Description
I got a detector model from Quantization Aware Training. Trained in Tensorflow 2.3, converted to onnx and then to TensorRT.
I noticed that when triggering several times a builder of a TRT engine from using the same code & variables, and applying inference on the same image from each TRT engine - the results are not the same. (the engine is built on the same device)
Does it mean that the TRT engine builder is non-deterministic?
If so, how can we make it be deterministic so that when triggering the same setup several times, we’ll get the same TRT engine?
Environment
TensorRT Version : 7.1.2
CUDA Version : 11.0
Operating System + Version : Ubuntu 18.04
Python Version (if applicable) : 3.6
TensorFlow Version (if applicable) : The model was trained on tf 2.3, converted to onnx, and then converted to tensorRT engine.
I can’t share the relevant model for this.
Any help will be appreciated!
