Not able to get camera clock from TK1 board.
I tried to interface the image sensor ar1820hs with tegra k1 board. I followed all the steps given in Tegra k1 Linux driver package driver guide(Here full procedure for IMX135 image sensor is given for V4L2). I have done all the required changes for the AR1820HS.
The kernel module is also getting created. But it is not flashed into the tk1 during flashing. I need to manually copy the ar1820hs_v4l2.ko to the tk1 board. I am able to insert the module. But I am not able to get cam_mclk and xshutdown is always low.
Please guide me if anyone has worked on this. In addition please share me if there are any other document for the same.
thanks in advance.
