I am trying to install Pytorch version 1.3.0 on Jetson Nano. It is giving the below error.
nvlink error : entry function ‘_Z32ncclAllReduceTreeLLKernel_sum_i88ncclColl’ with max regcount of 80 calls function ‘_Z29ncclReduceScatterRing_max_f64P14CollectiveArgs’ with regcount of 96
nvlink error : entry function ‘_Z32ncclAllReduceRingLLKernel_sum_i88ncclColl’ with max regcount of 80 calls function ‘_Z29ncclReduceScatterRing_max_f64P14CollectiveArgs’ with regcount of 96
[ 37%] Built target gen_onnx_proto
[ 37%] Built target sleefpurec_scalar
[ 37%] Built target sleefdetpurecfma_scalar
[ 37%] Built target sleefpurecfma_scalar
[ 37%] Built target sleefdetadvsimd
Makefile:68: recipe for target ‘/home/jetbot/pytorch/build/nccl/obj/collectives/device/devlink.o’ failed
make[5]: *** [/home/jetbot/pytorch/build/nccl/obj/collectives/device/devlink.o] Error 255
Makefile:49: recipe for target ‘/home/jetbot/pytorch/build/nccl/obj/collectives/device/colldevice.a’ failed
make[4]: *** [/home/jetbot/pytorch/build/nccl/obj/collectives/device/colldevice.a] Error 2
Makefile:25: recipe for target ‘src.build’ failed
make[3]: *** [src.build] Error 2
[ 37%] Built target sleefadvsimd
CMakeFiles/nccl_external.dir/build.make:110: recipe for target ‘nccl_external-prefix/src/nccl_external-stamp/nccl_external-build’ failed
make[2]: *** [nccl_external-prefix/src/nccl_external-stamp/nccl_external-build] Error 2
CMakeFiles/Makefile2:67: recipe for target ‘CMakeFiles/nccl_external.dir/all’ failed
make[1]: *** [CMakeFiles/nccl_external.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs…
[ 37%] Built target sleefdetadvsimdnofma
[ 37%] Built target sleefadvsimdnofma
Makefile:140: recipe for target ‘all’ failed
make: *** [all] Error 2
File “setup.py”, line 756, in
build_deps()
File “setup.py”, line 324, in build_deps
cmake=cmake)
File “/home/jetbot/pytorch/tools/build_pytorch_libs.py”, line 59, in build_caffe2
cmake.build(my_env)
File “/home/jetbot/pytorch/tools/setup_helpers/cmake.py”, line 334, in build
self.run(build_args, my_env)
File “/home/jetbot/pytorch/tools/setup_helpers/cmake.py”, line 142, in run
check_call(command, cwd=self.build_dir, env=env)
File “/usr/lib/python3.6/subprocess.py”, line 311, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command ‘[‘cmake’, ‘–build’, ‘.’, ‘–target’, ‘install’, ‘–config’, ‘Release’, ‘–’, ‘-j’, ‘4’]’ returned non-zero exit status 2.
Jetson 4.3 sdk version SDcard image is mounted on the device.
jetbot@jetbot-desktop:~$ cat /etc/nv_tegra_release
R32 (release), REVISION: 3.1, GCID: 18186506, BOARD: t210ref, EABI: aarch64, DATE: Tue Dec 10 06:58:34 UTC 2019
I have also tried installing pytorch using the below commands, but it gave error telling it is not supported on this platform.
wget https://nvidia.box.com/shared/static/phqe92v26cbhqjohwtvxorrwnmrnfx1o.whl -O torch-1.3.0-cp36-cp36m-linux_aarch64.whl
pip3 install numpy torch-1.3.0-cp36-cp36m-linux_aarch64.whl
I have also tried installing version 1.1.0 and 1.2.0 , but getting same error.
Regards,
Shankar
