i try to build a kernel from source with the new L4T Releases 34.1.x (contained in Jetpack 5.0.x DP) for use with a Xavier NX (production).
When I checked the default config (created with make tegra-defconfig
), i recognised that the only SOC downstream option drivers that are included is the one for the t234 family (CONFIG_ARCH_TEGRA_23x_SOC).
Building the kernel (following Kernel Customization — Jetson Linux Developer Guide 34.1 documentation) with this config suceeds, but it won’t fit for the Xavier NX i want to boot on with.
When including the t194 drivers (ARCH_TEGRA_19x_SOC), the build fails exactly at the same point as posted in Building kernel 5.10 from nvbuild.sh script - Jetson & Embedded Systems / Jetson Xavier NX - NVIDIA Developer Forums.
No other config changes were made!
The Known Issues Section of the r34.1.1 Release Notes mention:
3499398 GPIO configuration utility does not work as expected in Linux 5.10 kernel included
in Jetpack 5.0 DP release
Does this mean no compilation actually possible due to incompatible pinctrl/pinmux implementations?
How can i successfully build a 5.x kernel for my Jetson Xavier NX?
Thanks in advance!
