Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: RTX 4060
- Driver Version: 535.183.01
Topic Description
Detailed Description
Expected result
When given a control value of 720 degrees, rotate twice
Actual result
After rotate to about 360 degrees, the error occurs.
PhysX error: PxArticulationJointReducedCoordinate::setDriveTarget() only supports target angle in range [-2Pi, 2Pi] for joints of type PxArticulationJointType::eREVOLUTE
Steps to Reproduce
- Set the ‘Lower Limit’ and ‘Upper Limit’ of the revolute joint to ‘Not Limited’.
- Create position profile [0, 1, 2, …, 360, 361, 362, …718, 719, 720].
- Set the joint position as the value of the position profile. Using “ArticulationAction” API
- Apply action using “apply_action” API
3-4 is repeated every physics step.
The value of the input joint position gradually increases. (0 → 720)
Error Messages
Additional Information
Additional Context
I want to control the joint to move more than once with position control. (infinite revolute)
Is it impossible to control more than one turn with position control method?
