Not able to get a Passed tag on 01-nbody.cu code in course "Getting Started with Accelerated Computing in CUDA C/C++"
Hey, Team, I cannot get a Pass Label on my Assessment as it always gives this error attached
, even when I complete the assignment with the below code. I have tried changing to multiple versions of code, even getting support, but the error seems to be the same.
My code for 01-nbody.cu: 01-nbody (2).cu - Google Drive
Thanks for joining NVIDIA forums. This may be related to a known issue. I have tagged the DLI team to look into your account.
Thanks for your patience as this gets sorted out.
Tom
Good day, and thanks for reaching out for support.
Using the code you provided, I was able to pass the assessment. So first off, congrats on the good work!
My best guess is that you are missing the step of running the run_assessment() function in the notebook before clicking on the “ASSESS TASK” button.
After saving your work to 09-nbody/01-nbody.cu be sure to execute the Jupyter notebook cell as shown below:
You should see the same message as me (since I used your code), and especially the “Congratulations! You passed the assessment!”
At this point you can now follow the instructions in the Generate a Certificate section of the notebook which will involve your clicking the “ASSESS TASK” button, but this time, you should see the same as I do:
Please let me know if you need any additional support and I’ll be happy to help.
This topic was automatically closed 60 minutes after the last reply. New replies are no longer allowed.
