Not able to run jetson-io.py after 40pin header edit
Hello
I am working on a simple project to operate a relay module using 40pin of Jetson Agx Xavier.
After finishing pin setting through sudo /opt/nvidia/jetson-io/jetson-io.py (All pin functions are enabled)
After that, an error message appeared.
I ran jetson-io.py to check the error, but it turned off after a while.
I’ve tried to find and fix similar problems, but I don’t know what the problem is.
Solved.
If the overlay tree overlapped with the existing tree, it could not be executed.
When I delete the tree I created, it works fine.
Glad to know issue resolved. Thanks
