Does this kernel has any problem ? Like too many control statements,not simple etc ?
It crashes when the first ‘for’ loop iteration(ITERATION) is more than ~2000 on a GTX 280.
CHUNKS=256. If ITERATIONS is less than ~2000 it works perfectly as desired.
Any clues ? My intention is to do the same operation(as implemented in kernel) on different chunks of data -
Is character array properly supported on CUDA ? Or is it better to use 32 bit integer arrays ?
int ChunkNo = blockIdx.x * blockDim.x + threadIdx.x;
unsigned int TempCode,Length;
unsigned int Flag,OutChars;
unsigned int i,k,p,q;
unsigned char j;
unsigned char TempChar,Mask;if (ChunkNo < CHUNKS)
TempCode=0;
Length =0;
Flag=0;
q=0;
OutChars=0;
for(i=0;i<ITERATIONS;i++)
j=idata[ChunkNo * LENGTH + i];
Mask=0x80;
k=0;
while(k<8)
if(Flag)
TempChar=j&Mask;
if(TempChar==Mask)
TempCode=TempCode<<1;
TempCode=TempCode|0x00000001;
else
Length++;
Mask=Mask>>1;
k++;
else
while((q<MinCodeLength)&&(k<8))
TempChar=j&Mask;
if(TempChar==Mask)
else
Length++;
Mask=Mask>>1;
k++;
q++;
}if(q>=MinCodeLength) { Flag=1; for(p=0;p<TOTAL_SYMBOLS;p++) { if(TempCode == d_CodeWordArray[p] && Length == d_CodeLengthArray[p]) { TempCode=0; Length =0; odata[ChunkNo * LENGTH + OutChars] = p; OutChars++; Flag=0; q=0; break; } } } } } DChunkSizeArray[ChunkNo]=OutChars;
What operating system are you on? Is there a screen attached to the device? How long does the kernel take to execute?
You might just be running into the 5 sec runtime limit.
Its on a Windows 7. I am not sure what you meant screen attached to device. I am using a GTX 280 dedicated graphics card.
5 sec run time limit ? Is there something like that ? I want kernel to operate on a long 8 bit array.
The main problem with the code is that:
printf("Not enough indentation and readability\n");
abort(-1);
The runtime limit on Windows 7 is actually closer to 2 seconds. To change the delay or turn of the watchdog read [url=“http://www.microsoft.com/whdc/device/display/wddm_timeout.mspx”]http://www.microsoft.com/whdc/device/displ...dm_timeout.mspx[/url]
