No toolbar after installation?
After installing the TADP from Gameworks, I don’t see a toolbar in VS2008 or VS2010 (I double checked that the VS plugin was checked during install). Is there some step I’m missing? Thanks.
Looking closer, it looks like “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Platforms\Tegra-Android” is missing (found by using an existing sln file which should use the Tegra VS integration). I looked at the logs for the Tegra installation and it says the VS portion installed correctly (and I can’t find the Tegra-Android directory anywhere else).
The issue was resolved via email. This is an installation problem and we’re looking into fixing it. If you encounter the same behavior please make sure .NET 4.5 is installed on the machine.
