Hi, I am new to the whole area of conversational AI but decided to play a little bit with riva.
I am using fedora and podman as my os and after some modification to the scripts was able to run the trioton server with all default models and no errors. I try a few examples like:
riva_tts_client --voice_name=English-US.Female-1 --text=“test 1” --audio_file=/outputs/output.wav
and it was loking fine I also try asr example which also work fine but when I try:
riva_nlp_qa --questions=/outputs/a.txt --contexts=/outputs/c.txt
it seems that the service is not running I got RPC failed. Code: 12
the strange thing is that I don’t see any errors in the attached log there are a bunch of warnings but it looks like everything is loaded.
log.txt (152.5 KB)
Can some one point me to waht can case this behavior or some info how to debug and find out what is wrong.
