STACKTRACE
petrin-d@petrin-pc:~/NVIDIA_CUDA-10.1_Samples/bin/x86_64/linux/release$ strace ./deviceQuery
execve("./deviceQuery", ["./deviceQuery"], [/* 49 vars /]) = 0
brk(NULL) = 0x5d72a0f81000
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
mmap(NULL, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7b1cf2c29000
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
open("/usr/local/cuda-10.1/lib64/tls/x86_64/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/local/cuda-10.1/lib64/tls/x86_64", 0x7fff6561aa50) = -1 ENOENT (No such file or directory)
open("/usr/local/cuda-10.1/lib64/tls/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/local/cuda-10.1/lib64/tls", 0x7fff6561aa50) = -1 ENOENT (No such file or directory)
open("/usr/local/cuda-10.1/lib64/x86_64/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/local/cuda-10.1/lib64/x86_64", 0x7fff6561aa50) = -1 ENOENT (No such file or directory)
open("/usr/local/cuda-10.1/lib64/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/local/cuda-10.1/lib64", {st_mode=S_IFDIR|S_ISGID|0755, st_size=4096, …}) = 0
open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=115245, …}) = 0
mmap(NULL, 115245, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7b1cf2c0c000
close(3) = 0
open("/lib/x86_64-linux-gnu/librt.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, “\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\340 \0\0\0\0\0\0”…, 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=32333, …}) = 0
mmap(NULL, 2128832, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7b1cf2801000
mprotect(0x7b1cf2808000, 2093056, PROT_NONE) = 0
mmap(0x7b1cf2a07000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7b1cf2a07000
close(3) = 0
open("/usr/local/cuda-10.1/lib64/libpthread.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, “\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0Pa\0\0\0\0\0\0”…, 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=136026, …}) = 0
mmap(NULL, 2212936, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7b1cf25e4000
mprotect(0x7b1cf25fc000, 2093056, PROT_NONE) = 0
mmap(0x7b1cf27fb000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x17000) = 0x7b1cf27fb000
mmap(0x7b1cf27fd000, 13384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7b1cf27fd000
close(3) = 0
open("/usr/local/cuda-10.1/lib64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, “\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200\r\0\0\0\0\0\0”…, 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=15227, …}) = 0
mmap(NULL, 2109680, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7b1cf23e0000
mprotect(0x7b1cf23e3000, 2093056, PROT_NONE) = 0
mmap(0x7b1cf25e2000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7b1cf25e2000
close(3) = 0
open("/usr/local/cuda-10.1/lib64/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/x86_64-linux-gnu/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, “\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\340\267\10\0\0\0\0\0”…, 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1566756, …}) = 0
mmap(NULL, 3674720, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7b1cf205e000
mprotect(0x7b1cf21d0000, 2097152, PROT_NONE) = 0
mmap(0x7b1cf23d0000, 49152, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x172000) = 0x7b1cf23d0000
mmap(0x7b1cf23dc000, 12896, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7b1cf23dc000
close(3) = 0
open("/usr/local/cuda-10.1/lib64/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/libm.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, “\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200V\0\0\0\0\0\0”…, 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1063915, …}) = 0
mmap(NULL, 3158248, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7b1cf1d5a000
mprotect(0x7b1cf1e5d000, 2093056, PROT_NONE) = 0
mmap(0x7b1cf205c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x102000) = 0x7b1cf205c000
close(3) = 0
open("/usr/local/cuda-10.1/lib64/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\220\0\0\0\0\0\0"…, 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=93173, …}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7b1cf2c0a000
mmap(NULL, 2188336, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7b1cf1b43000
mprotect(0x7b1cf1b59000, 2093056, PROT_NONE) = 0
mmap(0x7b1cf1d58000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x15000) = 0x7b1cf1d58000
close(3) = 0
open("/usr/local/cuda-10.1/lib64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/x86_64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, “\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\4\2\0\0\0\0\0”…, 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1689947, …}) = 0
mmap(NULL, 3795296, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7b1cf17a4000
mprotect(0x7b1cf1939000, 2097152, PROT_NONE) = 0
mmap(0x7b1cf1b39000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x195000) = 0x7b1cf1b39000
mmap(0x7b1cf1b3f000, 14688, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7b1cf1b3f000
close(3) = 0
mmap(NULL, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7b1cf2c07000
arch_prctl(ARCH_SET_FS, 0x7b1cf2c079c0) = 0
mprotect(0x7b1cf1b39000, 16384, PROT_READ) = 0
mprotect(0x7b1cf1d58000, 4096, PROT_READ) = 0
mprotect(0x7b1cf205c000, 4096, PROT_READ) = 0
mprotect(0x7b1cf23d0000, 40960, PROT_READ) = 0
mprotect(0x7b1cf25e2000, 4096, PROT_READ) = 0
mprotect(0x7b1cf27fb000, 4096, PROT_READ) = 0
mprotect(0x7b1cf2a07000, 4096, PROT_READ) = 0
mprotect(0x5d729fa44000, 12288, PROT_READ) = 0
mprotect(0x7b1cf2c2c000, 4096, PROT_READ) = 0
munmap(0x7b1cf2c0c000, 115245) = 0
set_tid_address(0x7b1cf2c07c90) = 8465
set_robust_list(0x7b1cf2c07ca0, 24) = 0
rt_sigaction(SIGRTMIN, {sa_handler=0x7b1cf25e9bd0, sa_mask=, sa_flags=SA_RESTORER|SA_SIGINFO, sa_restorer=0x7b1cf25f50c0}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {sa_handler=0x7b1cf25e9c60, sa_mask=, sa_flags=SA_RESTORER|SA_RESTART|SA_SIGINFO, sa_restorer=0x7b1cf25f50c0}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM64_INFINITY}) = 0
brk(0x5d72a0fb3000) = 0x5d72a0fb3000
futex(0x5d729fa47ef8, FUTEX_WAKE_PRIVATE, 2147483647) = 0
futex(0x7b1cf23dd03c, FUTEX_WAKE_PRIVATE, 2147483647) = 0
futex(0x7b1cf23dd048, FUTEX_WAKE_PRIVATE, 2147483647) = 0
fstat(1, {st_mode=S_IFCHR|0600, st_rdev=makedev(136, 1), …}) = 0
write(1, “./deviceQuery Starting…\n\n”, 27./deviceQuery Starting…
) = 27
write(1, " CUDA Device Query (Runtime API)"…, 65 CUDA Device Query (Runtime API) version (CUDART static linking)
) = 65
write(1, “\n”, 1
) = 1
futex(0x7b1cf25e30a8, FUTEX_WAKE_PRIVATE, 2147483647) = 0
open("/usr/local/cuda-10.1/lib64/libcuda.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
close(3) = 0
open("/usr/lib/x86_64-linux-gnu/libcuda.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, “\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200\310\f\0\0\0\0\0”…, 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=16590656, …}) = 0
mmap(NULL, 18774664, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7b1cf05bc000
mprotect(0x7b1cf1475000, 2093056, PROT_NONE) = 0
mmap(0x7b1cf1674000, 1155072, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xeb8000) = 0x7b1cf1674000
mmap(0x7b1cf178e000, 88712, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7b1cf178e000
close(3) = 0
sched_get_priority_max(SCHED_RR) = 99
sched_get_priority_min(SCHED_RR) = 1
getpid() = 8465
open("/sys/devices/system/cpu/online", O_RDONLY|O_CLOEXEC) = 3
read(3, “0-3\n”, 8192) = 4
close(3) = 0
mmap(NULL, 135168, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7b1cf2be6000
sched_getaffinity(8465, 8, [0, 1, 2, 3]) = 8
munmap(0x7b1cf2be6000, 135168) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {tv_sec=2665, tv_nsec=720615153}) = 0
open("/proc/sys/vm/mmap_min_addr", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=0, …}) = 0
read(3, “65536\n”, 1024) = 6
close(3) = 0
getpid() = 8465
futex(0x7b1cf178f0a4, FUTEX_WAKE_PRIVATE, 2147483647) = 0
statfs("/dev/shm/", {f_type=TMPFS_MAGIC, f_bsize=4096, f_blocks=1013379, f_bfree=1004530, f_bavail=1004530, f_files=1013379, f_ffree=1013337, f_fsid={val=[0, 0]}, f_namelen=255, f_frsize=4096, f_flags=ST_VALID|ST_NOSUID|ST_NODEV}) = 0
futex(0x7b1cf2800330, FUTEX_WAKE_PRIVATE, 2147483647) = 0
open("/dev/shm/cuda_injection_path_shm", O_RDWR|O_NOFOLLOW|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/home/petrin-d/.nv/nvidia-application-profile-globals-rc", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/home/petrin-d/.nv/nvidia-application-profiles-rc", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/home/petrin-d/.nv/nvidia-application-profiles-rc.d", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/etc/nvidia/nvidia-application-profiles-rc", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/etc/nvidia/nvidia-application-profiles-rc.d/", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/share/nvidia/nvidia-application-profiles-440.31-rc", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0444, st_size=7184, …}) = 0
read(3, “# Application profiles for the N”…, 4096) = 4096
read(3, " “profile” : “IgnoreGLSLExte”…, 4096) = 3088
close(3) = 0
open("/usr/share/nvidia/nvidia-application-profiles-rc", O_RDONLY) = -1 ENOENT (No such file or directory)
getpid() = 8465
readlink("/proc/8465/exe", “/home/petrin-d/NVIDIA_CUDA-10.1_”…, 4095) = 76
getpid() = 8465
geteuid() = 1000
socket(AF_UNIX, SOCK_SEQPACKET|SOCK_CLOEXEC, 0) = 3
setsockopt(3, SOL_SOCKET, SO_PASSCRED, [1], 4) = 0
connect(3, {sa_family=AF_UNIX, sun_path="/tmp/nvidia-mps/control"}, 26) = -1 ENOENT (No such file or directory)
close(3) = 0
lstat("/proc", {st_mode=S_IFDIR|0555, st_size=0, …}) = 0
lstat("/proc/self", {st_mode=S_IFLNK|0777, st_size=0, …}) = 0
readlink("/proc/self", “8465”, 4095) = 4
lstat("/proc/8465", {st_mode=S_IFDIR|0555, st_size=0, …}) = 0
lstat("/proc/8465/exe", {st_mode=S_IFLNK|0777, st_size=0, …}) = 0
lstat("/home", {st_mode=S_IFDIR|0755, st_size=4096, …}) = 0
lstat("/home/petrin-d", {st_mode=S_IFDIR|0750, st_size=4096, …}) = 0
lstat("/home/petrin-d/NVIDIA_CUDA-10.1_Samples", {st_mode=S_IFDIR|0755, st_size=4096, …}) = 0
lstat("/home/petrin-d/NVIDIA_CUDA-10.1_Samples/bin", {st_mode=S_IFDIR|0755, st_size=4096, …}) = 0
lstat("/home/petrin-d/NVIDIA_CUDA-10.1_Samples/bin/x86_64", {st_mode=S_IFDIR|0755, st_size=4096, …}) = 0
lstat("/home/petrin-d/NVIDIA_CUDA-10.1_Samples/bin/x86_64/linux", {st_mode=S_IFDIR|0755, st_size=4096, …}) = 0
lstat("/home/petrin-d/NVIDIA_CUDA-10.1_Samples/bin/x86_64/linux/release", {st_mode=S_IFDIR|0755, st_size=4096, …}) = 0
lstat("/home/petrin-d/NVIDIA_CUDA-10.1_Samples/bin/x86_64/linux/release/deviceQuery", {st_mode=S_IFREG|0755, st_size=664352, …}) = 0
brk(0x5d72a0fde000) = 0x5d72a0fde000
open("/proc/modules", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0444, st_size=0, …}) = 0
read(3, “nls_utf8 16384 1 - Live 0x000000”…, 1024) = 1024
close(3) = 0
open("/proc/driver/nvidia/params", O_RDONLY) = 3
read(3, “Mobile: 4294967295\nResmanDebugLe”…, 1024) = 691
close(3) = 0
stat("/dev/nvidiactl", {st_mode=S_IFCHR|0666, st_rdev=makedev(195, 255), …}) = 0
open("/dev/nvidiactl", O_RDWR) = 3
fcntl(3, F_SETFD, FD_CLOEXEC) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0xd2, 0x48), 0x7fff6560f6b0) = 0
open("/sys/devices/system/memory/block_size_bytes", O_RDONLY) = 4
read(4, “8000000\n”, 99) = 8
close(4) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0xd6, 0x08), 0x7fff6560f6b0) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0xca, 0x04), 0x7b1cf17a2860) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0xc8, 0xa00), 0x7b1cf17a1e60) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2b, 0x20), 0x7fff6560f700) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f700) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x29, 0x10), 0x7fff6560f770) = 0
close(3) = 0
close(3) = 0
close(3) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0xd2, 0x48), 0x7fff6560fc40) = 0
close(4) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0xd6, 0x08), 0x7fff6560fc40) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2b, 0x20), 0x7fff6560fc90) = 0
open("/proc/self/status", O_RDONLY) = 4
fstat(4, {st_mode=S_IFREG|0444, st_size=0, …}) = 0
read(4, “Name:\tdeviceQuery\nUmask:\t0022\nSt”…, 1024) = 1024
read(4, “0000000,00000000,00000000,000000”…, 1024) = 340
close(4) = 0
open("/sys/devices/system/node", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 4
fstat(4, {st_mode=S_IFDIR|0755, st_size=0, …}) = 0
getdents(4, /* 10 entries /, 32768) = 312
open("/sys/devices/system/node/node0/cpumap", O_RDONLY) = 5
fstat(5, {st_mode=S_IFREG|0444, st_size=4096, …}) = 0
read(5, “f\n”, 4096) = 2
close(5) = 0
getdents(4, / 0 entries */, 32768) = 0
close(4) = 0
futex(0x7b1cf1792178, FUTEX_WAKE_PRIVATE, 2147483647) = 0
get_mempolicy([MPOL_DEFAULT], [000000000000000000, 000000000000000000, 000000000000000000, 000000000000000000, 000000000000000000, 000000000000000000, 000000000000000000, 000000000000000000, 000000000000000000, 000000000000000000, 000000000000000000, 000000000000000000, 000000000000000000, 000000000000000000, 000000000000000000, 000000000000000000], 1024, NULL, 0) = 0
open("/proc/modules", O_RDONLY) = 4
read(4, “nls_utf8 16384 1 - Live 0x000000”…, 1024) = 1024
close(4) = 0
open("/proc/devices", O_RDONLY) = 4
read(4, “Character devices:\n 1 mem\n 4 /”…, 1024) = 678
close(4) = 0
stat("/dev/nvidia-uvm", {st_mode=S_IFCHR|0666, st_rdev=makedev(238, 0), …}) = 0
stat("/dev/nvidia-uvm-tools", {st_mode=S_IFCHR|0666, st_rdev=makedev(238, 1), …}) = 0
open("/dev/nvidia-uvm", O_RDWR|O_CLOEXEC) = 4
fcntl(4, F_GETFD) = 0x1 (flags FD_CLOEXEC)
ioctl(4, _IOC(0, 0x00, 0x01, 0x3000), 0x7fff6560fd40) = 0
clock_gettime(CLOCK_MONOTONIC_RAW, {tv_sec=2665, tv_nsec=723370264}) = 0
ioctl(4, _IOC(0, 0x00, 0x27, 0x00), 0x7fff6560fd70) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f980) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f870) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f960) = 0
open("/proc/driver/nvidia/params", O_RDONLY) = 5
fstat(5, {st_mode=S_IFREG|0444, st_size=0, …}) = 0
read(5, “Mobile: 4294967295\nResmanDebugLe”…, 1024) = 691
close(5) = 0
stat("/dev/nvidia0", {st_mode=S_IFCHR|0666, st_rdev=makedev(195, 0), …}) = 0
open("/dev/nvidia0", O_RDWR) = 5
fcntl(5, F_SETFD, FD_CLOEXEC) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f520) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f390) = 0
open("/proc/driver/nvidia/params", O_RDONLY) = 6
fstat(6, {st_mode=S_IFREG|0444, st_size=0, …}) = 0
read(6, “Mobile: 4294967295\nResmanDebugLe”…, 1024) = 691
close(6) = 0
open("/dev/nvidia0", O_RDWR) = 6
fcntl(6, F_SETFD, FD_CLOEXEC) = 0
ioctl(6, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0xd7, 0x228), 0x7fff6560f2b0) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2b, 0x20), 0x7fff6560f570) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f490) = 0
open("/proc/driver/nvidia/params", O_RDONLY) = 7
fstat(7, {st_mode=S_IFREG|0444, st_size=0, …}) = 0
read(7, “Mobile: 4294967295\nResmanDebugLe”…, 1024) = 691
close(7) = 0
open("/dev/nvidia0", O_RDWR) = 7
fcntl(7, F_SETFD, FD_CLOEXEC) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2b, 0x20), 0x7fff6560f550) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f280) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f120) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f0b0) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560ee40) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f130) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f2b0) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f0d0) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f210) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f200) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560d9b0) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f260) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2b, 0x20), 0x7fff6560f300) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f2c0) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f270) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f300) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560f320) = 0
mmap(NULL, 100663296, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7b1cea5bc000
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560fb50) = 0
mmap(NULL, 172032, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7b1cf2bdd000
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x2a, 0x20), 0x7fff6560e300) = 0
sysinfo({uptime=2666, loads=[992, 4032, 5216], totalram=8301604864, freeram=6157479936, sharedram=75427840, bufferram=59367424, totalswap=8455712768, freeswap=8455712768, procs=390, totalhigh=0, freehigh=0, mem_unit=1}) = 0
uname({sysname=“Linux”, nodename=“petrin-pc”, …}) = 0
ioctl(4, _IOC(0, 0x00, 0x25, 0x00), 0x7fff6560fd20) = 0
ioctl(4, _IOC(0, 0x00, 0x37, 0x00), 0x7fff6560fd50) = 0
ioctl(4, _IOC(0, 0x00, 0x17, 0x00), 0x7fff6560fd80) = 0
ioctl(3, _IOC(_IOC_READ|_IOC_WRITE, 0x46, 0x4a, 0xc0), 0x7fff6560fba0) = 0
getrlimit(RLIMIT_AS, {rlim_cur=RLIM64_INFINITY, rlim_max=RLIM64_INFINITY}) = 0
open("/proc/self/maps", O_RDONLY) = 8
fstat(8, {st_mode=S_IFREG|0444, st_size=0, …}) = 0
read(8, “5d729f7d1000-5d729f844000 r-xp 0”…, 1024) = 1024
close(8) = 0
mmap(0x200000000, 4297064448, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x200000000
mmap(NULL, 536866816, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7b1cca5bd000
munmap(0x7b1cca5bd000, 94646272) = 0
munmap(0x7b1ce0000000, 173785088) = 0
getpid() = 8465
stat("/proc/8465/ns/pid", {st_mode=S_IFREG|0444, st_size=0, …}) = 0
socket(AF_UNIX, SOCK_SEQPACKET|SOCK_CLOEXEC, 0) = 8
unlink("") = ?
+++ killed by SIGKILL +++
