NOBARA 40, KDE, NVIDIA RTX 4090: assertion 'G_IS_OBJECT (object)' failed
i use the NOBARA 40 System for a few Days.
And i have a struggle whit: GLib-GObject-CRITICAL **: 21:41:14.855: g_object_unref: assertion ‘G_IS_OBJECT (object)’ failed
After 10 to 30 Minutes every Game kills whit this Message (var/log/messages).:
Dec  7 13:57:12 reaper steam[5914]: (process:2491): GLib-GObject-CRITICAL **: 13:57:12.445: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec  7 14:28:37 reaper steam[5147]: (process:2241): GLib-GObject-CRITICAL **: 14:28:37.982: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec  7 14:45:57 reaper steam[5147]: (process:3377): GLib-GObject-CRITICAL **: 14:45:57.166: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec  7 18:31:32 reaper steam[5147]: (process:5893): GLib-GObject-CRITICAL **: 18:31:32.439: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec  7 18:35:19 reaper steam[5147]: (process:7193): GLib-GObject-CRITICAL **: 18:35:19.890: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec  7 18:41:46 reaper steam[5147]: (process:9332): GLib-GObject-CRITICAL **: 18:41:46.850: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec  7 19:04:14 reaper steam[5147]: (process:10156): GLib-GObject-CRITICAL **: 19:04:14.117: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec  7 21:41:41 reaper steam[5147]: (process:16450): GLib-GObject-CRITICAL **: 21:41:41.636: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec  7 21:41:47 reaper steam[5147]: (process:16301): GLib-GObject-CRITICAL **: 21:41:47.299: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec  7 21:51:06 reaper steam[5147]: (process:17016): GLib-GObject-CRITICAL **: 21:51:06.371: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec  7 22:00:42 reaper steam[5147]: (process:17429): GLib-GObject-CRITICAL **: 22:00:42.438: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec  7 22:29:03 reaper steam[5147]: (process:18546): GLib-GObject-CRITICAL **: 22:29:03.559: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec  7 22:36:01 reaper steam[5147]: (process:19228): GLib-GObject-CRITICAL **: 22:36:01.417: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec  8 20:55:27 reaper steam[10057]: (process:1891): GLib-GObject-CRITICAL **: 20:55:27.441: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec 10 11:27:50 reaper steam[5256]: (process:2917): GLib-GObject-CRITICAL **: 11:27:50.305: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec 10 11:30:11 reaper steam[5256]: (process:3765): GLib-GObject-CRITICAL **: 11:30:11.501: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec 11 09:07:56 reaper steam[6627]: (process:2297): GLib-GObject-CRITICAL **: 09:07:56.015: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec 11 09:13:33 reaper steam[6627]: (process:2707): GLib-GObject-CRITICAL **: 09:13:33.987: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec 11 09:21:43 reaper steam[6627]: (process:3123): GLib-GObject-CRITICAL **: 09:21:43.608: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec 11 18:44:30 reaper steam[6627]: (process:4134): GLib-GObject-CRITICAL **: 18:44:30.022: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec 11 18:57:42 reaper steam[6627]: (process:4627): GLib-GObject-CRITICAL **: 18:57:42.407: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec 12 19:01:17 reaper steam[5482]: (process:3223): GLib-GObject-CRITICAL **: 19:01:17.624: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec 12 20:39:44 reaper steam[5482]: (process:4211): GLib-GObject-CRITICAL **: 20:39:44.485: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec 12 21:05:06 reaper steam[4953]: (process:2023): GLib-GObject-CRITICAL **: 21:05:06.607: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec 12 21:41:09 reaper steam[4953]: (process:6568): GLib-GObject-CRITICAL **: 21:41:09.150: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Dec 12 21:41:14 reaper steam[4953]: (process:6373): GLib-GObject-CRITICAL **: 21:41:14.855: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
After long Google-search-time i doesnt find a good troubleshooting instruction for debugging or a solution for this failure.
I Create this File for a deeper view, but i find nothing what can help.
nvidia-bug-report.log.gz (410.0 KB)
fastfetch
OS: Nobara Linux 40 (KDE Plasma) x86_64
Host: B550 AORUS PRO AC
Kernel: Linux 6.11.9-200.fsync.fc40.x86_64
Uptime: 1 hour, 38 mins
Packages: 3224 (rpm), 24 (flatpak)
Shell: pk-command-not-found
Display (DP-3): 2560x1440 @ 144 Hz in 27" [External] *
Display (HDMI-A-1): 1920x1080 @ 60 Hz in 24" [External]
WM: KWin (X11)
Theme: Adwaita-dark [GTK2/3]
Cursor: Adwaita
Terminal: konsole 24.08.3
CPU: AMD Ryzen 9 5950X (32) @ 5.08 GHz
GPU: NVIDIA GeForce RTX 4090
Memory: 7.81 GiB / 31.22 GiB (25%)
Swap: 0 B / 42.35 GiB (0%)
Disk (/): 253.76 GiB / 1.78 TiB (14%) - btrfs
Locale: de_AT.utf8
NVIDIA Settings
NVIDIA Driver Version: 565.77
NVML Version: 12.565.77
I have no idea what else I can do, and I don’t want to destroy my system with blind commands.
  • How i can made a Trace?
  • Elsewhere a debugging switch for more verbose logs?
Thanks for every input or advice.
reagards fox
After few Test i can say, the Problem happens only with the Steam Games… :-/
Edit:
  • Steamclient (flatpack) uninstall
  • Steamclient (rpm) install
    Same Failure.
Solution: Update to Nobara 41
