NvCVImage_Transfer doesn’t appear to be able to transfer back from planar 32-bit BGR (used by the Super Resolution and Artifact Reduction effects) to any DXGI texture format I can find. The transfer from DirectX textures works fine, but not back.
The following code always returns 104/NVCV_ERR_PIXELFORMAT regardless of the DXGI_FORMAT used to create the DirectX texture:
ID3D11Device* device = nullptr;
if (FAILED(D3D11CreateDevice(nullptr, D3D_DRIVER_TYPE_HARDWARE, nullptr, 0, nullptr, 0, D3D11_SDK_VERSION, &device, nullptr, nullptr)))
return 96;
CUstream cuStream;
if (NvVFX_CudaStreamCreate(&cuStream) != NVCV_SUCCESS)
return 97;
uint32_t width = 1920;
uint32_t height = 1080;
ID3D11Texture2D* resource = nullptr;
D3D11_TEXTURE2D_DESC rtDesc;
ZeroMemory(&rtDesc, sizeof(D3D11_TEXTURE2D_DESC));
rtDesc.Width = width;
rtDesc.Height = height;
rtDesc.MipLevels = 1;
rtDesc.ArraySize = 1;
rtDesc.Format = DXGI_FORMAT_B8G8R8A8_UNORM;
rtDesc.SampleDesc.Count = 1;
rtDesc.Usage = D3D11_USAGE_DEFAULT;
rtDesc.BindFlags = D3D11_BIND_SHADER_RESOURCE;
rtDesc.CPUAccessFlags = 0;
rtDesc.MiscFlags = D3D11_RESOURCE_MISC_SHARED;
if (FAILED(device->CreateTexture2D(&rtDesc, nullptr, &resource)))
return 98;
NvCVImage texture;
if (NvCVImage_InitFromD3D11Texture(&texture, resource) != NVCV_SUCCESS)
return 99;
NvCVImage image(width, height, NVCV_BGR, NVCV_F32, NVCV_PLANAR, NVCV_GPU, 1);
NvCVImage temporary;
if (NvCVImage_MapResource(&texture, cuStream) != NVCV_SUCCESS)
return 100;
if (NvCVImage_Transfer(&texture, &image, 1, cuStream, &temporary) != NVCV_SUCCESS)
return 101;
if (NvCVImage_UnmapResource(&texture, cuStream) != NVCV_SUCCESS)
return 102;
return 103;
if (NvCVImage_Transfer(&image, &texture, 1, cuStream, &temporary) != NVCV_SUCCESS)
return 104;
return 105;
Do I need to manually transfer to another format before transferring to the DX11 texture or am I doing something wrong?
