Not able to generate kernel_headers.tbz2 under kernel Directory
I’ve built the JetPack 3.2.1 for the Jetson TX2 module. After completion of the build not able to find the kernel_headers.tbz2 file under $DEVDIR/kernel. And the wonder is even the kernel directory is also not created.
I’m posting my Jetpack & Kernel install directories as per “Compiling Jetson TX1/TX2 source code”
JetPack: /home/user/JetPack-L4T-3.2.1
Kernel: /home/user/JetPack-L4T-3.2.1/64_TX2/Linux_for_Tegra and attached the figure for the same.
And I’m suspecting that something is related to the path issue. Please correct me if anything am doing wrong.
Could you try Jetpack 4 releases? The latest release for TX2 is 4.6.2 and we would suggest use this version.
