I get video playback off of some deepstream_test3_app as well as with the gst-launch-1.0 -v videotestsrc pattern=snow ! video/x-raw,width=1280,height=720 ! autovideosinkcommand, but none with deepstream_test2_app. Is that normal?
• Hardware Platform (Jetson / GPU) GTX 1070 • DeepStream Version 5.0 • JetPack Version (valid for Jetson only) • TensorRT Version 7.0.0 • NVIDIA GPU Driver Version (valid for GPU only) 440.82
Now playing: ../../../../samples/streams/sample_1080p_h264.mp4
WARNING: ../nvdsinfer/nvdsinfer_func_utils.cpp:34 [TRT]: Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
0:00:00.903185280 3883 0x562f13377e90 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<secondary3-nvinference-engine> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1577> [UID = 4]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1 3x224x224
1 OUTPUT kFLOAT predictions/Softmax 6x1x1
0:00:00.903266378 3883 0x562f13377e90 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<secondary3-nvinference-engine> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1681> [UID = 4]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:00.904636550 3883 0x562f13377e90 INFO nvinfer gstnvinfer_impl.cpp:311:notifyLoadModelStatus:<secondary3-nvinference-engine> [UID 4]: Load new model:dstest2_sgie3_config.txt sucessfully
0:00:00.927882653 3883 0x562f13377e90 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1577> [UID = 3]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 20x1x1
0:00:00.927944209 3883 0x562f13377e90 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1681> [UID = 3]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:00.929050352 3883 0x562f13377e90 INFO nvinfer gstnvinfer_impl.cpp:311:notifyLoadModelStatus:<secondary2-nvinference-engine> [UID 3]: Load new model:dstest2_sgie2_config.txt sucessfully
0:00:00.943755703 3883 0x562f13377e90 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1577> [UID = 2]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 12x1x1
0:00:00.943828029 3883 0x562f13377e90 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1681> [UID = 2]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:00.944984879 3883 0x562f13377e90 INFO nvinfer gstnvinfer_impl.cpp:311:notifyLoadModelStatus:<secondary1-nvinference-engine> [UID 2]: Load new model:dstest2_sgie1_config.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
0:00:00.959572550 3883 0x562f13377e90 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1577> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:00.959659042 3883 0x562f13377e90 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1681> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:00.960277145 3883 0x562f13377e90 INFO nvinfer gstnvinfer_impl.cpp:311:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:dstest2_pgie_config.txt sucessfully
Running...
I just noticed that playing sample_720p.h264 rather than sample_1080p_h264.mp4 yields playback however.
Please noticed, test1 and test2 sample only accept h264 elementary stream, test3 sample accept any container type that gstreamer supported, and any codec can be used as input.
