trying to flash BoardID3636, getting above msg
sudo ./flash.sh -r -k jetson-tx2 mmcblk0p1
pls advise.
Please give more information so we know what’s happening; we don’t do telepathy.
- P3636 is the TX2 NX module, which is to be used with the Xavier NX DevKit, and flashed with
jetson-xavier-nx-devkit-tx2-nx, notjetson-tx2. - Please provide both the flashing log from the host and the serial console log from the device here.
- What’s the purpose of using
-r -kin the flashing command? Are you re-using the system image?
sudo ./flash.sh -r -k kernel-dtb jetson-tx2 mmcblk0p1
# L4T BSP Information:
# R32 , REVISION: 7.3
# Target Board Information:
# Name: jetson-tx2, Board Family: t186ref, SoC: Tegra 186,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
./tegraflash.py --chip 0x18 --applet "/home/user/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0069 ] Generating RCM messages
[ 0.0094 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/jay/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0105 ] RCM 0 is saved as rcm_0.rcm
[ 0.0118 ] RCM 1 is saved as rcm_1.rcm
[ 0.0118 ] List of rcm files are saved in rcm_list.xml
[ 0.0118 ]
[ 0.0119 ] Signing RCM messages
[ 0.0148 ] tegrasign_v3.py --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0149 ] Assuming zero filled SBK key
[ 0.0351 ] Copying signature to RCM mesages
[ 0.0382 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0407 ]
[ 0.0408 ] Boot Rom communication
[ 0.0438 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0453 ] RCM version 0X180001
[ 0.0724 ] Boot Rom communication completed
[ 1.0787 ]
[ 2.0842 ] tegrarcm_v2 --isapplet
[ 2.0868 ] Applet version 01.00.0000
[ 2.1180 ]
[ 2.1218 ] Retrieving EEPROM data
[ 2.1220 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/jay/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 2.1239 ] Applet version 01.00.0000
[ 2.2183 ] Saved platform info in /home/jay/nvidia/nvidia_sdk/JetPack_4.6.3_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 2.2913 ]
Board ID(3636) version(301) sku(0001) revision(D.0)
not supported by U-Boot
Have you checked this?
Do you know what carrier board you are using?
pls indicate where do v find the carrier board details
P3636 is the TX2 NX module, which is to be used with the Xavier NX DevKit, and flashed with jetson-xavier-nx-devkit-tx2-nx, not jetson-tx2.
—not checked, want to make sure the params r correct
If you don’t know what you are doing, then just take a picture of your hardware setup.
Clearly it’s incorrect.
it is the Xavier NX/TX2 NX and also confirmed with the .conf file in the flash folder.
the process is gone thru.
thanks for the kind assistance.
