I was trying to report a problem and running “startx --logverbose 6” based on the instructions in “If you have a problem, PLEASE read this first”, but that failed to run, with the following message:
xinit : Unable to run program “xterm”: No such file or directory
Specify a program on the commandline or make sure that /user/bin is in your path.
I verified that the /user/bin is in the path environment variable.
I am running Fedora 23, nvidia driver version 361.42
