Dear Sir,
I am a beginner of PGI accelerator. Anyone could tell me whether PGI accelerator support “SELECTCASE” within the “!$acc region”? I found that sometimes it is work, but sometimes it is not correct.
When I disable the lines of Cof5(J,L) of the code, it works well. But when I enable them, the result of GPU and CPU becomes non-consistent.
My PC setting:
PGI 10.0
CUDA 2.2
Display card: FX4600
I compile the code in this way:
pgfortran -o test test.for -ta=nvidia,time -Minfo=accel
Any people could help me??
Kelvin
c-----Main Program (22 Dec 2009)
program test
use accel_lib
implicit none
integer,parameter :: N=600,M=4
integer J,L,CaseNos(N,M)
real Cof1(N,M),Cof2(N,M),Cof3(N,M),Cof4(N,M),Cof5(N,M)
real dummy1(N,M),dummy2(N,M)
c ***** Coefficients *****
do J=1,100
do L=1,M
CaseNos(J,L)=1
enddo
enddo
do J=101,200
do L=1,M
CaseNos(J,L)=2
enddo
enddo
do J=201,300
do L=1,M
CaseNos(J,L)=3
enddo
enddo
do J=301,400
do L=1,M
CaseNos(J,L)=4
enddo
enddo
do J=401,500
do L=1,M
CaseNos(J,L)=5
enddo
enddo
do J=501,600
do L=1,M
CaseNos(J,L)=6
enddo
enddo
c ***** GPU *****
!$acc region
do J=1,N
do L=1,M
SELECTCASE(CaseNos(J,L))
CASE(1)
Cof1(J,L)=1
Cof2(J,L)=3
Cof3(J,L)=50
Cof4(J,L)=4
c Cof5(J,L)=(-Cof3(J,L)+(sqrt(Cof3(J,L)*Cof3(J,L)
c & -4*Cof2(J,L)*Cof4(J,L))))*(0.5/Cof2(J,L))
Cof2(J,L)=-(Cof1(J,L)+Cof5(J,L))/150
Cof1(J,L)=1*Cof5(J,L)+1
Cof3(J,L)=3*Cof5(J,L)+3
Cof4(J,L)=4*Cof5(J,L)+4
CASE(2)
Cof1(J,L)=1
Cof2(J,L)=3
Cof3(J,L)=50
Cof4(J,L)=4
c Cof5(J,L)=(-Cof3(J,L)-(sqrt(Cof3(J,L)*Cof3(J,L)
CASE(3)
Cof1(J,L)=1
Cof2(J,L)=3
Cof3(J,L)=50
Cof4(J,L)=4
CASE(4)
Cof1(J,L)=1
Cof2(J,L)=3
Cof3(J,L)=50
Cof4(J,L)=4
CASE(5)
Cof1(J,L)=1
Cof2(J,L)=3
Cof3(J,L)=50
Cof4(J,L)=4
CASE(6)
Cof1(J,L)=1
Cof2(J,L)=3
Cof3(J,L)=50
Cof4(J,L)=4
ENDSELECT
dummy1(J,L)=Cof1(J,L)+Cof2(J,L)+Cof3(J,L)+Cof4(J,L)+Cof5(J,L)
enddo
enddo
!$acc end region
c ***** GPU *****
c ***** Host *****
do J=1,N
do L=1,M
CASE(1)
Cof1(J,L)=1
Cof2(J,L)=3
Cof3(J,L)=50
Cof4(J,L)=4
CASE(2)
Cof1(J,L)=1
Cof2(J,L)=3
Cof3(J,L)=50
Cof4(J,L)=4
CASE(3)
Cof1(J,L)=1
Cof2(J,L)=3
Cof3(J,L)=50
Cof4(J,L)=4
CASE(4)
Cof1(J,L)=1
Cof2(J,L)=3
Cof3(J,L)=50
Cof4(J,L)=4
CASE(5)
Cof1(J,L)=1
Cof2(J,L)=3
Cof3(J,L)=50
Cof4(J,L)=4
CASE(6)
Cof1(J,L)=1
Cof2(J,L)=3
Cof3(J,L)=50
Cof4(J,L)=4
ENDSELECT
dummy2(J,L)=Cof1(J,L)+Cof2(J,L)+Cof3(J,L)+Cof4(J,L)+Cof5(J,L)
enddo
enddo
c ***** Host *****
c ***** Check *****
do J=1,N
do L=1,M
if(dummy1(J,L).ne.dummy2(J,L))then
print*,J,L,dummy1(J,L),dummy2(J,L)
endif
enddo
enddo
c ***** Check *****
c-----Program Ended
end program test
