Software Version
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.10816
other
Host Machine Version
other
I want to perform batch inference on segmentation model. I converted the onnx model using tensorRT_optimization
tool, where I passed batchSize=5
flag but tensorRT_optimization
tool still uses batchSize=1 (default)
I also get a warning as shown below:
(segENV) dummy:~/SegModel$ /usr/local/driveworks-5.6/tools/dnn/tensorRT_optimization --modelType=onnx --onnxFile=/home/dummy/SegModel/segmodel.onnx --batchSize=5 --out=/home/dummy/dnn/src/segmodel_trt.bin --explicitBatch=1
[10-11-2022 12:13:47] DNNGenerator: Initializing TensorRT generation on model /home/dummy/SegModel/segmodel.onnx.
[10-11-2022 12:13:47] onnx2trt_utils.cpp:367: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[10-11-2022 12:13:47] DNNGenerator: Input "input": 3x480x640
[10-11-2022 12:13:47] DNNGenerator: Output "output": 26x480x640
[10-11-2022 12:14:36] The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
[10-11-2022 12:14:36] DNNValidator: Iteration 0: 6.573056 ms.
[10-11-2022 12:14:36] DNNValidator: Iteration 1: 6.563840 ms.
[10-11-2022 12:14:36] DNNValidator: Iteration 2: 7.925760 ms.
[10-11-2022 12:14:36] DNNValidator: Iteration 3: 6.976512 ms.
[10-11-2022 12:14:36] DNNValidator: Iteration 4: 6.606848 ms.
[10-11-2022 12:14:36] DNNValidator: Iteration 5: 6.608896 ms.
[10-11-2022 12:14:36] DNNValidator: Iteration 6: 6.609920 ms.
[10-11-2022 12:14:36] DNNValidator: Iteration 7: 6.607872 ms.
[10-11-2022 12:14:36] DNNValidator: Iteration 8: 6.903808 ms.
[10-11-2022 12:14:36] DNNValidator: Iteration 9: 8.797184 ms.
[10-11-2022 12:14:36] DNNValidator: Average over 10 runs is 7.017370 ms.
[10-11-2022 12:14:37] Releasing Driveworks SDK Context
I have also created the onnx model for batched inference specifically. The input and output dimensions of the model are shared below. tensorRT_optimization
tool only picks up CHW from the NCHW dimension present in onnx model.
Batched Input:
Batched Output:
Is this the current limitation of the tensorRT_optimization
tool? Looking forward to hearing back on this soon.
