software :
driver source code download http://www.mellanox.com/page/products_dyn?product_family=27 http://www.mellanox.com/page/products_dyn?product_family=27
with version 4.0.0
kernel : ubuntu linux-4.4.0-generic
hardware:
mainboard : MSI C236A
mlnx 0x6750 ethernet card
normally running is ok ,
but when i call pm-suspend --no-quirks or
equally echo -n “mem” >/sys/power/state
when it was waken up by keyboard ,the mlx4 0x6750 not running ok ,
i debug with this problem ,i find that the slice different is in the code to read MLX4_OWNER_BASE
static int mlx4_get_ownership(struct mlx4_dev *dev)
void __iomem *owner;
u32 ret;
if (pci_channel_offline(dev->persist->pdev)){
debug_info_mlx(" ");
return -EIO;
owner = ioremap(pci_resource_start(dev->persist->pdev, 0) +
MLX4_OWNER_BASE,
MLX4_OWNER_SIZE);
if (!owner) {
mlx4_err(dev, “Failed to obtain ownership bit\n”);
return -ENOMEM;
ret = readl(owner);
iounmap(owner);
debug_info_mlx(“ret %d”, ret);
return (int) !!ret;
on normal the last debug is ret 0
but when on the wakeup the insmod code is
16777216
always this code
i wonder how to reset the nic card to be read 0
thank you
