I am facing the following problem :
When using Unnormalized coordinates all values of my 4 by 4 Texture are read out properly
e.g.
printf("%i %i %i %i \n " , tex2D(refTex,0.5,0.5) , tex2D(refTex,1.5,0.5) , tex2D(refTex,2.5,0.5) ,tex2D(refTex,3.5,0.5) );
printf("%i %i %i %i \n " , tex2D(refTex,0.5,1.5) , tex2D(refTex,1.5,1.5) , tex2D(refTex,2.5,1.5) ,tex2D(refTex,3.5,1.5) );
printf("%i %i %i %i \n " , tex2D(refTex,0.5,2.5) , tex2D(refTex,1.5,2.5) , tex2D(refTex,2.5,2.5) ,tex2D(refTex,3.5,2.5) );
printf("%i %i %i %i \n " , tex2D(refTex,0.5,3.5) , tex2D(refTex,1.5,3.5) , tex2D(refTex,2.5,3.5) ,tex2D(refTex,3.5,3.5) );
BUT when using normalized coordinates
e.g.
printf("%i %i %i %i \n " , tex2D(refTex,0. /4.0,0.) , tex2D(refTex,1.0/4.0) , tex2D(refTex,2.0/4,0.0) ,tex2D(refTex,3.0/4.0,0.0) );
I get the folowing numbers
193 177 129 225
although the values in the texture lie in the range [1-16]
Normalized coordinate access is cruscial to me since I want to use the WRAP access mode for textures…
HERE IS THE CODE
//constructs a 4 by 4 matrix of type unsigned int
this->buildDitherMatrix(ditherMatrix);
//this->buildButtingMatrix(buttingMatrix);
try
// allocate array and copy image data
CUarray cu_array;
CUDA_ARRAY_DESCRIPTOR desc;
desc.Format = CU_AD_FORMAT_UNSIGNED_INT8;
desc.NumChannels = 1;
desc.Width = 4;
desc.Height = 4;
errorCode = cuArrayCreate( &cu_array, &desc );
cuErr(errorCode, "Creating array failed");
CUDA_MEMCPY2D copyParam;
memset(©Param, 0, sizeof(copyParam));
copyParam.dstMemoryType = CU_MEMORYTYPE_ARRAY;
copyParam.dstArray = cu_array;
copyParam.srcMemoryType = CU_MEMORYTYPE_HOST;
copyParam.srcHost = ditherMatrix;
copyParam.srcPitch = desc.Width* sizeof(uint8_t);
copyParam.WidthInBytes = copyParam.srcPitch;
copyParam.Height = desc.Height;
errorCode = cuMemcpy2D(©Param);
cuErr(errorCode, "Copying dither matrix to CUDA array failed");
std::cout<<copyParam.Height<<std::endl;
std::cout<<copyParam.WidthInBytes<<std::endl;
std::cout<<copyParam.srcPitch<<std::endl;
std::cout<<copyParam.srcXInBytes<<std::endl;
// set texture parameters
CUtexref cu_texref;
errorCode= (cuModuleGetTexRef(&cu_texref, cuModule, "refTex"));
cuErr(errorCode, "Fetching reference to global texture failed");
errorCode= (cuTexRefSetArray(cu_texref, cu_array, CU_TRSA_OVERRIDE_FORMAT));
cuErr(errorCode, "Set CUDA array format failed");
errorCode= (cuTexRefSetAddressMode(cu_texref, 0, CU_TR_ADDRESS_MODE_WRAP));
cuErr(errorCode, "Set CUDA addressing mode failed");
errorCode= (cuTexRefSetAddressMode(cu_texref, 1, CU_TR_ADDRESS_MODE_WRAP));
errorCode= (cuTexRefSetFilterMode(cu_texref, CU_TR_FILTER_MODE_LINEAR));
cuErr(errorCode, "Set CUDA filtering mode failed");
errorCode= (cuTexRefSetFlags(cu_texref, CU_TRSF_NORMALIZED_COORDINATES));
//errorCode= (cuTexRefSetFlags(cu_texref, CU_TRSF_READ_AS_INTEGER));
cuErr(errorCode, "Set CUDA normalized coordinate addressing mode failed");
errorCode= (cuTexRefSetFormat(cu_texref, CU_AD_FORMAT_UNSIGNED_INT8, 1));
cuErr(errorCode, "Set CUDA texture data type failed");
CUfunction hfunc;
//CUresult cuModuleGetFunction ( hfunc, CUmodule hmod, const char* name )
errorCode = cuModuleGetFunction( &hfunc, cuModule, "Png_kernel" );
cuErr(errorCode, "Get module functionPNG_TEXTURE failed");
errorCode= cuParamSetTexRef(hfunc, CU_PARAM_TR_DEFAULT, cu_texref);
cuErr(errorCode, "Bind CUDA array totexture failed");
catch(Exception &e)
throw e;
Thank you for your help.
