Not Able Visualize the Isaac Sim Environment Inside the HTC VIVE
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
Isaac Sim Version
5.1.0
Operating System
Ubuntu 22.04
GPU Information
  • Model: RTX A5000
  • Driver Version: 580.95.05
Topic Description
Detailed Description
 I have an HTC Vive (2018 model) and I want to visualize the Isaac Sim environment inside the headset. I am using the Monado OpenXR runtime. When I move the controller and the headset, the movement is reflected correctly in Isaac Sim, but I am not able to see the environment inside the HTC Vive.
For additional Information.
In the steamVR, I am able see the steamVRHome inside the Headset.
Steps to Reproduce
  1. To setup the Monado I followed this Instruction.(Monado - Getting Started)
  2. In the Isaac sim , download the XR and close the IsaacSim.
  3. In one terminal I launched the monado-service and other terminal before launching IsaacSim paste this command “export XR_RUNTIME_JSON=~/monado/build/openxr_monado-dev.json” to Isaac SIM get exact location of the monado openXR.
  4. Once Isaac sim Launched , Click start VR. Now you can see VR launched without any issues.
(Add more steps as needed)
Screenshots or Videos
Could you reproduce the issue with VR started and then attach the full Kit log file from that run?
Hello!
Best regards,
