Not getting any display from jetson board when connected to monitor
My jetson nano B01 board is getting power as the light is blinking and ethernet is also connected but the monitor says there is no signal. All the HDMI cables and the monitor are working fine ,as i have checked by connecting to other devices. I have also dumped the log in serial debug console and i am uploading the screenshots here for reference. In the debug console with minicom .when i connect the jetson to the monitor with hdmi it says configure on desktop, that means the connection is detected but i still have no display on the monitor . How can i fix this issue of display ? And can you confirm if its a hardware or software issue ?
Looks like bootloader software has something broken. Please reflash the board by using sdkmanager.
i have reflashed the board multiple times with sdk manager but still there seems to be no display output . i have tried the DP port also but still nothing. Is there any other way to fix this ?
share us the log after your sdkmanger flash attempt. Otherwise it is just some comments from you. It does not mean anything.
