I have been having issues with booting up my new 4gb jetson nano. I’ve done everything I can think of right now (which is not much but still). I have changed monitors, cables, power supplies, keyboards, reflashed SD card, and tried a different sd card. I’ve attached a picture of the boot screen it has been stuck on for the last hour, it occasionally restarts and goes through this again. I tried finding similar things on the forum so if this already exists a point in the right direction would be much appreciated.
Please try sdkmanager.
I am experiencing the same problem. Also nano 4gb version. Unfortunately, I don’t have a linux pc or dualboot to use the sdkmanager. Also sdkmanager in docker in windows or wsl doesn’t seem to work due to incompatible usb bindings. Could you recommend a solution?
No other suggestion, to reflash the device via SDK Manager is the only way.
