When I’m converting some models to tensortRT, I’m not getting the last line:
“…TensorRTOptimizer: Graph size after: …”
obviously, on these, conversion wasn’t successful, while on others I do get the last line with a successful conversion.
Any thoughts on why this could be happening are more than appreciated.
my output for when it fails is:
2019-12-09 13:41:58.823081: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2019-12-09 13:41:58.823238: I tensorflow/core/grappler/devices.cc:55] Number of eligible GPUs (core count >= 8, compute capability >= 0.0): 1
2019-12-09 13:41:58.823436: I tensorflow/core/grappler/clusters/single_machine.cc:359] Starting new session
2019-12-09 13:41:58.823736: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2019-12-09 13:41:58.823870: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1640] Found device 0 with properties:
name: GeForce GTX 1060 with Max-Q Design major: 6 minor: 1 memoryClockRate(GHz): 1.48
pciBusID: 0000:01:00.0
2019-12-09 13:41:58.823898: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudart.so.10.0
2019-12-09 13:41:58.823908: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcublas.so.10.0
2019-12-09 13:41:58.823916: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcufft.so.10.0
2019-12-09 13:41:58.823924: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcurand.so.10.0
2019-12-09 13:41:58.823932: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcusolver.so.10.0
2019-12-09 13:41:58.823940: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcusparse.so.10.0
2019-12-09 13:41:58.823948: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudnn.so.7
2019-12-09 13:41:58.823979: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2019-12-09 13:41:58.824127: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2019-12-09 13:41:58.824249: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1763] Adding visible gpu devices: 0
2019-12-09 13:41:58.824264: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1181] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-12-09 13:41:58.824268: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1187] 0
2019-12-09 13:41:58.824271: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1200] 0: N
2019-12-09 13:41:58.824316: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2019-12-09 13:41:58.824477: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2019-12-09 13:41:58.824602: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1326] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 4949 MB memory) -> physical GPU (device: 0, name: GeForce GTX 1060 with Max-Q Design, pci bus id: 0000:01:00.0, compute capability: 6.1)
2019-12-09 13:41:58.926672: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:716] Optimization results for grappler item: tf_graph
2019-12-09 13:41:58.926709: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:718] constant folding: Graph size after: 96 nodes (-57), 95 edges (-57), time = 49.648ms.
2019-12-09 13:41:58.926725: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:718] layout: Graph size after: 122 nodes (26), 143 edges (48), time = 11.707ms.
2019-12-09 13:41:58.926728: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:718] constant folding: Graph size after: 122 nodes (0), 143 edges (0), time = 19.06ms.
