I’m trying to interface ov5647 with jetson nano, In order to first get detected in jetson nano we should have dts file, so for that I took reference of imx219 and created dts files, then I removed imx219 and imx477 and I also created a driver which will load when its compatible string matches with dts compatible string, and prints kernel message, so after compiling and testing I did not see any messages in dmesg or ov5647 driver being used.I doubt with my dts file so I decompiled my dtb file to check it once can you guys please check it once what are things are missing.
/dts-v1/;
/memreserve/ 0x0000000080000000 0x0000000000020000;
compatible = "nvidia,p3449-0000-b00+p3448-0000-b00", "nvidia,jetson-nano", "nvidia,tegra210";
interrupt-parent = <0x1>;
#address-cells = <0x2>;
#size-cells = <0x2>;
nvidia,dtbbuildtime = "Oct 10 2022", "15:33:13";
nvidia,boardids = "3448";
nvidia,proc-boardid = "3448";
nvidia,pmu-boardid = "3448";
nvidia,fastboot-usb-pid = <0xb442>;
model = "NVIDIA Jetson Nano Developer Kit";
rbpcv2_ov5647_a@36 {
compatible = "nvidia,ov5647";
status = "okay";
reg = <0x36>;
devnode = "video0";
physical_w = "3.680";
physical_h = "2.760";
sensor_model = "ov5647";
use_sensor_mode_id = "true";
reset-gpios = <0x5b 0x97 0x0>;
linux,phandle = <0xb9>;
phandle = <0xb9>;
mode0 {
mclk_khz = "25000";
num_lanes = [32 00];
phy_mode = "DPHY";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = [30 00];
active_w = "2592";
active_h = "1944";
dynamic_pixel_bit_depth = "10";
csi_pixel_bit_depth = "10";
mode_type = "bayer";
pixel_phase = "bggr";
readout_orientation = "90";
line_length = "2844";
inherent_gain = [31 00];
mclk_multiplier = "3.4999";
pix_clk_hz = "87499996";
gain_factor = [31 00];
framerate_factor = "999999";
exposure_factor = "1000000";
min_gain_val = "16";
max_gain_val = "128";
step_gain_val = [31 00];
default_gain = "16";
min_hdr_ratio = [31 00];
max_hdr_ratio = [31 00];
min_framerate = "15000000";
max_framerate = "15000000";
step_framerate = [31 00];
default_framerate = "15000000";
min_exp_time = "65";
max_exp_time = "60000";
step_exp_time = [31 00];
default_exp_time = "10000";
embedded_metadata_height = [30 00];
mode1 {
mclk_khz = "25000";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
line_length = "2416";
mclk_multiplier = "3.6669";
pix_clk_hz = "81666663";
framerate_factor = "1000000";
min_framerate = "30000000";
max_framerate = "30000000";
default_framerate = "30000000";
min_exp_time = "60";
max_exp_time = "30000";
mode2 {
mclk_khz = "25000";
phy_mode = "DPHY";
active_w = "1280";
active_h = "960";
line_length = "1896";
mclk_multiplier = "3.66669";
min_framerate = "45000000";
max_framerate = "45000000";
default_framerate = "45000000";
min_exp_time = "43";
max_exp_time = "20000";
mode3 {
mclk_khz = "25000";
phy_mode = "DPHY";
active_w = "1280";
active_h = "720";
line_length = "1792";
min_framerate = "60000000";
max_framerate = "60000000";
default_framerate = "60000000";
max_exp_time = "10000";
ports {
#address-cells = <0x1>;
#size-cells = <0x0>;
port@0 {
reg = <0x0>;
endpoint {
port-index = <0x0>;
bus-width = <0x2>;
remote-endpoint = <0x77>;
linux,phandle = <0x78>;
phandle = <0x78>;
nvcsi {
num-channels = <0x1>;
linux,phandle = <0xbd>;
phandle = <0xbd>;
channel@0 {
reg = <0x0>;
linux,phandle = <0xbe>;
phandle = <0xbe>;
ports {
port@0 {
reg = <0x0>;
linux,phandle = <0xbf>;
phandle = <0xbf>;
endpoint@0 {
port-index = <0x0>;
bus-width = <0x2>;
remote-endpoint = <0x78>;
linux,phandle = <0x77>;
phandle = <0x77>;
port@1 {
reg = <0x1>;
linux,phandle = <0xc0>;
phandle = <0xc0>;
endpoint@1 {
remote-endpoint = <0x79>;
linux,phandle = <0x5f>;
phandle = <0x5f>;
plugin-manager {
fragement@9 {
ids = "<3448-0000-300", "<3448-0002-300";
override@0 {
target = <0x5d>;
_overlay_ {
status = "disabled";
override@1 {
target = <0xb8>;
_overlay_ {
keep-power-in-suspend;
non-removable;
override@2 {
target = <0xb9>;
_overlay_ {
status = "okay";
override@3 {
target = <0xba>;
_overlay_ {
status = "okay";
badge = "porg_front_RBPCV2";
position = "front";
orientation = [31 00];
override@4 {
target = <0xbb>;
_overlay_ {
status = "okay";
pcl_id = "v4l2_sensor";
devname = "ov5647 6-0036";
proc-device-tree = "/proc/device-tree/host1x/i2c@546c0000/rbpcv2_ov5647_a@36";
override@5 {
target = <0xbc>;
_overlay_ {
status = "okay";
pcl_id = "v4l2_lens";
proc-device-tree = "/proc/device-tree/lens_ov5647@RBPCV2/";
override@9 {
target = <0xbd>;
_overlay_ {
status = "okay";
override@10 {
target = <0xbe>;
_overlay_ {
status = "okay";
override@11 {
target = <0xbf>;
_overlay_ {
status = "okay";
override@12 {
target = <0x77>;
_overlay_ {
status = "okay";
port-index = <0x0>;
bus-width = <0x2>;
override@13 {
target = <0xc0>;
_overlay_ {
status = "okay";
override@14 {
target = <0x5f>;
_overlay_ {
status = "okay";
override@15 {
target = <0xc1>;
_overlay_ {
status = "okay";
num_csi_lanes = <0x2>;
max_lane_speed = <0x16e360>;
min_bits_per_pixel = <0xa>;
vi_peak_byte_per_pixel = <0x2>;
vi_bw_margin_pct = <0x19>;
max_pixel_rate = <0x3a980>;
isp_peak_byte_per_pixel = <0x5>;
isp_bw_margin_pct = <0x19>;
gps_wake {
compatible = "gps-wake";
gps-enable-gpio = <0xc6 0x8 0x0>;
gps-wakeup-gpio = <0x5b 0x26 0x0>;
linux,phandle = <0x11b>;
phandle = <0x11b>;
gpu-dvfs-rework {
status = "okay";
pwm_regulators {
compatible = "simple-bus";
pwm-regulator@0 {
status = "okay";
reg = <0x0>;
compatible = "pwm-regulator";
pwms = <0xce 0x0 0x9c4>;
regulator-name = "vdd-cpu";
regulator-min-microvolt = <0xacda0>;
regulator-max-microvolt = <0x143188>;
regulator-always-on;
regulator-boot-on;
voltage-table = <0xacda0 0x0 0xb18a0 0x1 0xb63a0 0x2 0xbaea0 0x3 0xbf9a0 0x4 0xc44a0 0x5 0xc8fa0 0x6 0xcdaa0 0x7 0xd25a0 0x8 0xd70a0 0x9 0xdbba0 0xa 0xe06a0 0xb 0xe51a0 0xc 0xe9ca0 0xd 0xee7a0 0xe 0xf32a0 0xf 0xf7da0 0x10 0xfc8a0 0x11 0x1013a0 0x12 0x105ea0 0x13 0x10a9a0 0x14 0x10f4a0 0x15 0x113fa0 0x16 0x118aa0 0x17 0x11d5a0 0x18 0x1220a0 0x19 0x126ba0 0x1a 0x12b6a0 0x1b 0x1301a0 0x1c 0x134ca0 0x1d 0x1397a0 0x1e 0x13e2a0 0x1f 0x142da0 0x20>;
linux,phandle = <0x9f>;
phandle = <0x9f>;
pwm-regulator@1 {
status = "okay";
reg = <0x1>;
pwms = <0xa7 0x1 0x1f40>;
regulator-name = "vdd-gpu";
regulator-init-microvolt = <0xf4240>;
regulator-n-voltages = <0x3e>;
regulator-enable-ramp-delay = <0x7d0>;
enable-gpio = <0x23 0x6 0x0>;
regulator-settling-time-us = <0xa0>;
dfll-max77621@70110000 {
dfll-max77621-integration {
i2c-fs-rate = <0xf4240>;
pmic-i2c-address = <0x36>;
pmic-i2c-voltage-register = <0x1>;
sel-conversion-slope = <0x1>;
linux,phandle = <0x11c>;
phandle = <0x11c>;
dfll-max77621-board-params {
sample-rate = <0x30d4>;
fixed-output-forcing;
cf = <0xa>;
ci = <0x0>;
cg = <0x2>;
droop-cut-value = <0xf>;
droop-restore-ramp = <0x0>;
scale-out-ramp = <0x0>;
linux,phandle = <0x11d>;
phandle = <0x11d>;
dfll-cdev-cap {
compatible = "nvidia,tegra-dfll-cdev-action";
act-dev = <0x2b>;
cdev-type = "DFLL-cap";
#cooling-cells = <0x2>;
linux,phandle = <0x18>;
phandle = <0x18>;
dfll-cdev-floor {
act-dev = <0x2b>;
cdev-type = "DFLL-floor";
linux,phandle = <0x10>;
phandle = <0x10>;
dvfs {
compatible = "nvidia,tegra210-dvfs";
vdd-cpu-supply = <0x9f>;
nvidia,gpu-max-freq-khz = <0xe1000>;
r8168 {
isolate-gpio = <0x5b 0xbb 0x0>;
tegra_udrm {
compatible = "nvidia,tegra-udrm";
linux,phandle = <0x11e>;
phandle = <0x11e>;
soft_watchdog {
compatible = "softdog-platform";
dt-override-status-odm-data = <0x30000 0x0>;
status = "okay";
linux,phandle = <0xb7>;
phandle = <0xb7>;
leds {
compatible = "gpio-leds";
linux,phandle = <0xc4>;
phandle = <0xc4>;
pwr {
gpios = <0x5b 0x41 0x0>;
default-state = "on";
linux,default-trigger = "system-throttle";
memory@80000000 {
device_type = "memory";
reg = <0x0 0x80000000 0x0 0x80000000>;
cpu_edp {
status = "okay";
nvidia,edp_limit = <0x61a8>;
gpu_edp {
status = "okay";
nvidia,edp_limit = <0x4e20>;
hot-surface-alert {
compatible = "userspace-therm-alert";
cdev-type = "hot-surface-alert";
status = "okay";
linux,phandle = <0x1f>;
phandle = <0x1f>;
lens_ov5647@RBPCV2 {
min_focus_distance = "0.0";
hyper_focal = "0.0";
focal_length = "3.04";
f_number = "2.0";
aperture = "0.0";
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
status = "okay";
linux,phandle = <0xc1>;
phandle = <0xc1>;
modules {
module0 {
position = "front";
linux,phandle = <0xba>;
phandle = <0xba>;
drivernode0 {
linux,phandle = <0xbb>;
phandle = <0xbb>;
drivernode1 {
linux,phandle = <0xbc>;
phandle = <0xbc>;
__symbols__ {
host1x = "/host1x";
vi_base = "/host1x/vi";
vi_port0 = "/host1x/vi/ports/port@0";
rbpcv2_ov5647_vi_in0 = "/host1x/vi/ports/port@0/endpoint";
head0 = "/host1x/dc@54200000";
head1 = "/host1x/dc@54240000";
dsi = "/host1x/dsi";
sor0 = "/host1x/sor";
sor0_hdmi_display = "/host1x/sor/hdmi-display";
sor0_dp_display = "/host1x/sor/dp-display";
sor1 = "/host1x/sor1";
sor1_hdmi_display = "/host1x/sor1/hdmi-display";
sor1_dp_display = "/host1x/sor1/dp-display";
dpaux0 = "/host1x/dpaux";
dpaux1 = "/host1x/dpaux1";
i2c7 = "/host1x/i2c@546c0000";
ina3221x = "/host1x/i2c@546c0000/ina3221x@40";
ov5647_single_cam0 = "/host1x/i2c@546c0000/rbpcv2_ov5647_a@36";
rbpcv2_ov5647_out0 = "/host1x/i2c@546c0000/rbpcv2_ov5647_a@36/ports/port@0/endpoint";
csi_base = "/host1x/nvcsi";
csi_chan0 = "/host1x/nvcsi/channel@0";
csi_chan0_port0 = "/host1x/nvcsi/channel@0/ports/port@0";
rbpcv2_ov5647_csi_in0 = "/host1x/nvcsi/channel@0/ports/port@0/endpoint@0";
csi_chan0_port1 = "/host1x/nvcsi/channel@0/ports/port@1";
rbpcv2_ov5647_csi_out0 = "/host1x/nvcsi/channel@0/ports/port@1/endpoint@1";
tegra_pmc = "/pmc@7000e400";
tcp = "/tegra-camera-platform";
cam_module0 = "/tegra-camera-platform/modules/module0";
cam_module0_drivernode0 = "/tegra-camera-platform/modules/module0/drivernode0";
cam_module0_drivernode1 = "/tegra-camera-platform/modules/module0/drivernode1";
Full file:
kernel_tegra210-p3448-0000-p3449-0000-b00.dts (303.8 KB)
