0:00:00.034290254 82 0x558af9076000 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory "nvyolo"!
One element could not be created. Exiting.
$ deepstream-app -c deepstream_app_config_yoloV3_tiny.txt ../../../deepstream-4.0/samples/streams/sample_1080p_h264.mp4
/opt/nvidia/deepstream/deepstream-4.0/sources/objectDetector_Yolo$ deepstream-app -c deepstream_app_config_yoloV3_tiny.txt ../../../deepstream-4.0/samples/streams/sample_1080p_h264.mp4
0:00:00.041242406 7009 0x5617a070b210 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x120000: 'AVR (Audio Visual Research)' is not mapped
0:00:00.041259916 7009 0x5617a070b210 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x180000: 'CAF (Apple Core Audio File)' is not mapped
0:00:00.041264278 7009 0x5617a070b210 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x100000: 'HTK (HMM Tool Kit)' is not mapped
0:00:00.041268606 7009 0x5617a070b210 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0xc0000: 'MAT4 (GNU Octave 2.0 / Matlab 4.2)' is not mapped
0:00:00.041272233 7009 0x5617a070b210 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0xd0000: 'MAT5 (GNU Octave 2.1 / Matlab 5.0)' is not mapped
0:00:00.041275498 7009 0x5617a070b210 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x210000: 'MPC (Akai MPC 2k)' is not mapped
0:00:00.041279703 7009 0x5617a070b210 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0xe0000: 'PVF (Portable Voice Format)' is not mapped
0:00:00.041283613 7009 0x5617a070b210 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x160000: 'SD2 (Sound Designer II)' is not mapped
0:00:00.041290661 7009 0x5617a070b210 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x190000: 'WVE (Psion Series 3)' is not mapped
0:00:00.111197979 7009 0x5617a070b210 WARN ladspa gstladspa.c:507:plugin_init:<plugin156> no LADSPA plugins found, check LADSPA_PATH
0:00:00.126602234 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.265: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.126858751 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.265: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dewarper.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.127062635 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.265: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.127658002 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.266: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.128487900 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.266: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dsexample.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.128763516 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.267: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideo4linux2.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.128974078 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.267: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.129172016 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.267: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_segvisual.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.129489402 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.267: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_jpegdec.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.129699766 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.268: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.129894006 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.268: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.130078121 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.268: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ofvisual.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.130269479 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.268: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_eglglessink.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.130451666 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.268: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_of.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.177319940 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.315: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.177584473 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.316: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dewarper.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.177802389 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.316: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.178467318 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.316: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.179254135 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.317: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dsexample.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.179555242 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.318: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideo4linux2.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.179776366 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.318: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.179989779 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.318: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_segvisual.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.180266459 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.318: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_jpegdec.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.180481376 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.318: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.180700880 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.319: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.180910570 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.319: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ofvisual.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.181132004 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.319: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_eglglessink.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.181346673 7009 0x5617a070b210 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7009): GStreamer-WARNING **: 02:32:03.319: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_of.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.252498113 7008 0x56374b5c5c70 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory "nvstreammux"!
** ERROR: <create_multi_source_bin:653>: Failed to create element 'src_bin_muxer'
** ERROR: <create_multi_source_bin:715>: create_multi_source_bin failed
** ERROR: <create_pipeline:967>: create_pipeline failed
** ERROR: <main:632>: Failed to create pipeline
Quitting
App run failed
Second attempt:
./deepstream-test1-app ../../../../samples/streams/sample_1080p_h264.mp4
0:00:00.044183247 8307 0x5632c6881e10 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x120000: 'AVR (Audio Visual Research)' is not mapped
0:00:00.044202406 8307 0x5632c6881e10 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x180000: 'CAF (Apple Core Audio File)' is not mapped
0:00:00.044210655 8307 0x5632c6881e10 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x100000: 'HTK (HMM Tool Kit)' is not mapped
0:00:00.044217792 8307 0x5632c6881e10 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0xc0000: 'MAT4 (GNU Octave 2.0 / Matlab 4.2)' is not mapped
0:00:00.044223357 8307 0x5632c6881e10 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0xd0000: 'MAT5 (GNU Octave 2.1 / Matlab 5.0)' is not mapped
0:00:00.044228942 8307 0x5632c6881e10 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x210000: 'MPC (Akai MPC 2k)' is not mapped
0:00:00.044235477 8307 0x5632c6881e10 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0xe0000: 'PVF (Portable Voice Format)' is not mapped
0:00:00.044241651 8307 0x5632c6881e10 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x160000: 'SD2 (Sound Designer II)' is not mapped
0:00:00.044248636 8307 0x5632c6881e10 WARN default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x190000: 'WVE (Psion Series 3)' is not mapped
0:00:00.114877190 8307 0x5632c6881e10 WARN ladspa gstladspa.c:507:plugin_init:<plugin156> no LADSPA plugins found, check LADSPA_PATH
0:00:00.130227450 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.790: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.130478161 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.791: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dewarper.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.130675843 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.791: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.131277380 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.791: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.132108362 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.792: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dsexample.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.132380352 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.793: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideo4linux2.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.132581616 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.793: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.132775827 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.793: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_segvisual.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.133024558 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.793: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_jpegdec.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.133217762 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.793: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.133416565 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.794: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.133606998 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.794: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ofvisual.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.133807584 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.794: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_eglglessink.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.133999081 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.794: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_of.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.182096533 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.842: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.182376173 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.843: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dewarper.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.182599435 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.843: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.183269262 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.843: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.184047869 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.844: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dsexample.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.184350757 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.844: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideo4linux2.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.184575034 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.845: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.184793482 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.845: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_segvisual.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.185073664 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.845: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_jpegdec.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.185322522 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.845: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.185590134 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.846: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.185855353 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.846: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ofvisual.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.186170966 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.846: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_eglglessink.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.186399467 8307 0x5632c6881e10 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:8307): GStreamer-WARNING **: 02:51:59.847: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_of.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:00.249034183 8306 0x56174febd090 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory "nvv4l2decoder"!
0:00:00.249054342 8306 0x56174febd090 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory "nvstreammux"!
How to solve this problem?
I am trying to run deepstream 4.0 on my ubuntu 18.04 (x86_64).
