Not able to install sdk manager
Hi everyone, I’m trying to flash a Jetson Tx2 Developer Kit, and as it require, I’m installing on an host PC with Ubuntu 18.04 the Nvidia SDK Manager.
After downloaded it, I type this in order to install it:
sudo apt install ./sdkmanager_1.8.0-10363_amd64.deb
But in the reading package lists process, it encountered an error as follow:
Reading package lists… Error!
E: Sub-process Popen returned an error code (2)
E: Encountered a section with no Package: header
E: Problem with MergeList /home/jetpack/sdkmanager_1.8.0-10363_amd64.deb
E: The package lists or status file could not be parsed or opened.
Any thoughts? Thank you in advance!
$ sudo rm /var/lib/apt/lists/* -vf
$ sudo apt update
and try that again.
Thanks. I already tried it. But it doesn’t resolve anything.
Hi giuseppe.mazzone,
Please try download again on your ubuntu-18.04 host PC:
Download link: NVIDIA SDK Manager | NVIDIA Developer
Run below command:
$ sudo chmod 755 sdkmanager_1.8.0-10363_amd64.deb
$ sudo apt install ./sdkmanager_1.8.0-10363_amd64.deb
