I’m new to deepstream and attemping to run the sample apps. When I try to run the deepstream-test1-app, I just see it is stuck at “Running…” with no output. I ran it with the command
./deepstream-test1-app …/…/…/…/samples/streams/sample_720p.h264
(Also tried with mp4 input)
Based on comments in the other threads, I have tried to collect some diagnostics;
My system:
Ubuntu 18.04
GeForce 940MX
Driver: 430.50
CUDA 10.1
cuDNN 7.6.5
TensorRT 6.0.1.5
DeepStream SDK 4.0.2
- GST log for deepstream-test1-app (no output, stuck on “Running…”)
- GST log for deepstream-app with the config file source30_1080p_dec_infer-resnet_tiled_display_int8.txt (black screen)
- Same as above but with [primary gie] enable=0 (black screen)
- Output of gst-inspect-1.0 nvv4l2decoder
However, I am able to run and see output for two other apps with mjpeg inputs;
deepstream-segmentation-app and deepstream-image-decode-app
Please help to get this running… thank you.
