We are in wait and looking for a solution, someone have black borders on the screen, bad resolution, and in my case I have an auto adjust screen with no black borders but my text is aliased as you can see here https://oxhak.fr/nvidia_bug_355.11.png
I can confirm the issue with 355.11: I’m running Archlinux x86_64 on a desktop with two Nvidia GTX 550 in SLI mode, with only one monitor connected to the VGA port of the first card: using a resolution higher than or equal to 1680x1650 at 59.95Hz (the monitor native resolution) the display area goes outside of the screen (screenshot) and then the monitor tries to auto-adjust itself but it fails. Everything works fine with the same monitor using the HDMI port, and the issue disappears also downgrading to 352.41.
I have the same issue with Archlinux x86_64 and nVidia drivers 355.11 on linux 4.2.1. Fonts are illegible and screen is distorted. I have a Samsung monitor 1366x768 at 59.95Hz via VGA on a GTX750Ti. When downgrading to 352.41 and to linux 4.1.6 the problem disappear.
Can someone with this problem please generate and attach nvidia-bug-report.log.gz files from the working and broken drivers? Also, can you please test the 358.09 driver too?
Thanks for your reply aplattner, this my nvidia-bug-report https://oxhak.fr/nvidia-bug-report.log.gz with the current 355.11-3 on Arch Linux, the broken driver. I can’t attach a working nvidia-bug-report version cause I can’t downgrade, If anyone who have downgraded can post an nvidia-bug-report with the working drivers version it can be helpfull !
I’m sorry, I forgot to ask for a verbose log with mode validation information. You can get that by either starting X from the console with “startx – -logverbose 6” or by running “sudo nvidia-xconfig --mode-debug” and then restarting the X server.
Here is how it looks for me: [url]http://i.imgur.com/u74DQNZ.jpg[/url]
I think it is automatically discovering wrong dpi resolution for monitor and that’s the effect off applying 83x105 * 1680x1050 in my case…
83x105 is lie. I don’t remember exact dpi right now but it was something like that.
1600x1200 works well which is confirming my theory as my monitor have 90x90 dpi resolution.
After upgrading two of my monitors won’t even show up at all, I can’t quite pull any logs at the moment but I had an Acer monitor and a Dell monitor over DVI, and my Rift over HDMI. GDM keeps restarting over and over due to it not finding any screens, at least until I power my Rift. From there, only the Rift shows as connected, all other monitors show as disconnected despite being on. I did another test though and an old 1280x1024 Samsung SyncMaster display works properly. Interestingly, if I boot with that monitor, then swap another monitor in it’s place, it detects correctly (but only for the port it booted in). Really funky stuff in this update :/
Looks like I’m seeing the same type of issue. I didn’t find this thread when I originally looked so I posted about it a few days ago. I’ve just forced pacman to remove the Nvidia driver and have manually installed 352.55 for now. Luckily it is only affecting my HTPC with a gt610. My main PC running gtx970’s has been fine, but maybe it’s the monitors correcting it.
My HTPC is connected to my surround receiver via HDMI cable with my TV also connected via HDMI to my receiver.
I also reported this bug to RPMFusion, but seems NVIDIA’s fault after what I read: 3801 – Blurry output after last update (there’s a workaround for RPMFusion users too).
