I have a camera that sends MIPI video. I have it connected on CAM1
these are my relevant .dts sections:
`i2c@3180000 {
#address-cells = <0x01>;
#size-cells = <0x00>;
iommus = <0x06 0x04>;
dma-coherent;
compatible = “nvidia,tegra234-i2c”;
reg = <0x00 0x3180000 0x00 0x100>;
nvidia,hw-instance-id = <0x02>;
interrupts = <0x00 0x1b 0x04>;
scl-gpio = <0x50 0x72 0x00>;
sda-gpio = <0x50 0x73 0x00>;
status = “okay”;
clock-frequency = <0x61a80>;
clocks = <0x02 0x32 0x02 0x66>;
clock-names = “div-clk\0parent”;
assigned-clocks = <0x02 0x32>;
assigned-clock-parents = <0x02 0x66>;
resets = <0x02 0x1e>;
reset-names = “i2c”;
dmas = <0x3f 0x17 0x3f 0x17>;
dma-names = “rx\0tx”;
nvidia,epl-reporter-id = <0x8052>;
phandle = <0x2c6>;
prod-settings {
#prod-cells = <0x04>;
prod {
prod = <0x00 0x9c 0xffff 0x308 0x00 0xd4 0xff 0x00 0x00 0xd8 0xff 0x00 0x00 0xdc 0xffff 0x01 0x00 0xe0 0xffff 0x02>;
prod_c_fm {
prod = <0x00 0x6c 0xffff0000 0x3c0000 0x00 0x94 0xffff 0x202 0x00 0x98 0xffffffff 0x2020202>;
prod_c_fmplus {
prod = <0x00 0x6c 0xffff0000 0x160000 0x00 0x94 0xffff 0x202 0x00 0x98 0xffffffff 0x2020202>;
prod_c_hs {
prod = <0x00 0x6c 0xffffffff 0x160002 0x00 0x94 0xffff 0x202 0x00 0x98 0xffffffff 0x2020202 0x00 0xa0 0xffffff 0x90909>;
prod_c_sm {
prod = <0x00 0x6c 0xffff0000 0x4f0000 0x00 0x94 0xffff 0x708 0x00 0x98 0xffffffff 0x8080808>;
sg_zcm2090nmi@10 {
compatible = “savgood,sg_zcm2090nmi”;
reg = <0x10>;
physical_w = “15.974”;
physical_h = “12.000”;
sensor_model = “sg_zcm2090nmi”;
devnode = “video0”;
mode0 {
num_lanes = "4";
tegra_sinterface = "serial_c";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "20";
lane_polarity = "0";
active_w = "1920";
active_h = "1080";
mode_type = "yuv";
pixel_phase = "uyvy";
csi_pixel_bit_depth = "16";
dynamic_pixel_bit_depth = "16";
readout_orientation = "0";
line_length = "2200";
frame_length = "1125";
inherent_gain = "1";
pix_clk_hz = "74250000";
gain_factor = "1";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "1";
max_gain_val = "1";
default_gain = "1";
min_framerate = "60000000";
max_framerate = "60000000";
default_framerate = "60000000";
min_exp_time = "1";
max_exp_time = "1";
default_exp_time = "1";
embedded_metadata_height = "0";
step_gain_val = "1";
step_framerate = "1";
step_exp_time = "1";
ports {
port@0 {
reg = <0x00>;
sg_zcm_out0: endpoint {
port-index = <0x02>;
bus-width = <0x04>;
remote-endpoint = <&nvcsi_csi_in0>;
` nvcsi@15a00000 {
compatible = “nvidia,tegra194-nvcsi”;
clocks = <0x02 0x51>;
clock-names = “nvcsi”;
status = “okay”;
num-channels = <0x01>;
phandle = <0x43f>;
channel@0 {
reg = <0x00>;
phandle = <0x500>;
ports {
port@0 {
reg = <0x00>;
phandle = <0x501>;
nvcsi_csi_in0: endpoint@0 {
bus-width = <0x04>;
remote-endpoint = <&sg_zcm_out0>;
phandle = <0x502>;
port@1 {
reg = <0x01>;
phandle = <0x503>;
nvcsi_csi_out0: endpoint@1 {
bus-width = <0x04>;
remote-endpoint = <&sg_zcm_vi_in0>;
phandle = <0x504>;
`tegra-capture-vi {
compatible = “nvidia,tegra-camrtc-capture-vi”;
nvidia,vi-devices = <0x27c 0x27e>;
nvidia,vi-mapping-size = <0x06>;
nvidia,vi-mapping = <0x00 0x00 0x01 0x00 0x02 0x00 0x03 0x01 0x04 0x00 0x05 0x01>;
nvidia,vi-mapping-names = “csi-stream-id\0vi-unit-id”;
nvidia,vi-max-channels = <0x48>;
ports {
port@0 {
reg = <0x00>;
phandle = <0x42d>;
sg_zcm_vi_in0: endpoint@0 {
bus-width = <0x04>;
remote-endpoint = <&nvcsi_csi_out0>;
phandle = <0x4d4>;
`tegra-camera-platform {
compatible = “nvidia, tegra-camera-platform”;
num_csi_lanes = <0x04>;
max_lane_speed = <0x16e360>;
min_bits_per_pixel = <0x10>; // 16-bit for YUV
vi_peak_byte_per_pixel = <0x02>;
vi_bw_margin_pct = <0x19>;
max_pixel_rate = <0x3a980>;
isp_peak_byte_per_pixel = <0x05>;
isp_bw_margin_pct = <0x19>;
modules {
module0 {
badge = "sg_zcm2090nmi_cam";
position = "rear";
orientation = "1";
drivernode0 {
pcl_id = "v4l2_sensor";
devname = "sg_zcm2090nmi 2-0010";
proc-device-tree = "/proc/device-tree/bus@0/i2c@3180000/sg_zcm2090nmi@10";
`tegra-capture-vi {
ports {
port@0 {
reg = <0x00>;
phandle = <0x42d>;
bus-width = <0x04>;
phandle = <0x4d4>;
i will also attach my driver c code
when i try to open a stream with
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=UYVY --stream-mmap --stream-count=1
i get the following on dmesg:
[ 708.952533] sg_zcm2090nmi 2-0010: sg_zcm_set_mode: called
[ 708.956172] sg_zcm2090nmi 2-0010: sg_zcm_start_streaming: called
[ 711.636085] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 711.645258] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 711.654876] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 711.662667] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 711.673375] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 711.681681] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 714.195739] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 714.204891] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 714.214499] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 714.222298] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 714.233008] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 714.240761] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 714.251604] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 717.011611] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 717.020779] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 717.030390] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 717.038186] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 717.048893] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 718.067520] tegra194-vi5 13e40000.host1x:vi0@15c00000: capture control message timed out
[ 718.075865] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_control_send_message: failed to send IVC control message
[ 719.091466] tegra194-vi5 13e40000.host1x:vi0@15c00000: capture control message timed out
[ 719.099983] tegra-camrtc-capture-vi tegra-capture-vi: vi capture setup failed
[ 719.107617] tegra-camrtc-capture-vi tegra-capture-vi: fatal: error recovery failed
sg_zcm2090nmi_tegracam_debug (copy).c.txt (9.6 KB)
along with:
kworker/4:3-577 [004] … 125.252745: rtcpu_nvcsi_intr: tstamp:4504342524 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
kworker/4:3-577 [004] … 125.252746: rtcpu_nvcsi_intr: tstamp:4504342524 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001000
kworker/4:3-577 [004] … 125.252746: rtcpu_nvcsi_intr: tstamp:4504343450 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
kworker/4:3-577 [004] … 125.252746: rtcpu_nvcsi_intr: tstamp:4504343450 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001000
kworker/4:3-577 [004] … 125.252747: rtcpu_nvcsi_intr: tstamp:4504344373 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
kworker/4:3-577 [004] … 125.252749: rtcpu_nvcsi_intr: tstamp:4504344373 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001000
kworker/4:3-577 [004] … 125.252749: rtcpu_nvcsi_intr: tstamp:4504348074 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000040
kworker/4:3-577 [004] … 125.252750: rtcpu_nvcsi_intr: tstamp:4504348074 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000040
kworker/4:3-577 [004] … 125.252750: rtcpu_nvcsi_intr: tstamp:4504348998 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
kworker/4:3-577 [004] … 125.252750: rtcpu_nvcsi_intr: tstamp:4504348998 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001000
kworker/4:3-577 [004] … 125.252751: rtcpu_nvcsi_intr: tstamp:4504349929 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
kworker/4:3-577 [004] … 125.252751: rtcpu_nvcsi_intr: tstamp:4504349929 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001000
kworker/4:3-577 [004] … 125.252752: rtcpu_nvcsi_intr: tstamp:4504350844 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
kworker/4:3-577 [004] … 125.252752: rtcpu_nvcsi_intr: tstamp:4504350844 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001000
kworker/4:3-577 [004] … 125.252752: rtcpu_nvcsi_intr: tstamp:4504355487 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000040
kworker/4:3-577 [004] … 125.252753: rtcpu_nvcsi_intr: tstamp:4504355487 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000040
kworker/4:3-577 [004] … 125.252753: rtcpu_nvcsi_intr: tstamp:4504355487 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001040
kworker/4:3-577 [004] … 125.252753: rtcpu_nvcsi_intr: tstamp:4504355487 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000040
kworker/4:3-577 [004] … 125.252754: rtcpu_nvcsi_intr: tstamp:4504356925 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
kworker/4:3-577 [004] … 125.252754: rtcpu_nvcsi_intr: tstamp:4504356925 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001000
kworker/4:3-577 [004] … 125.252754: rtcpu_nvcsi_intr: tstamp:4504357818 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
kworker/4:3-577 [004] … 125.252755: rtcpu_nvcsi_intr: tstamp:4504357818 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001040
kworker/4:3-577 [004] … 125.252755: rtcpu_nvcsi_intr: tstamp:4504357818 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000040
kworker/4:3-577 [004] … 125.252756: rtcpu_nvcsi_intr: tstamp:4504358979 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000040
kworker/4:3-577 [004] … 125.252756: rtcpu_nvcsi_intr: tstamp:4504358979 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000040
kworker/4:3-577 [004] … 125.252756: rtcpu_nvcsi_intr: tstamp:4504363820 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
kworker/4:3-577 [004] … 125.252757: rtcpu_nvcsi_intr: tstamp:4504363820 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001000
kworker/4:3-577 [004] … 125.252757: rtcpu_nvcsi_intr: tstamp:4504364745 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
kworker/4:3-577 [004] … 125.252757: rtcpu_nvcsi_intr: tstamp:4504364745 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001000
kworker/4:3-577 [004] … 125.252758: rtcpu_nvcsi_intr: tstamp:4504367518 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000004
kworker/4:3-577 [004] … 125.252758: rtcpu_nvcsi_intr: tstamp:4504367518 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000004
kworker/4:3-577 [004] … 125.252758: rtcpu_nvcsi_intr: tstamp:4504369373 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
kworker/4:3-577 [004] … 125.252759: rtcpu_nvcsi_intr: tstamp:4504369373 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001000
kworker/4:3-577 [004] … 125.252759: rtcpu_nvcsi_intr: tstamp:4504370291 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000040
kworker/4:3-577 [004] … 125.252760: rtcpu_nvcsi_intr: tstamp:4504370291 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001040
kworker/4:3-577 [004] … 125.252760: rtcpu_nvcsi_intr: tstamp:4504371226 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
kworker/4:3-577 [004] … 125.252760: rtcpu_nvcsi_intr: tstamp:4504371226 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001000
kworker/4:3-577 [004] … 125.252761: rtcpu_nvcsi_intr: tstamp:4504373075 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000040
kworker/4:3-577 [004] … 125.252761: rtcpu_nvcsi_intr: tstamp:4504373075 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000040
kworker/4:3-577 [004] … 125.252761: rtcpu_nvcsi_intr: tstamp:4504376781 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x10000000
kworker/4:3-577 [004] … 125.252762: rtcpu_nvcsi_intr: tstamp:4504376781 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00001000
and frequent kernel crashes.
i tried to play with cil_settletime but to no avail
am I missing something obvious?
i will add the datasheets of the camera.
i have set the MIPI format to 1080P30 using the VISCA serial command
MIPI Digital Camera Module User Guide_20250331.pdf (610.3 KB)
can anobody help?
thanks
