = "4200000000";
gain_factor = "10";
max_gain_val = "3510"; /* 17x */
min_framerate = "3000000"; /* 2.0 fps */
max_framerate = "60000000"; /* 60.0 fps */
default_framerate = "60000000"; /* 60.0 fps */
min_exp_time = "6"; /* us */
max_exp_time = "16667"; /* us */
default_exp_time = "16667"; /* us */
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
imx477_i2c_out0: endpoint {
port-index = <4>;
bus-width = <2>;
remote-endpoint = <&ds_imx477_i2c_csi_in0>;
tegra-camera-platform {
//compatible = "nvidia,tegra-camera-platform";
compatible = "nvidia, tegra-camera-platform";
// status = "okay";
num_csi_lanes = <2>; // Changed 2 -> 4
max_lane_speed = <4500000>;//<1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <240000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. rear or front.
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
status = "okay";
badge = "porg_bottomleft_RBPCV2";
position = "bottomleft";
orientation = "1";
drivernode0 {
status = "okay";
pcl_id = "v4l2_sensor";
devname = "imx477 2-001a";
proc-device-tree = "/proc/device-tree/i2c@7000c500/imx477_a@1a";
Command:
~$ v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0,sensor_mode=1 --stream-mmap —stream-count=100
Output:
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 60.39 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 60.19 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 60.13 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 60.09 fps
After that we try to run capturing, both options below failed.
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM), width=(int)1920,height=(int)1080,framerate=60/1' ! nvvidconv flip-method=0 ! 'video/x-raw, format=(string)I420' ! xvimagesink -e —verbose
gst-launch-1.0 nvarguscamerasrc sensor-id=0 wbmode=0 aelock=true awblock=true ! nvvidconv ! queue ! xvimagesink sync=false
OUTPUT:
~$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 wbmode=0 aelock=true awblock=true ! nvvidconv ! queue ! xvimagesink sync=false
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 4056 x 3040 FR = 15,000000 fps Duration = 66666668 ; Analog Gain range min 1,000000, max 351,000000; Exposure Range min 16000, max 710227000;
GST_ARGUS: 1920 x 1080 FR = 59,999999 fps Duration = 16666667 ; Analog Gain range min 1,000000, max 351,000000; Exposure Range min 6000, max 16667000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 1
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 59,999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
CONSUMER: ERROR OCCURRED
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: CANCELLED
Additional debug info:
Argus Error Status
Execution ended after 0:00:03.037527603
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
dmesg log
dmesg log
[ 46.542452] imx477 2-001a: imx477_open:
[ 47.219178] imx477 2-001a: imx477_power_on: power on
[ 47.524788] imx477 2-001a: imx477_set_mode:
[ 47.815209] imx477 2-001a: → imx477_set_mode:
[ 47.819966] imx477 2-001a: imx477_start_streaming:
[ 47.829396] imx477 2-001a: imx477_stop_streaming:
[ 47.834809] imx477 2-001a: imx477_power_off: power off
[ 48.043739] imx477 2-001a: imx477_power_on: power on
[ 48.350635] imx477 2-001a: imx477_set_mode:
[ 48.648634] imx477 2-001a: → imx477_set_mode:
[ 48.653362] imx477 2-001a: imx477_set_gain: Setting gain control to: 19
[ 48.662673] imx477 2-001a: imx477_set_gain: val: 19 (/10) [times], gain: 486
[ 48.672786] imx477 2-001a: imx477_set_exposure: Setting exposure control to: 16666
[ 48.680754] imx477 2-001a: imx477_set_exposure: val: 16666 [us], coarse_time: 1551 [lines]
[ 48.690612] imx477 2-001a: imx477_set_frame_rate: Setting framerate control to: 30000001
[ 48.698777] imx477 2-001a: imx477_set_frame_rate: val: 30000001e-6 [fps], frame_length: 3102 [lines]
[ 48.709347] imx477 2-001a: imx477_start_streaming:
[ 48.720532] imx477 2-001a: imx477_set_group_hold: Setting group hold control to: 1
[ 48.729133] imx477 2-001a: imx477_set_frame_rate: Setting framerate control to: 60000000
[ 48.737726] imx477 2-001a: imx477_set_frame_rate: val: 60000000e-6 [fps], frame_length: 1551 [lines]
[ 48.748153] imx477 2-001a: imx477_set_gain: Setting gain control to: 18
[ 48.755003] imx477 2-001a: imx477_set_gain: val: 18 (/10) [times], gain: 456
[ 48.763333] imx477 2-001a: imx477_set_group_hold: Setting group hold control to: 0
[ 48.788626] imx477 2-001a: imx477_set_group_hold: Setting group hold control to: 1
[ 48.797044] imx477 2-001a: imx477_set_frame_rate: Setting framerate control to: 30000001
[ 48.805670] imx477 2-001a: imx477_set_frame_rate: val: 30000001e-6 [fps], frame_length: 3102 [lines]
[ 48.816230] imx477 2-001a: imx477_set_gain: Setting gain control to: 19
[ 48.823159] imx477 2-001a: imx477_set_gain: val: 19 (/10) [times], gain: 486
[ 48.832052] imx477 2-001a: imx477_set_group_hold: Setting group hold control to: 0
[ 49.967503] usb 1-3.4: usb_suspend_both: status 0
[ 50.235290] fence timeout on [ffffffc0992aba80] after 1500ms
[ 50.235332] name=[nvhost_sync:14], current value=0 waiting value=1
[ 50.235364] ---- mlocks ----
[ 50.235429] fence timeout on [ffffffc0992abc00] after 1500ms
[ 50.235445] ---- syncpts ----
[ 50.235461] name=[nvhost_sync:13], current value=0 waiting value=1
[ 50.235484] ---- mlocks ----
[ 50.235503] id 1 (disp0_a) min 354 max 354 refs 1 (previous client : )
[ 50.235535] id 2 (disp0_b) min 1 max 1 refs 1 (previous client : )
[ 50.235550] ---- syncpts ----
[ 50.235559] id 3 (disp0_c) min 1 max 1 refs 1 (previous client : )
[ 50.235597] id 8 (gm20b_507) min 19192 max 19192 refs 1 (previous client : )
[ 50.235630] id 9 (gm20b_506) min 14 max 14 refs 1 (previous client : )
[ 50.235668] id 11 (gm20b_505) min 1820 max 1820 refs 1 (previous client : gm20b_505)
[ 50.235706] id 13 (54600000.isp_0) min 0 max 3 refs 4 (previous client : )
[ 50.235741] id 14 (54600000.isp_1) min 0 max 3 refs 4 (previous client : )
[ 50.235779] id 15 (54600000.isp_2) min 7 max 15 refs 10 (previous client : )
[ 50.235817] id 16 (54600000.isp_3) min 0 max 3 refs 4 (previous client : )
[ 50.235868] id 21 (gm20b_504) min 704 max 704 refs 1 (previous client : )
[ 50.235908] id 22 (gm20b_503) min 58 max 58 refs 1 (previous client : )
[ 50.235947] id 23 (gm20b_502) min 2 max 2 refs 1 (previous client : )
[ 50.235986] id 24 (gm20b_501) min 2 max 2 refs 1 (previous client : )
[ 50.236025] id 25 (gm20b_500) min 6 max 6 refs 1 (previous client : )
[ 50.236066] id 26 (vblank0) min 2921 max -2 refs 1 (previous client : )
[ 50.236114] id 29 (54080000.vi_0) min 0 max 3 refs 4 (previous client : 54080000.vi_0)
[ 50.236159] id 31 (54080000.vi_2) min 2 max 7 refs 7 (previous client : 54080000.vi_2)
[ 50.236210] id 34 (54080000.vi_4) min 0 max 3 refs 4 (previous client : 54080000.vi_4)
[ 50.236257] id 37 (gm20b_499) min 8 max 8 refs 1 (previous client : )
[ 50.236297] id 38 (gm20b_498) min 6 max 6 refs 1 (previous client : )
[ 50.236338] id 39 (gm20b_497) min 6 max 6 refs 1 (previous client : )
[ 50.236379] id 40 (gm20b_496) min 6 max 6 refs 1 (previous client : )
[ 50.236420] id 41 (gm20b_495) min 6 max 6 refs 1 (previous client : )
[ 50.236461] id 42 (gm20b_494) min 6 max 6 refs 1 (previous client : )
[ 50.236950] ---- channels ----
[ 50.236968] id 1 (disp0_a) min 354 max 354 refs 1 (previous client : )
[ 50.237003] id 2 (disp0_b) min 1 max 1 refs 1 (previous client : )
[ 50.237027]
channel 0 - 54600000.isp
[ 50.237045] id 3 (disp0_c) min 1 max 1 refs 1 (previous client : )
[ 50.237084] 0-54600000.isp (18):
[ 50.237110] id 8 (gm20b_507) min 19192 max 19192 refs 1 (previous client : )
[ 50.237146] active class 01, offset 0050, val 0000000d
[ 50.237157] id 9 (gm20b_506) min 14 max 14 refs 1 (previous client : )
[ 50.237192] DMAPUT 000001b0, DMAGET 00000128, DMACTL 00000000
[ 50.237203] id 11 (gm20b_505) min 1820 max 1820 refs 1 (previous client : gm20b_505)
[ 50.237234] CBREAD 0000000d, CBSTAT 00010050
[ 50.237242] id 13 (54600000.isp_0) min 0 max 3 refs 4 (previous client : )
[ 50.237276] id 14 (54600000.isp_1) min 0 max 3 refs 4 (previous client : )
[ 50.237305]
00000000ad7a18a7: JOB, syncpt_id=13, syncpt_val=1, first_get=000000a8, timeout=10000, num_slots=3, num_handles=1
[ 50.237321] id 15 (54600000.isp_2) min 7 max 15 refs 10 (previous client : )
[ 50.237356] id 16 (54600000.isp_3) min 0 max 3 refs 4 (previous client : )
[ 50.237398] GATHER at ffc98000+4c54, 8 words
[ 50.237415] id 21 (gm20b_504) min 704 max 704 refs 1 (previous client : )
[ 50.237450] 20000001
[ 50.237453] id 22 (gm20b_503) min 58 max 58 refs 1 (previous client : )
[ 50.237488] 0000040d
[ 50.237490] id 23 (gm20b_502) min 2 max 2 refs 1 (previous client : )
[ 50.237522] 20000001
[ 50.237524] id 24 (gm20b_501) min 2 max 2 refs 1 (previous client : )
[ 50.237555] 0000050e
[ 50.237557] id 25 (gm20b_500) min 6 max 6 refs 1 (previous client : )
[ 50.237591] 20000001
[ 50.237593] id 26 (vblank0) min 2922 max -2 refs 1 (previous client : )
[ 50.237615] 00000610
[ 50.237636] id 29 (54080000.vi_0) min 0 max 3 refs 4 (previous client : 54080000.vi_0)
[ 50.237655] 200c0001
[ 50.237685] 00000005
[ 50.237695] id 31 (54080000.vi_2) min 2 max 7 refs 7 (previous client : 54080000.vi_2)
[ 50.237738] id 34 (54080000.vi_4) min 0 max 3 refs 4 (previous client : 54080000.vi_4)
[ 50.237778] GATHER at ffc98000+4c74, 2 words
[ 50.237787] id 37 (gm20b_499) min 8 max 8 refs 1 (previous client : )
[ 50.237820] 20000001
[ 50.237822] id 38 (gm20b_498) min 6 max 6 refs 1 (previous client : )
[ 50.237854] 0000000f
[ 50.237856] id 39 (gm20b_497) min 6 max 6 refs 1 (previous client : )
[ 50.237889] id 40 (gm20b_496) min 6 max 6 refs 1 (previous client : )
[ 50.237921] id 41 (gm20b_495) min 6 max 6 refs 1 (previous client : )
[ 50.237953] id 42 (gm20b_494) min 6 max 6 refs 1 (previous client : )
[ 50.237968]
channel 1 - 54080000.vi
[ 50.238003] 1-54080000.vi (13):
[ 50.238043] active class 01, offset 0050, val 0000001d
[ 50.238080] DMAPUT 000000e8, DMAGET 000000e8, DMACTL 00000000
[ 50.238111] CBREAD 0000001d, CBSTAT 00010050
[ 50.238170]
0000000045cbc076: JOB, syncpt_id=29, syncpt_val=1, first_get=00000000, timeout=10000, num_slots=7, num_handles=1
[ 50.238230] GATHER at ffc88000+0000, 35 words
[ 50.238257] 10620001
[ 50.238286] 0000001f
[ 50.238312] 10630002
[ 50.238339] 00000000
[ 50.238364] 00000000
[ 50.238391] 103a0001
[ 50.238416] 10100010
[ 50.238452] 103c0001
[ 50.238472] ---- channels ----
[ 50.238490] 10101010
[ 50.238512] unable to lock channel list
[ 50.238521] 10420001
[ 50.238548] 00000001
[ 50.238550] unable to lock channel list
[ 50.238570] unable to lock channel list
[ 50.238577] 10430006
[ 50.238597] 00000000
[ 50.238606] unable to lock channel list
[ 50.238626] unable to lock channel list
[ 50.238631] 001c984c
[ 50.238649] 00000000
[ 50.238656] unable to lock channel list
[ 50.238674] unable to lock channel list
[ 50.238680] 00000000
[ 50.238698] 00000000
[ 50.238706] unable to lock channel list
[ 50.238724] unable to lock channel list
[ 50.238728] 00000000
[ 50.238746] 10590001
[ 50.238755]
---- host general irq ----
[ 50.238786] 00000003
[ 50.238789] sync_hintmask_ext = 0xc0000000
[ 50.238813] sync_hintmask = 0x80000000
[ 50.238820] 120e0006
[ 50.238840] 007f0015
[ 50.238853] sync_intc0mask = 0x00000001
[ 50.238875] sync_intmask = 0x00000011
[ 50.239354] 080301f0
[ 50.239432] 00000000
[ 50.239484] 00140000
[ 50.239507] 0000f005
[ 50.239518] 00000000
[ 50.239529] 12420001
[ 50.239539] 00000001
[ 50.239549] 124b0003
[ 50.239558] 00000000
[ 50.239568] 00000000
[ 50.239577] 00000040
[ 50.239587] 128b0001
[ 50.239596] 00000000
[ 50.239616] GATHER at ffc88000+008c, 3 words
[ 50.239625] 304e0005
[ 50.239634] 00000007
[ 50.239643] 0000000f
[ 50.239662] GATHER at ffc88000+0098, 17 words
[ 50.239679] 10430006
[ 50.239688] 00200002
[ 50.239696] 001c984c
[ 50.239705] 00000000
[ 50.239713] 04380780
[ 50.239725] 00000960
[ 50.239733] 0000002b
[ 50.239747] 124b0003
[ 50.239755] 00000000
[ 50.239764] 00000000
[ 50.239772] 00000046
[ 50.239781] 20000001
[ 50.239789] 00001c1d
[ 50.239798] 20000001
[ 50.239806] 00000522
[ 50.239815] 20410001
[ 50.239823] 00000001
[ 50.239841] GATHER at ffc88000+00dc, 2 words
[ 50.239850] 20000001
[ 50.239860] 0000001f
[ 50.239893]
[ 50.239905] sync_hintmask_ext = 0xc0000000
[ 50.239914] sync_hintmask = 0x80000000
[ 50.239923] sync_intc0mask = 0x00000001
[ 50.239933] sync_intmask = 0x00000011
[ 50.239942]
---- host syncpt irq mask ----
[ 50.239952] syncpt_thresh_int_mask(0) = 0x54000001
[ 50.239962] syncpt_thresh_int_mask(1) = 0x44000001
[ 50.239972] syncpt_thresh_int_mask(2) = 0x00000010
[ 50.239982] syncpt_thresh_int_mask(3) = 0x00000000
[ 50.239992] syncpt_thresh_int_mask(4) = 0x00000000
[ 50.240002] syncpt_thresh_int_mask(5) = 0x00000000
[ 50.240012] syncpt_thresh_int_mask(6) = 0x00000000
[ 50.240022] syncpt_thresh_int_mask(7) = 0x00000000
[ 50.240033] syncpt_thresh_int_mask(8) = 0x00000000
[ 50.240043] syncpt_thresh_int_mask(9) = 0x00000000
[ 50.240054] syncpt_thresh_int_mask(10) = 0x00000000
[ 50.240071] syncpt_thresh_int_mask(11) = 0x00000000
[ 50.240087]
---- host syncpt irq status ----
[ 50.240098] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 50.240116] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 50.240127] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 50.240138] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 50.240149] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 50.240160] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 50.240171]
---- host syncpt thresh ----
[ 50.240182] syncpt_int_thresh_thresh_0(0) = 1
[ 50.240205] syncpt_int_thresh_thresh_0(13) = 1
[ 50.240217] syncpt_int_thresh_thresh_0(14) = 1
[ 50.240229] syncpt_int_thresh_thresh_0(15) = 8
[ 50.240241] syncpt_int_thresh_thresh_0(16) = 1
[ 50.240263] syncpt_int_thresh_thresh_0(29) = 1
[ 50.240275] syncpt_int_thresh_thresh_0(31) = 3
[ 50.240285] syncpt_int_thresh_thresh_0(34) = 1
[ 50.240655]
[ 50.240673] syncpt_thresh_int_mask(0) = 0x54000001
[ 50.240686] syncpt_thresh_int_mask(1) = 0x44000001
[ 50.240697] syncpt_thresh_int_mask(2) = 0x00000010
[ 50.240707] syncpt_thresh_int_mask(3) = 0x00000000
[ 50.240718] syncpt_thresh_int_mask(4) = 0x00000000
[ 50.240728] syncpt_thresh_int_mask(5) = 0x00000000
[ 50.240739] syncpt_thresh_int_mask(6) = 0x00000000
[ 50.240749] syncpt_thresh_int_mask(7) = 0x00000000
[ 50.240759] syncpt_thresh_int_mask(8) = 0x00000000
[ 50.240770] syncpt_thresh_int_mask(9) = 0x00000000
[ 50.240782] syncpt_thresh_int_mask(10) = 0x00000000
[ 50.240793] syncpt_thresh_int_mask(11) = 0x00000000
[ 50.240802]
[ 50.240815] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 50.240824] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 50.240832] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 50.240840] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 50.240847] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 50.240855] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 50.240860]
[ 50.240869] syncpt_int_thresh_thresh_0(0) = 1
[ 50.240885] syncpt_int_thresh_thresh_0(13) = 1
[ 50.240893] syncpt_int_thresh_thresh_0(14) = 1
[ 50.240901] syncpt_int_thresh_thresh_0(15) = 8
[ 50.240908] syncpt_int_thresh_thresh_0(16) = 1
[ 50.240924] syncpt_int_thresh_thresh_0(29) = 1
[ 50.240932] syncpt_int_thresh_thresh_0(31) = 3
[ 50.240941] syncpt_int_thresh_thresh_0(34) = 1
[ 50.298972] fence timeout on [ffffffc094e1b0c0] after 1500ms
[ 50.298980] name=[nvhost_sync:34], current value=0 waiting value=1
[ 50.298985] ---- mlocks ----
[ 50.298997] ---- syncpts ----
[ 50.299004] id 1 (disp0_a) min 354 max 355 refs 1 (previous client : )
[ 50.299009] id 2 (disp0_b) min 1 max 1 refs 1 (previous client : )
[ 50.299013] id 3 (disp0_c) min 1 max 1 refs 1 (previous client : )
[ 50.299019] id 8 (gm20b_507) min 19224 max 19224 refs 1 (previous client : )
[ 50.299024] id 9 (gm20b_506) min 14 max 14 refs 1 (previous client : )
[ 50.299029] id 11 (gm20b_505) min 1822 max 1824 refs 1 (previous client : gm20b_505)
[ 50.299034] id 13 (54600000.isp_0) min 0 max 3 refs 4 (previous client : )
[ 50.299038] id 14 (54600000.isp_1) min 0 max 3 refs 4 (previous client : )
[ 50.299043] id 15 (54600000.isp_2) min 7 max 15 refs 10 (previous client : )
[ 50.299047] id 16 (54600000.isp_3) min 0 max 3 refs 4 (previous client : )
[ 50.299054] id 21 (gm20b_504) min 704 max 704 refs 1 (previous client : )
[ 50.299058] id 22 (gm20b_503) min 58 max 58 refs 1 (previous client : )
[ 50.299062] id 23 (gm20b_502) min 2 max 2 refs 1 (previous client : )
[ 50.299067] id 24 (gm20b_501) min 2 max 2 refs 1 (previous client : )
[ 50.299071] id 25 (gm20b_500) min 6 max 6 refs 1 (previous client : )
[ 50.299075] id 26 (vblank0) min 2925 max -2 refs 1 (previous client : )
[ 50.299080] id 29 (54080000.vi_0) min 0 max 3 refs 4 (previous client : 54080000.vi_0)
[ 50.299085] id 31 (54080000.vi_2) min 2 max 7 refs 7 (previous client : 54080000.vi_2)
[ 50.299090] id 34 (54080000.vi_4) min 0 max 3 refs 4 (previous client : 54080000.vi_4)
[ 50.299095] id 37 (gm20b_499) min 8 max 8 refs 1 (previous client : )
[ 50.299099] id 38 (gm20b_498) min 6 max 6 refs 1 (previous client : )
[ 50.299103] id 39 (gm20b_497) min 6 max 6 refs 1 (previous client : )
[ 50.299106] id 40 (gm20b_496) min 6 max 6 refs 1 (previous client : )
[ 50.299110] id 41 (gm20b_495) min 6 max 6 refs 1 (previous client : )
[ 50.299114] id 42 (gm20b_494) min 6 max 6 refs 1 (previous client : )
[ 50.299206] ---- channels ----
[ 50.299214]
[ 50.299221] 0-54600000.isp (18):
[ 50.299225] active class 01, offset 0050, val 0000000d
[ 50.299228] DMAPUT 000001b0, DMAGET 00000128, DMACTL 00000000
[ 50.299231] CBREAD 0000000d, CBSTAT 00010050
[ 50.299237]
[ 50.299243] GATHER at ffc98000+4c54, 8 words
[ 50.299246] 20000001
[ 50.299248] 0000040d
[ 50.299251] 20000001
[ 50.299254] 0000050e
[ 50.299256] 20000001
[ 50.299259] 00000610
[ 50.299261] 200c0001
[ 50.299264] 00000005
[ 50.299270] GATHER at ffc98000+4c74, 2 words
[ 50.299273] 20000001
[ 50.299275] 0000000f
[ 50.299285]
[ 50.299291] 1-54080000.vi (13):
[ 50.299294] active class 01, offset 0050, val 0000001d
[ 50.299298] DMAPUT 000000e8, DMAGET 000000e8, DMACTL 00000000
[ 50.299301] CBREAD 0000001d, CBSTAT 00010050
[ 50.299306]
[ 50.299311] GATHER at ffc88000+0000, 35 words
[ 50.299314] 10620001
[ 50.299316] 0000001f
[ 50.299319] 10630002
[ 50.299321] 00000000
[ 50.299324] 00000000
[ 50.299327] 103a0001
[ 50.299329] 10100010
[ 50.299332] 103c0001
[ 50.299334] 10101010
[ 50.299337] 10420001
[ 50.299340] 00000001
[ 50.299342] 10430006
[ 50.299345] 00000000
[ 50.299348] 001c984c
[ 50.299350] 00000000
[ 50.299353] 00000000
[ 50.299355] 00000000
[ 50.299358] 00000000
[ 50.299360] 10590001
[ 50.299363] 00000003
[ 50.299366] 120e0006
[ 50.299369] 007f0015
[ 50.299371] 080301f0
[ 50.299374] 00000000
[ 50.299377] 00140000
[ 50.299379] 0000f005
[ 50.299382] 00000000
[ 50.299385] 12420001
[ 50.299387] 00000001
[ 50.299390] 124b0003
[ 50.299393] 00000000
[ 50.299396] 00000000
[ 50.299398] 00000040
[ 50.299401] 128b0001
[ 50.299404] 00000000
[ 50.299411] GATHER at ffc88000+008c, 3 words
[ 50.299414] 304e0005
[ 50.299416] 00000007
[ 50.299419] 0000000f
[ 50.299426] GATHER at ffc88000+0098, 17 words
[ 50.299429] 10430006
[ 50.299432] 00200002
[ 50.299435] 001c984c
[ 50.299438] 00000000
[ 50.299440] 04380780
[ 50.299444] 00000960
[ 50.299446] 0000002b
[ 50.299449] 124b0003
[ 50.299452] 00000000
[ 50.299455] 00000000
[ 50.299458] 00000046
[ 50.299461] 20000001
[ 50.299463] 00001c1d
[ 50.299466] 20000001
[ 50.299469] 00000522
[ 50.299472] 20410001
[ 50.299475] 00000001
[ 50.299482] GATHER at ffc88000+00dc, 2 words
[ 50.299485] 20000001
[ 50.299488] 0000001f
[ 50.299497]
[ 50.299501] sync_hintmask_ext = 0xc0000000
[ 50.299505] sync_hintmask = 0x80000000
[ 50.299508] sync_intc0mask = 0x00000001
[ 50.299512] sync_intmask = 0x00000011
[ 50.299515]
[ 50.299519] syncpt_thresh_int_mask(0) = 0x54400001
[ 50.299523] syncpt_thresh_int_mask(1) = 0x44000001
[ 50.299527] syncpt_thresh_int_mask(2) = 0x00000010
[ 50.299531] syncpt_thresh_int_mask(3) = 0x00000000
[ 50.299534] syncpt_thresh_int_mask(4) = 0x00000000
[ 50.299538] syncpt_thresh_int_mask(5) = 0x00000000
[ 50.299542] syncpt_thresh_int_mask(6) = 0x00000000
[ 50.299546] syncpt_thresh_int_mask(7) = 0x00000000
[ 50.299549] syncpt_thresh_int_mask(8) = 0x00000000
[ 50.299553] syncpt_thresh_int_mask(9) = 0x00000000
[ 50.299557] syncpt_thresh_int_mask(10) = 0x00000000
[ 50.299561] syncpt_thresh_int_mask(11) = 0x00000000
[ 50.299564]
[ 50.299568] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 50.299572] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 50.299576] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 50.299580] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 50.299584] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 50.299588] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 50.299591]
[ 50.299596] syncpt_int_thresh_thresh_0(0) = 1
[ 50.299606] syncpt_int_thresh_thresh_0(11) = 1824
[ 50.299611] syncpt_int_thresh_thresh_0(13) = 1
[ 50.299615] syncpt_int_thresh_thresh_0(14) = 1
[ 50.299620] syncpt_int_thresh_thresh_0(15) = 8
[ 50.299624] syncpt_int_thresh_thresh_0(16) = 1
[ 50.299635] syncpt_int_thresh_thresh_0(29) = 1
[ 50.299640] syncpt_int_thresh_thresh_0(31) = 3
[ 50.299645] syncpt_int_thresh_thresh_0(34) = 1
[ 51.770951] fence timeout on [ffffffc094e1b240] after 1500ms
[ 51.770958] name=[nvhost_sync:13], current value=0 waiting value=3
[ 51.770962] ---- mlocks ----
[ 51.770973] ---- syncpts ----
[ 51.770979] id 1 (disp0_a) min 374 max 374 refs 1 (previous client : )
[ 51.770983] id 2 (disp0_b) min 1 max 1 refs 1 (previous client : )
[ 51.770986] id 3 (disp0_c) min 1 max 1 refs 1 (previous client : )
[ 51.770991] id 8 (gm20b_507) min 19310 max 19310 refs 1 (previous client : )
[ 51.770995] id 9 (gm20b_506) min 14 max 14 refs 1 (previous client : )
[ 51.770999] id 11 (gm20b_505) min 1936 max 1936 refs 1 (previous client : gm20b_505)
[ 51.771003] id 13 (54600000.isp_0) min 0 max 3 refs 4 (previous client : )
[ 51.771006] id 14 (54600000.isp_1) min 0 max 3 refs 4 (previous client : )
[ 51.771009] id 15 (54600000.isp_2) min 7 max 15 refs 10 (previous client : )
[ 51.771012] id 16 (54600000.isp_3) min 0 max 3 refs 4 (previous client : )
[ 51.771017] id 21 (gm20b_504) min 704 max 704 refs 1 (previous client : )
[ 51.771020] id 22 (gm20b_503) min 58 max 58 refs 1 (previous client : )
[ 51.771023] id 23 (gm20b_502) min 2 max 2 refs 1 (previous client : )
[ 51.771026] id 24 (gm20b_501) min 2 max 2 refs 1 (previous client : )
[ 51.771029] id 25 (gm20b_500) min 6 max 6 refs 1 (previous client : )
[ 51.771032] id 26 (vblank0) min 3014 max -2 refs 1 (previous client : )
[ 51.771037] id 29 (54080000.vi_0) min 0 max 3 refs 4 (previous client : 54080000.vi_0)
[ 51.771048] id 31 (54080000.vi_2) min 2 max 7 refs 7 (previous client : 54080000.vi_2)
[ 51.771053] id 34 (54080000.vi_4) min 0 max 3 refs 4 (previous client : 54080000.vi_4)
[ 51.771057] id 37 (gm20b_499) min 8 max 8 refs 1 (previous client : )
[ 51.771060] id 38 (gm20b_498) min 6 max 6 refs 1 (previous client : )
[ 51.771063] id 39 (gm20b_497) min 6 max 6 refs 1 (previous client : )
[ 51.771066] id 40 (gm20b_496) min 6 max 6 refs 1 (previous client : )
[ 51.771068] id 41 (gm20b_495) min 6 max 6 refs 1 (previous client : )
[ 51.771071] id 42 (gm20b_494) min 6 max 6 refs 1 (previous client : )
[ 51.771155] ---- channels ----
[ 51.771162]
[ 51.771167] 0-54600000.isp (18):
[ 51.771170] active class 01, offset 0050, val 0000000d
[ 51.771173] DMAPUT 000001b0, DMAGET 00000128, DMACTL 00000000
[ 51.771175] CBREAD 0000000d, CBSTAT 00010050
[ 51.771179]
[ 51.771183] GATHER at ffc98000+4c54, 8 words
[ 51.771185] 20000001
[ 51.771187] 0000040d
[ 51.771188] 20000001
[ 51.771190] 0000050e
[ 51.771192] 20000001
[ 51.771193] 00000610
[ 51.771195] 200c0001
[ 51.771196] 00000005
[ 51.771200] GATHER at ffc98000+4c74, 2 words
[ 51.771202] 20000001
[ 51.771204] 0000000f
[ 51.771210]
[ 51.771214] 1-54080000.vi (13):
[ 51.771217] active class 01, offset 0050, val 0000001d
[ 51.771219] DMAPUT 000000e8, DMAGET 000000e8, DMACTL 00000000
[ 51.771220] CBREAD 0000001d, CBSTAT 00010050
[ 51.771224]
[ 51.771227] GATHER at ffc88000+0000, 35 words
[ 51.771229] 10620001
[ 51.771231] 0000001f
[ 51.771232] 10630002
[ 51.771234] 00000000
[ 51.771235] 00000000
[ 51.771237] 103a0001
[ 51.771238] 10100010
[ 51.771240] 103c0001
[ 51.771241] 10101010
[ 51.771243] 10420001
[ 51.771245] 00000001
[ 51.771246] 10430006
[ 51.771248] 00000000
[ 51.771249] 001c984c
[ 51.771251] 00000000
[ 51.771252] 00000000
[ 51.771254] 00000000
[ 51.771255] 00000000
[ 51.771257] 10590001
[ 51.771259] 00000003
[ 51.771260] 120e0006
[ 51.771262] 007f0015
[ 51.771264] 080301f0
[ 51.771265] 00000000
[ 51.771267] 00140000
[ 51.771268] 0000f005
[ 51.771270] 00000000
[ 51.771272] 12420001
[ 51.771273] 00000001
[ 51.771275] 124b0003
[ 51.771276] 00000000
[ 51.771278] 00000000
[ 51.771280] 00000040
[ 51.771281] 128b0001
[ 51.771283] 00000000
[ 51.771287] GATHER at ffc88000+008c, 3 words
[ 51.771289] 304e0005
[ 51.771290] 00000007
[ 51.771292] 0000000f
[ 51.771296] GATHER at ffc88000+0098, 17 words
[ 51.771297] 10430006
[ 51.771299] 00200002
[ 51.771301] 001c984c
[ 51.771303] 00000000
[ 51.771304] 04380780
[ 51.771306] 00000960
[ 51.771308] 0000002b
[ 51.771310] 124b0003
[ 51.771311] 00000000
[ 51.771313] 00000000
[ 51.771315] 00000046
[ 51.771316] 20000001
[ 51.771318] 00001c1d
[ 51.771320] 20000001
[ 51.771322] 00000522
[ 51.771323] 20410001
[ 51.771325] 00000001
[ 51.771329] GATHER at ffc88000+00dc, 2 words
[ 51.771330] 20000001
[ 51.771332] 0000001f
[ 51.771338]
[ 51.771340] sync_hintmask_ext = 0xc0000000
[ 51.771342] sync_hintmask = 0x80000000
[ 51.771345] sync_intc0mask = 0x00000001
[ 51.771347] sync_intmask = 0x00000011
[ 51.771349]
[ 51.771351] syncpt_thresh_int_mask(0) = 0x54400001
[ 51.771354] syncpt_thresh_int_mask(1) = 0x44000001
[ 51.771356] syncpt_thresh_int_mask(2) = 0x00000010
[ 51.771359] syncpt_thresh_int_mask(3) = 0x00000000
[ 51.771361] syncpt_thresh_int_mask(4) = 0x00000000
[ 51.771364] syncpt_thresh_int_mask(5) = 0x00000000
[ 51.771366] syncpt_thresh_int_mask(6) = 0x00000000
[ 51.771368] syncpt_thresh_int_mask(7) = 0x00000000
[ 51.771371] syncpt_thresh_int_mask(8) = 0x00000000
[ 51.771373] syncpt_thresh_int_mask(9) = 0x00000000
[ 51.771376] syncpt_thresh_int_mask(10) = 0x00000000
[ 51.771378] syncpt_thresh_int_mask(11) = 0x00000000
[ 51.771380]
[ 51.771383] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 51.771385] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 51.771388] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 51.771390] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 51.771393] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 51.771395] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 51.771397]
[ 51.771400] syncpt_int_thresh_thresh_0(0) = 1
[ 51.771407] syncpt_int_thresh_thresh_0(11) = 1938
[ 51.771411] syncpt_int_thresh_thresh_0(13) = 1
[ 51.771414] syncpt_int_thresh_thresh_0(14) = 1
[ 51.771417] syncpt_int_thresh_thresh_0(15) = 8
[ 51.771420] syncpt_int_thresh_thresh_0(16) = 1
[ 51.771428] syncpt_int_thresh_thresh_0(29) = 1
[ 51.771431] syncpt_int_thresh_thresh_0(31) = 3
[ 51.771435] syncpt_int_thresh_thresh_0(34) = 1
[ 58.746970] host1x 50000000.host1x: cdma_handle_timeout: timeout: 13 (54600000.isp_0) client 3, HW thresh 0, done 1
[ 58.757876] host1x 50000000.host1x: cdma_handle_timeout: timeout: 14 (54600000.isp_1) client 3, HW thresh 0, done 1
[ 58.772302] host1x 50000000.host1x: cdma_handle_timeout: timeout: 16 (54600000.isp_3) client 3, HW thresh 0, done 1
[ 58.784120] host1x 50000000.host1x: cdma_handle_timeout: timeout: 15 (54600000.isp_2) client 3, HW thresh 7, done 7
[ 58.794635] ---- mlocks ----
[ 58.794655] ---- syncpts ----
[ 58.794668] id 1 (disp0_a) min 459 max 459 refs 1 (previous client : )
[ 58.794676] id 2 (disp0_b) min 1 max 1 refs 1 (previous client : )
[ 58.794683] id 3 (disp0_c) min 1 max 1 refs 1 (previous client : )
[ 58.794695] id 8 (gm20b_507) min 20040 max 20040 refs 1 (previous client : )
[ 58.794700] id 9 (gm20b_506) min 14 max 14 refs 1 (previous client : )
[ 58.794705] id 11 (gm20b_505) min 2364 max 2364 refs 1 (previous client : gm20b_505)
[ 58.794711] id 13 (54600000.isp_0) min 0 max 3 refs 4 (previous client : )
[ 58.794717] id 14 (54600000.isp_1) min 0 max 3 refs 4 (previous client : )
[ 58.794721] id 15 (54600000.isp_2) min 7 max 15 refs 10 (previous client : )
[ 58.794725] id 16 (54600000.isp_3) min 0 max 3 refs 4 (previous client : )
[ 58.794731] id 21 (gm20b_504) min 704 max 704 refs 1 (previous client : )
[ 58.794735] id 22 (gm20b_503) min 58 max 58 refs 1 (previous client : )
[ 58.794739] id 23 (gm20b_502) min 2 max 2 refs 1 (previous client : )
[ 58.794742] id 24 (gm20b_501) min 2 max 2 refs 1 (previous client : )
[ 58.794749] id 25 (gm20b_500) min 6 max 6 refs 1 (previous client : )
[ 58.794753] id 26 (vblank0) min 3435 max -2 refs 1 (previous client : )
[ 58.794761] id 29 (54080000.vi_0) min 0 max 3 refs 4 (previous client : 54080000.vi_0)
[ 58.794766] id 31 (54080000.vi_2) min 2 max 7 refs 7 (previous client : 54080000.vi_2)
[ 58.794774] id 34 (54080000.vi_4) min 0 max 3 refs 4 (previous client : 54080000.vi_4)
[ 58.794779] id 37 (gm20b_499) min 8 max 8 refs 1 (previous client : )
[ 58.794785] id 38 (gm20b_498) min 6 max 6 refs 1 (previous client : )
[ 58.794790] id 39 (gm20b_497) min 6 max 6 refs 1 (previous client : )
[ 58.794795] id 40 (gm20b_496) min 6 max 6 refs 1 (previous client : )
[ 58.794799] id 41 (gm20b_495) min 6 max 6 refs 1 (previous client : )
[ 58.794803] id 42 (gm20b_494) min 6 max 6 refs 1 (previous client : )
[ 58.794902] ---- channels ----
[ 58.794910]
[ 58.794919] 0-54600000.isp (18):
[ 58.794923] active class 01, offset 0050, val 0000000d
[ 58.794925] DMAPUT 000001b0, DMAGET 00000128, DMACTL 00000000
[ 58.794928] CBREAD 0000000d, CBSTAT 00010050
[ 58.794933]
[ 58.794939] GATHER at ffc98000+4c54, 8 words
[ 58.794942] 20000001
[ 58.794947] 0000040d
[ 58.794951] 20000001
[ 58.794953] 0000050e
[ 58.794955] 20000001
[ 58.794957] 00000610
[ 58.794959] 200c0001
[ 58.794961] 00000005
[ 58.794966] GATHER at ffc98000+4c74, 2 words
[ 58.794968] 20000001
[ 58.794972] 0000000f
[ 58.794986]
[ 58.794992] 1-54080000.vi (13):
[ 58.794995] active class 01, offset 0050, val 0000001d
[ 58.794998] DMAPUT 000000e8, DMAGET 000000e8, DMACTL 00000000
[ 58.795000] CBREAD 0000001d, CBSTAT 00010050
[ 58.795004]
[ 58.795008] GATHER at ffc88000+0000, 35 words
[ 58.795010] 10620001
[ 58.795012] 0000001f
[ 58.795014] 10630002
[ 58.795016] 00000000
[ 58.795017] 00000000
[ 58.795019] 103a0001
[ 58.795021] 10100010
[ 58.795024] 103c0001
[ 58.795027] 10101010
[ 58.795032] 10420001
[ 58.795035] 00000001
[ 58.795039] 10430006
[ 58.795042] 00000000
[ 58.795046] 001c984c
[ 58.795049] 00000000
[ 58.795052] 00000000
[ 58.795056] 00000000
[ 58.795059] 00000000
[ 58.795062] 10590001
[ 58.795065] 00000003
[ 58.795067] 120e0006
[ 58.795069] 007f0015
[ 58.795071] 080301f0
[ 58.795073] 00000000
[ 58.795075] 00140000
[ 58.795077] 0000f005
[ 58.795079] 00000000
[ 58.795081] 12420001
[ 58.795083] 00000001
[ 58.795085] 124b0003
[ 58.795087] 00000000
[ 58.795088] 00000000
[ 58.795090] 00000040
[ 58.795092] 128b0001
[ 58.795094] 00000000
[ 58.795099] GATHER at ffc88000+008c, 3 words
[ 58.795101] 304e0005
[ 58.795103] 00000007
[ 58.795105] 0000000f
[ 58.795110] GATHER at ffc88000+0098, 17 words
[ 58.795112] 10430006
[ 58.795114] 00200002
[ 58.795116] 001c984c
[ 58.795118] 00000000
[ 58.795120] 04380780
[ 58.795122] 00000960
[ 58.795124] 0000002b
[ 58.795126] 124b0003
[ 58.795128] 00000000
[ 58.795130] 00000000
[ 58.795132] 00000046
[ 58.795134] 20000001
[ 58.795136] 00001c1d
[ 58.795138] 20000001
[ 58.795140] 00000522
[ 58.795142] 20410001
[ 58.795144] 00000001
[ 58.795148] GATHER at ffc88000+00dc, 2 words
[ 58.795150] 20000001
[ 58.795152] 0000001f
[ 58.795162]
[ 58.795167] sync_hintmask_ext = 0xc0000000
[ 58.795170] sync_hintmask = 0x80000000
[ 58.795174] sync_intc0mask = 0x00000001
[ 58.795177] sync_intmask = 0x00000011
[ 58.795181]
[ 58.795185] syncpt_thresh_int_mask(0) = 0x54000001
[ 58.795189] syncpt_thresh_int_mask(1) = 0x44000001
[ 58.795192] syncpt_thresh_int_mask(2) = 0x00000010
[ 58.795196] syncpt_thresh_int_mask(3) = 0x00000000
[ 58.795200] syncpt_thresh_int_mask(4) = 0x00000000
[ 58.795204] syncpt_thresh_int_mask(5) = 0x00000000
[ 58.795207] syncpt_thresh_int_mask(6) = 0x00000000
[ 58.795211] syncpt_thresh_int_mask(7) = 0x00000000
[ 58.795215] syncpt_thresh_int_mask(8) = 0x00000000
[ 58.795219] syncpt_thresh_int_mask(9) = 0x00000000
[ 58.795222] syncpt_thresh_int_mask(10) = 0x00000000
[ 58.795226] syncpt_thresh_int_mask(11) = 0x00000000
[ 58.795230]
[ 58.795234] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 58.795238] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 58.795242] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 58.795246] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 58.795254] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 58.795259] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 58.795270]
[ 58.795275] syncpt_int_thresh_thresh_0(0) = 1
[ 58.795285] syncpt_int_thresh_thresh_0(13) = 1
[ 58.795290] syncpt_int_thresh_thresh_0(14) = 1
[ 58.795295] syncpt_int_thresh_thresh_0(15) = 8
[ 58.795301] syncpt_int_thresh_thresh_0(16) = 1
[ 58.795312] syncpt_int_thresh_thresh_0(29) = 1
[ 58.795319] syncpt_int_thresh_thresh_0(31) = 3
[ 58.795325] syncpt_int_thresh_thresh_0(34) = 1
[ 58.795442] isp 54600000.isp: SYNCPT_ID 13
[ 58.795446] isp 54600000.isp: SYNCPT_VAL 1
[ 58.795450] isp 54600000.isp: FIRST_GET 0xa8
[ 58.795454] isp 54600000.isp: TIMEOUT 10000
[ 58.795458] isp 54600000.isp: NUM_SLOTS 3
[ 58.795461] isp 54600000.isp: NUM_HANDLES 1
[ 58.795567] isp 54600000.isp: SYNCPT_ID 15
[ 58.795574] isp 54600000.isp: SYNCPT_VAL 8
[ 58.795578] isp 54600000.isp: FIRST_GET 0xc0
[ 58.795582] isp 54600000.isp: TIMEOUT 10000
[ 58.795585] isp 54600000.isp: NUM_SLOTS 5
[ 58.795589] isp 54600000.isp: NUM_HANDLES 1
[ 58.795611] isp 54600000.isp: SYNCPT_ID 15
[ 58.795615] isp 54600000.isp: SYNCPT_VAL 9
[ 58.795619] isp 54600000.isp: FIRST_GET 0xe8
[ 58.795621] isp 54600000.isp: TIMEOUT 10000
[ 58.795625] isp 54600000.isp: NUM_SLOTS 3
[ 58.795630] isp 54600000.isp: NUM_HANDLES 1
[ 58.795650] isp 54600000.isp: SYNCPT_ID 15
[ 58.795652] isp 54600000.isp: SYNCPT_VAL 10
[ 58.795655] isp 54600000.isp: FIRST_GET 0x100
[ 58.795657] isp 54600000.isp: TIMEOUT 10000
[ 58.795660] isp 54600000.isp: NUM_SLOTS 3
[ 58.795662] isp 54600000.isp: NUM_HANDLES 3
[ 58.795680] isp 54600000.isp: SYNCPT_ID 13
[ 58.795683] isp 54600000.isp: SYNCPT_VAL 2
[ 58.795685] isp 54600000.isp: FIRST_GET 0x118
[ 58.795687] isp 54600000.isp: TIMEOUT 10000
[ 58.795690] isp 54600000.isp: NUM_SLOTS 3
[ 58.795692] isp 54600000.isp: NUM_HANDLES 1
[ 58.795756] isp 54600000.isp: SYNCPT_ID 15
[ 58.795759] isp 54600000.isp: SYNCPT_VAL 12
[ 58.795761] isp 54600000.isp: FIRST_GET 0x130
[ 58.795763] isp 54600000.isp: TIMEOUT 10000
[ 58.795766] isp 54600000.isp: NUM_SLOTS 5
[ 58.795768] isp 54600000.isp: NUM_HANDLES 1
[ 58.795786] isp 54600000.isp: SYNCPT_ID 15
[ 58.795789] isp 54600000.isp: SYNCPT_VAL 13
[ 58.795791] isp 54600000.isp: FIRST_GET 0x158
[ 58.795793] isp 54600000.isp: TIMEOUT 10000
[ 58.795796] isp 54600000.isp: NUM_SLOTS 3
[ 58.795798] isp 54600000.isp: NUM_HANDLES 3
[ 58.795816] isp 54600000.isp: SYNCPT_ID 13
[ 58.795818] isp 54600000.isp: SYNCPT_VAL 3
[ 58.795821] isp 54600000.isp: FIRST_GET 0x170
[ 58.795823] isp 54600000.isp: TIMEOUT 10000
[ 58.795825] isp 54600000.isp: NUM_SLOTS 3
[ 58.795828] isp 54600000.isp: NUM_HANDLES 1
[ 58.795890] isp 54600000.isp: SYNCPT_ID 15
[ 58.795893] isp 54600000.isp: SYNCPT_VAL 15
[ 58.795895] isp 54600000.isp: FIRST_GET 0x188
[ 58.795897] isp 54600000.isp: TIMEOUT 10000
[ 58.795900] isp 54600000.isp: NUM_SLOTS 5
[ 58.795902] isp 54600000.isp: NUM_HANDLES 1
[ 59.002965] host1x 50000000.host1x: cdma_handle_timeout: timeout: 29 (54080000.vi_0) client 10, HW thresh 0, done 1
[ 59.013477] host1x 50000000.host1x: cdma_handle_timeout: timeout: 34 (54080000.vi_4) client 10, HW thresh 0, done 1
[ 59.024027] host1x 50000000.host1x: cdma_handle_timeout: timeout: 31 (54080000.vi_2) client 10, HW thresh 2, done 2
[ 59.034604] ---- mlocks ----
[ 59.034615] ---- syncpts ----
[ 59.034621] id 1 (disp0_a) min 466 max 466 refs 1 (previous client : )
[ 59.034625] id 2 (disp0_b) min 1 max 1 refs 1 (previous client : )
[ 59.034628] id 3 (disp0_c) min 1 max 1 refs 1 (previous client : )
[ 59.034634] id 8 (gm20b_507) min 20116 max 20116 refs 1 (previous client : )
[ 59.034637] id 9 (gm20b_506) min 14 max 14 refs 1 (previous client : )
[ 59.034641] id 11 (gm20b_505) min 2400 max 2400 refs 1 (previous client : gm20b_505)
[ 59.034645] id 13 (54600000.isp_0) min 3 max 3 refs 1 (previous client : )
[ 59.034649] id 14 (54600000.isp_1) min 3 max 3 refs 1 (previous client : )
[ 59.034662] id 15 (54600000.isp_2) min 15 max 15 refs 1 (previous client : )
[ 59.034666] id 16 (54600000.isp_3) min 3 max 3 refs 1 (previous client : )
[ 59.034671] id 21 (gm20b_504) min 704 max 704 refs 1 (previous client : )
[ 59.034675] id 22 (gm20b_503) min 58 max 58 refs 1 (previous client : )
[ 59.034678] id 23 (gm20b_502) min 2 max 2 refs 1 (previous client : )
[ 59.034682] id 24 (gm20b_501) min 2 max 2 refs 1 (previous client : )
[ 59.034685] id 25 (gm20b_500) min 6 max 6 refs 1 (previous client : )
[ 59.034688] id 26 (vblank0) min 3449 max -2 refs 1 (previous client : )
[ 59.034693] id 29 (54080000.vi_0) min 0 max 3 refs 4 (previous client : 54080000.vi_0)
[ 59.034698] id 31 (54080000.vi_2) min 2 max 7 refs 7 (previous client : 54080000.vi_2)
[ 59.034703] id 34 (54080000.vi_4) min 0 max 3 refs 4 (previous client : 54080000.vi_4)
[ 59.034707] id 37 (gm20b_499) min 8 max 8 refs 1 (previous client : )
[ 59.034711] id 38 (gm20b_498) min 6 max 6 refs 1 (previous client : )
[ 59.034715] id 39 (gm20b_497) min 6 max 6 refs 1 (previous client : )
[ 59.034718] id 40 (gm20b_496) min 6 max 6 refs 1 (previous client : )
[ 59.034722] id 41 (gm20b_495) min 6 max 6 refs 1 (previous client : )
[ 59.034725] id 42 (gm20b_494) min 6 max 6 refs 1 (previous client : )
[ 59.034821] ---- channels ----
[ 59.034838]
[ 59.034844] 1-54080000.vi (13):
[ 59.034848] active class 01, offset 0050, val 0000001d
[ 59.034851] DMAPUT 000000e8, DMAGET 000000e8, DMACTL 00000000
[ 59.034853] CBREAD 0000001d, CBSTAT 00010050
[ 59.034859]
[ 59.034864] GATHER at ffc88000+0000, 35 words
[ 59.034866] 10620001
[ 59.034868] 0000001f
[ 59.034891] 10630002
[ 59.034894] 00000000
[ 59.034896] 00000000
[ 59.034898] 103a0001
[ 59.034900] 10100010
[ 59.034902] 103c0001
[ 59.034904] 10101010
[ 59.034906] 10420001
[ 59.034908] 00000001
[ 59.034910] 10430006
[ 59.034912] 00000000
[ 59.034914] 001c984c
[ 59.034925] 00000000
[ 59.034927] 00000000
[ 59.034929] 00000000
[ 59.034931] 00000000
[ 59.034933] 10590001
[ 59.034935] 00000003
[ 59.034940] 120e0006
[ 59.034944] 007f0015
[ 59.034948] 080301f0
[ 59.034952] 00000000
[ 59.034956] 00140000
[ 59.034960] 0000f005
[ 59.034963] 00000000
[ 59.034969] 12420001
[ 59.034973] 00000001
[ 59.034976] 124b0003
[ 59.034980] 00000000
[ 59.034984] 00000000
[ 59.034987] 00000040
[ 59.034991] 128b0001
[ 59.034995] 00000000
[ 59.035014] GATHER at ffc88000+008c, 3 words
[ 59.035017] 304e0005
[ 59.035021] 00000007
[ 59.035024] 0000000f
[ 59.035033] GATHER at ffc88000+0098, 17 words
[ 59.035037] 10430006
[ 59.035041] 00200002
[ 59.035046] 001c984c
[ 59.035050] 00000000
[ 59.035053] 04380780
[ 59.035057] 00000960
[ 59.035060] 0000002b
[ 59.035063] 124b0003
[ 59.035067] 00000000
[ 59.035070] 00000000
[ 59.035073] 00000046
[ 59.035077] 20000001
[ 59.035080] 00001c1d
[ 59.035084] 20000001
[ 59.035087] 00000522
[ 59.035091] 20410001
[ 59.035102] 00000001
[ 59.035112] GATHER at ffc88000+00dc, 2 words
[ 59.035117] 20000001
[ 59.035119] 0000001f
[ 59.035125]
[ 59.035128] sync_hintmask_ext = 0xc0000000
[ 59.035130] sync_hintmask = 0x80000000
[ 59.035132] sync_intc0mask = 0x00000001
[ 59.035135] sync_intmask = 0x00000011
[ 59.035137]
[ 59.035139] syncpt_thresh_int_mask(0) = 0x00000001
[ 59.035142] syncpt_thresh_int_mask(1) = 0x44000000
[ 59.035144] syncpt_thresh_int_mask(2) = 0x00000010
[ 59.035147] syncpt_thresh_int_mask(3) = 0x00000000
[ 59.035149] syncpt_thresh_int_mask(4) = 0x00000000
[ 59.035152] syncpt_thresh_int_mask(5) = 0x00000000
[ 59.035154] syncpt_thresh_int_mask(6) = 0x00000000
[ 59.035157] syncpt_thresh_int_mask(7) = 0x00000000
[ 59.035159] syncpt_thresh_int_mask(8) = 0x00000000
[ 59.035162] syncpt_thresh_int_mask(9) = 0x00000000
[ 59.035165] syncpt_thresh_int_mask(10) = 0x00000000
[ 59.035167] syncpt_thresh_int_mask(11) = 0x00000000
[ 59.035169]
[ 59.035172] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 59.035175] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 59.035177] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 59.035180] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 59.035192] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 59.035194] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 59.035196]
[ 59.035200] syncpt_int_thresh_thresh_0(0) = 1
[ 59.035218] syncpt_int_thresh_thresh_0(29) = 1
[ 59.035221] syncpt_int_thresh_thresh_0(31) = 3
[ 59.035225] syncpt_int_thresh_thresh_0(34) = 1
[ 59.036423] imx477 2-001a: imx477_power_on: power on
[ 59.341566] imx477 2-001a: imx477_set_mode:
[ 59.610183] imx477 2-001a: → imx477_set_mode:
[ 59.614912] imx477 2-001a: imx477_set_gain: Setting gain control to: 19
[ 59.623412] imx477 2-001a: imx477_set_gain: val: 19 (/10) [times], gain: 486
[ 59.631570] imx477 2-001a: imx477_set_exposure: Setting exposure control to: 16666
[ 59.639182] imx477 2-001a: imx477_set_exposure: val: 16666 [us], coarse_time: 1551 [lines]
[ 59.648732] imx477 2-001a: imx477_set_frame_rate: Setting framerate control to: 30000001
[ 59.656990] imx477 2-001a: imx477_set_frame_rate: val: 30000001e-6 [fps], frame_length: 3102 [lines]
[ 59.667286] imx477 2-001a: imx477_start_streaming:
[ 59.676263] imx477 2-001a: imx477_stop_streaming:
[ 59.681535] imx477 2-001a: imx477_power_off: power off
[ 59.686734] vi 54080000.vi: SYNCPT_ID 29
[ 59.686739] vi 54080000.vi: SYNCPT_VAL 1
[ 59.686743] vi 54080000.vi: FIRST_GET 0x0
[ 59.686748] vi 54080000.vi: TIMEOUT 10000
[ 59.686751] vi 54080000.vi: NUM_SLOTS 7
[ 59.686754] vi 54080000.vi: NUM_HANDLES 1
[ 59.686825] vi 54080000.vi: SYNCPT_ID 31
[ 59.686828] vi 54080000.vi: SYNCPT_VAL 3
[ 59.686831] vi 54080000.vi: FIRST_GET 0x38
[ 59.686834] vi 54080000.vi: TIMEOUT 10000
[ 59.686837] vi 54080000.vi: NUM_SLOTS 4
[ 59.686839] vi 54080000.vi: NUM_HANDLES 1
[ 59.686862] vi 54080000.vi: SYNCPT_ID 29
[ 59.686864] vi 54080000.vi: SYNCPT_VAL 2
[ 59.686867] vi 54080000.vi: FIRST_GET 0x58
[ 59.686882] vi 54080000.vi: TIMEOUT 10000
[ 59.686885] vi 54080000.vi: NUM_SLOTS 5
[ 59.686888] vi 54080000.vi: NUM_HANDLES 1
[ 59.686946] vi 54080000.vi: SYNCPT_ID 31
[ 59.686949] vi 54080000.vi: SYNCPT_VAL 5
[ 59.686952] vi 54080000.vi: FIRST_GET 0x80
[ 59.686954] vi 54080000.vi: TIMEOUT 10000
[ 59.686957] vi 54080000.vi: NUM_SLOTS 4
[ 59.686960] vi 54080000.vi: NUM_HANDLES 1
[ 59.686980] vi 54080000.vi: SYNCPT_ID 29
[ 59.686983] vi 54080000.vi: SYNCPT_VAL 3
[ 59.686985] vi 54080000.vi: FIRST_GET 0xa0
[ 59.686988] vi 54080000.vi: TIMEOUT 10000
[ 59.686990] vi 54080000.vi: NUM_SLOTS 5
[ 59.686993] vi 54080000.vi: NUM_HANDLES 1
[ 59.687042] vi 54080000.vi: SYNCPT_ID 31
[ 59.687045] vi 54080000.vi: SYNCPT_VAL 7
[ 59.687048] vi 54080000.vi: FIRST_GET 0xc8
[ 59.687050] vi 54080000.vi: TIMEOUT 10000
[ 59.687053] vi 54080000.vi: NUM_SLOTS 4
[ 59.687056] vi 54080000.vi: NUM_HANDLES 1
dmesg imx477
  3.806144] imx477 2-001a: probing v4l2 sensor at addr 0x1a
[    3.811939] imx477 2-001a: avdd, iovdd and/or dvdd reglrs. not present, assume sensor powered independently
[    3.821954] imx477 2-001a: tegracam sensor driver:imx477_v2.0.6
[    3.822006] imx477 2-001a: imx477_power_on: power on
[    4.384645] imx477 2-001a: imx477_power_off: power off
[    4.389913] imx477 2-001a: detected imx477 sensor
[    4.547883] vi 54080000.vi: subdev imx477 2-001a bound
[    5.813256] imx477 2-001a: imx477_open:
dmesg ds90ub95x
[    1.266611] i2c-ds90ub954 2-0030: ds90ub954_probe: start
[    1.266616] i2c-ds90ub954 2-0030: ds90ub954_parse_dt: deserializer:
[    1.266693] i2c-ds90ub954 2-0030: ds90ub954_parse_dt: - csi-lane-count 2
[    1.266699] i2c-ds90ub954 2-0030: ds90ub954_parse_dt: - csi-lane-speed 1600
[    1.266704] i2c-ds90ub954 2-0030: ds90ub954_parse_dt: - test-pattern disabled
[    1.266710] i2c-ds90ub954 2-0030: ds90ub954_parse_dt: - continuous clock enabled
[    1.266809] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: parsing serializers device tree:
[    1.266816] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - serializer rx-channel: 0
[    1.266821] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: -test-pattern disabled
[    1.266827] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - csi-lane-count 2
[    1.266832] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - gpio0-output-enable 1
[    1.266837] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - gpio1-output-enable property not found
[    1.266841] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: gpio1-output-enable to default val: 0
[    1.266846] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - gpio2-output-enable property not found
[    1.266850] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: gpio2-output-enable to default val: 0
[    1.266856] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - gpio3-output-enable property not found
[    1.266860] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: gpio3-output-enable to default val: 0
[    1.266865] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - gpio0-control 9
[    1.266870] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - gpio1-control property not found
[    1.266874] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: gpio1-control to default val: 0b1000
[    1.266878] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - gpio2-control property not found
[    1.266883] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: gpio2-control to default val: 0b1000
[    1.266887] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - gpio3-control property not found
[    1.266891] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: gpio3-control to default val: 0b1000
[    1.266896] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - hs-clk-div property not found
[    1.266900] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - hs-clk-div set to default val: 0x2 (div by 4)
[    1.266904] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - div-m-val property not found
[    1.266908] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - div-m-val set to default val: 1
[    1.266913] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - div-n-val property not found
[    1.266917] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - div-n-val set to default val: 0x28
[    1.266922] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - i2c-address: 0x18
[    1.267011] i2c-ds90ub954 2-0030: ds90ub953_i2c_client init client done
[    1.267033] i2c-ds90ub954 2-0030: ds90ub953_regmap_init init regmap done
[    1.267114] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - num of slave alias pairs: 1
[    1.267120] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - slave addr: 0x1A, alias addr: 0x1A
[    1.267125] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - continuous clock enabled
[    1.267130] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - i2c-pass-through-all disabled
[    1.267135] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - virtual-channel-map property not found
[    1.267139] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: - virtual-channel-map set to default val: 0xE4
[    1.267143] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: serializer 0 successfully parsed
[    1.267148] i2c-ds90ub954 2-0030: ds90ub953_parse_dt: done
[    1.285985] i2c-ds90ub954 2-0030: ds90ub954_init starting
[    1.287222] i2c-ds90ub954 2-0030: ds90ub954_init: device ID: 0x60, code:_UB954, revision: 0x20
[    1.822109] i2c-ds90ub954 2-0030: ds90ub954_init: start init of serializer rx_port 0
[    2.770141] i2c-ds90ub954 2-0030: ds90ub954_init: DEVICE STS: 0xdf, id=0 x 10ms
[    2.770147] i2c-ds90ub954 2-0030: ds90ub954_init: backchannel is ready
[    2.770362] i2c-ds90ub954 2-0030: ds90ub954_init: Successfully set TI954_REG_BC_GPIO_CTL0
[    2.770473] i2c-ds90ub954 2-0030: ds90ub954_init: Successfully set TI954_REG_BC_GPIO_CTL1
[    2.770584] i2c-ds90ub954 2-0030: ds90ub954_init: slave id 0: 0x1A
[    2.770695] i2c-ds90ub954 2-0030: ds90ub954_init: alias id 0: 0x1A
[    2.770806] i2c-ds90ub954 2-0030: ds90ub954_init: Virtual channel reg [0x72] = 228
[    2.770810] i2c-ds90ub954 2-0030: ds90ub954_init: VC-ID 0 mapped to 0
[    2.770814] i2c-ds90ub954 2-0030: ds90ub954_init: VC-ID 1 mapped to 1
[    2.770818] i2c-ds90ub954 2-0030: ds90ub954_init: VC-ID 2 mapped to 2
[    2.770822] i2c-ds90ub954 2-0030: ds90ub954_init: VC-ID 3 mapped to 3
[    2.770826] i2c-ds90ub954 2-0030: ds90ub954_init: init of deserializer rx_port 0 successful
[    2.771661] i2c-ds90ub954 2-0030: ds90ub954_probe: init ds90ub954_done
[    3.293986] i2c 2-0018: ds90ub953_init: start
[    3.294980] i2c 2-0018: ds90ub953_init: device ID: 0x32, code:_UB953
[    3.295742] i2c 2-0018: ds90ub953_init: successful
The tegra_sinterface should be serial_e instead of serial_a in device tree.
ShaneCCC, thank you very much.
Everything works as it should.
