Not able to check whether DLA enabled/disabled using Nsight System
I dont see Nsight System output the DLA status (idle or busy) while running sampleGooglenet.cpp
Refer to your answer “DLA enabled/disabled at runtime using Nsight systems” suggested to use Nsight System for checking DLA status at runtime.
https://forums.developer.nvidia.com/t/dla-utilization-in-xavier-agx/203016/3
Is it possible to check DLA Status at runtime or not, or I am missing some flag.
sudo nsys profile /usr/src/tensorrt/bin/sample_googlenet --datadir=/usr/src/tensorrt/data/googlenet --useDLACore=0
Result of nsight systems
Also, here they shows DLA enabled/disbled on nsight systems
https://forums.developer.nvidia.com/t/nsight-systems-not-seeing-profile-ranges-when-dla-is-enabled/107382/2
Platform : Xavier AGX Dev. kit
TensorRT : 8.0.2
CUDA : 10.2
