• Hardware Platform (Jetson / GPU) Tesla T4
• DeepStream Version 7.1
• TensorRT Version 10.3.0.26-1+cuda12.5
• NVIDIA GPU Driver Version (valid for GPU only) 566.36 (NVCC Version 12.6)
Getting stream error when running the following pipeline
nvstreammux name=nvstreammux0 batch-size=16 width=1920 height=1080 live-source=False sync-inputs=True batched-push-timeout=40000
! queue
! tee name=t
t. ! nvinfer batch-size=16 config-file-path=“/code/processor/video/DeepStream-Yolo-Face/config_infer_primary_yoloV8_face.txt” model-engine-file=“/code/processor/video/DeepStream-Yolo-Face/yolov8n-face-2-arsh.onnx_b16_gpu0_fp32.engine”
! queue ! meta.sink_0
! queue ! meta.sink_1
uridecodebin3 uri=“file:///videos/classroom.mp4” name=decodebin0 ! queue ! nvstreammux0.sink_0
uridecodebin3 uri=“file:///videos/fruit-and-vegetable-detection.mp4” name=decodebin1 ! queue ! nvstreammux0.sink_1
nvdsmetamux config-file=/code/config_files/metamux/config_metamux0.txt name=meta
! queue
! nvdsosd process-mode=1
! queue
! queue ! nvvideoconvert ! “video/x-raw(memory:NVMM),format=NV12” ! nvv4l2h264enc ! h264parse ! rtspclientsink location=rtsp://gstreamer-rtsp:8554/stream/0
What is your goal? Metamux is used for parallel inference and merging metadata.
If you want build a parallel inference pipeline, please refer to this repository
or the command line.
gst-launch-1.0 uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 ! mux.sink_0 \
uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 ! mux.sink_1 \
nvstreammux name=mux gpu-id=0 batch-size=2 width=1920 height=1080 ! queue ! tee name=t \
t.src_0 ! queue ! meta.sink_0 \
t.src_1 ! queue ! nvstreamdemux name=demux per-stream-eos=true \
demux.src_0 ! queue ! tee name=b0_t \
demux.src_1 ! queue ! tee name=b1_t \
b0_t.src_0 ! queue ! b0_m.sink_0 nvstreammux name=b0_m batch-size=1 width=1920 height=1080 ! queue ! nvinfer batch-size=1 config-file-path=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt ! queue ! meta.sink_1 \
b1_t.src_0 ! queue ! b1_m.sink_1 nvstreammux name=b1_m batch-size=1 width=1920 height=1080 ! queue ! nvinfer batch-size=1 config-file-path=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt ! queue ! meta.sink_2 \
nvdsmetamux name=meta config-file=config_metamux.txt ! queue ! nvmultistreamtiler width=1920 height=1080 ! queue ! nvvideoconvert ! nvdsosd ! nv3dsink
We are using this, following your reply
gst-launch-1.0 uridecodebin uri=file:///videos/classroom.mp4 ! mux.sink_0
uridecodebin uri=file:///videos/classroom.mp4 ! mux.sink_1
b0_t.src_0 ! queue ! b0_m.sink_0 nvstreammux name=b0_m batch-size=1 width=1920 height=1080 ! queue ! nvinfer batch-size=1 config-file-path=/code/processor/video/DeepStream-Yolo-Face/config_infer_primary_yoloV8_face.txt ! queue ! meta.sink_1
b1_t.src_0 ! queue ! b1_m.sink_1 nvstreammux name=b1_m batch-size=1 width=1920 height=1080 ! queue ! nvinfer batch-size=1 config-file-path=/code/processor/video/DeepStream-Yolo-Face/config_infer_primary_yoloV8_face.txt ! queue ! meta.sink_2
nvdsmetamux name=meta config-file=/code/config_files/metamux/config_metamux0.txt ! queue ! nvmultistreamtiler width=1920 height=1080 ! queue ! nvvideoconvert ! nvdsosd !
queue ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=NV12" ! nvv4l2h264enc ! h264parse
! rtspclientsink location=rtsp://gstreamer-rtsp:8554/stream0
Getting error from cuda
Setting pipeline to PAUSED ...
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:327 [FullDims Engine Info]: layers num: 4
0 INPUT kFLOAT input 3x640x640 min: 1x3x640x640 opt: 16x3x640x640 Max: 16x3x640x640
1 OUTPUT kFLOAT boxes 8400x4 min: 0 opt: 0 Max: 0
2 OUTPUT kFLOAT scores 8400x1 min: 0 opt: 0 Max: 0
3 OUTPUT kFLOAT landmarks 8400x15 min: 0 opt: 0 Max: 0
Pipeline is PREROLLING ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://gstreamer-rtsp:8554/stream0
Progress: (open) Retrieving server options
Progress: (open) Opened Stream
INFO:
gstnvtiler.cpp(253): gst_nvmultistreamtiler_sink_event (): /GstPipeline:pipeline0/GstNvMultiStreamTiler:nvmultistreamtiler0:
Configuration 1x2
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Progress: (request) Sending RECORD request
Warning: Not increasing the pool size as CUDA memory is already at 99.000000 utilisation
Redistribute latency...
Cuda failure: status=2
Error(-1) in buffer allocation
Execution ended after 0:00:00.255649589
Setting pipeline to NULL ...
Freeing pipeline ...
cudaErrorMemoryAllocation = 2
The API call failed because it was unable to allocate enough memory or other resources to perform the requested operation.
T4 only has 16G of video memory. Parallel inference of two instances of yolo-face model leads to insufficient video memory. You need to change your GPU to one with larger memory
Is there a better way to do parallel inferencing then? As we have seen that for a single model it doesn’t take more than 1gb of vRAM, so it’s a bit confusing why it’s taking more than 16gb when using two instances of the model.
Using the vehicle detection model in DS SDK to do parallel inferencing, only 1G plus vRAM is used.
Will this model use a lot of vRAM ? Is there another program using the GPU? Use nvidia-smi -l
to monitor the vRAM usage.
