Not getting classification result in image-data-multistream for vehicle Type
Hi Team,
I am using Nvidia Nx-Xavier system, jetpack-4.4-b186 and DS-5.0.
I am running python DS test app-2 and I am able to get the Vehicle type classification result. but with the deepstream-image-data multistream application I am able get the type classification result but only some frame (if I am getting result of type classification on 2000 frame in test-app-2 so for the same configuration I am getting result on 5 frame with deepstream-imagedata-multistream app).
The problem is only with the type classification other classifier are working on both application.
below I am attaching the result of classification and Codebase file too.
CodeBase :
deepstream_imagedata-multistream.py (18.3 KB)
deepstream_test_2.py (14.6 KB)
Configuration file :
dstest2_pgie_config.txt (3.4 KB)
dstest2_sgie1_config.txt (3.5 KB)
dstest2_sgie2_config.txt (3.5 KB)
dstest2_sgie3_config.txt (3.5 KB)
dstest2_tracker_config.txt (1.8 KB)
Please help me out in finding why I am unable to get classification results on deepstream-imagedata-multistream.
Just check your deepstream_test_2.py and deepstream_imagedata-multistream.py.
The pipeline is different.
In deepstream_test_2.py:
pgie.link(tracker)
tracker.link(sgie1)
sgie1.link(sgie2)
sgie2.link(sgie3)
sgie3.link(nvvidconv)
nvvidconv.link(nvosd)
And for deepstream_imagedata-multistream.py:
pgie.link(dsexample)
dsexample.link(tracker)
tracker.link(sgie1)
#dsexample.link(sgie1)
sgie1.link(sgie2)
sgie2.link(nvvidconv1)
nvvidconv1.link(filter1)
The sgie3, which represents for the vehicle type classifier, is missing in the pipeline of deepstream_imagedata-multistream.py.
So please add the sgie3 back to the pipeline to fix this issue.
Thanks @AastaLLL for the rply.
Actually in deepstream-imagedata-multistream I am not using car color classifier.
In deepstream-imagedata-multistream sgie1 and sgie2 represent vehicle type and make.
sgie1.set_property(‘config-file-path’, “dstest2_sgie2_config.txt”)
sgie2.set_property(‘config-file-path’, “dstest2_sgie3_config.txt”)
please help where I am wrong.
Sorry that I don’t notice that.
Based on the pipeline, the behavior for sgie1 and sgie2 should be similar.
Could you get the expected classification result from sgie1?
