I have a problem with the Jetson AGX Xavier. There is no video output via HDMI. I can receive a signal via a USB Type-C to HDMI converter, but there is no output on the HDMI port. I’ve already tried two monitors.
I’ve attached the dmesg output, in case it gives more information.
Kind of, it is a graphical drawing board, which also has HDMI input functionality, I had to enable the input mode again, because the monitor went out of input mode, because there was no signal.
I’ve already tested it on another monitor, and I’ve attached the dsmeg from that one now too.dmesg2.txt (71.0 KB)
No, I don’t get a signal. If I connect two at the same time, one via HDMI and one via Type C I can see it on the Type C monitor and set everything, but I have no image at the hdmi one.
Just want to confirm, that 2nd monitor is a native HDMI TV/monitor, right?
To prevent it is hardware issue…
Do you have only one xavier to do the test? If you have other xavier, could you try that monitor to another xavier to do the test?
If there is no other xavier, do you have other HDMI TV/monitors in your office/home that can try? It should be at least one of them could work. We have 6~7 monitors in office and they all work fine with my xavier.
Some of our monitors don’t have native HDMI input. But I’ve tried it now on all native hdmi monitors in our office and used two different cables. Still I have no image output.
