Notable to Install Nvidia Drivers New or old versions in my Gpu GTX 1070 of OS UBUNTU 16.04
After installation i stuck at login loop and i am not able to find the issue.Could you please any one help me.
Below is my Xorg file for more details
[ 17.564]
X.Org X Server 1.19.5
Release Date: 2017-10-12
[ 17.564] X Protocol Version 11, Revision 0
[ 17.564] Build Operating System: Linux 4.4.0-101-generic x86_64 Ubuntu
[ 17.564] Current Operating System: Linux algorithmica-S2600CWR 4.13.0-37-generic #42~16.04.1-Ubuntu SMP Wed Mar 7 16:03:28 UTC 2018 x86_64
[ 17.564] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.13.0-37-generic root=UUID=f0d7fdc6-75c7-4bed-aa24-a9957e0177b6 ro quiet splash vt.handoff=7
[ 17.564] Build Date: 24 November 2017 09:44:25AM
[ 17.564] xorg-server 2:1.19.5-0ubuntu2~16.04.1 (For technical support please see http://www.ubuntu.com/support)
[ 17.564] Current version of pixman: 0.33.6
[ 17.564] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 17.564] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 17.564] (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Mar 16 10:56:19 2018
[ 17.579] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 17.579] (==) No Layout section. Using the first Screen section.
[ 17.579] (==) No screen section available. Using defaults.
[ 17.579] (
) |–>Screen “Default Screen Section” (0)
[ 17.579] (**) | |–>Monitor “”
[ 17.579] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 17.579] (==) Automatically adding devices
[ 17.579] (==) Automatically enabling devices
[ 17.579] (==) Automatically adding GPU devices
[ 17.579] (==) Automatically binding GPU devices
[ 17.579] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 17.579] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 17.579] Entry deleted from font path.
[ 17.579] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 17.579] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 17.579] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 17.579] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 17.579] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 17.579] (==) ModulePath set to “/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules”
[ 17.579] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 17.579] (II) Loader magic: 0x55f858feae00
[ 17.579] (II) Module ABI versions:
[ 17.579] X.Org ANSI C Emulation: 0.4
[ 17.579] X.Org Video Driver: 23.0
[ 17.579] X.Org XInput driver : 24.1
[ 17.579] X.Org Server Extension : 10.0
[ 17.580] (++) using VT number 7
[ 17.580] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 17.581] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 17.581] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 17.584] (–) PCI: (0:3:0:0) 10de:1b81:19da:2424 rev 161, Mem @ 0xa3000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00002000/128, BIOS @ 0x???/524288
[ 17.584] (–) PCI:*(0:6:0:0) 102b:0522:8086:0103 rev 5, Mem @ 0xa2000000/16777216, 0xa5000000/16384, 0xa4800000/8388608, BIOS @ 0x???/131072
[ 17.584] (II) LoadModule: “glx”
[ 17.606] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 17.644] (II) Module glx: vendor=“X.Org Foundation”
[ 17.644] compiled for 1.19.5, module version = 1.0.0
[ 17.644] ABI class: X.Org Server Extension, version 10.0
[ 17.644] (==) Matched mga as autoconfigured driver 0
[ 17.644] (==) Matched nvidia as autoconfigured driver 1
[ 17.644] (==) Matched nouveau as autoconfigured driver 2
[ 17.644] (==) Matched mga as autoconfigured driver 3
[ 17.644] (==) Matched modesetting as autoconfigured driver 4
[ 17.644] (==) Matched fbdev as autoconfigured driver 5
[ 17.644] (==) Matched vesa as autoconfigured driver 6
[ 17.644] (==) Assigned the driver to the xf86ConfigLayout
[ 17.644] (II) LoadModule: “mga”
[ 17.644] (WW) Warning, couldn’t open module mga
[ 17.644] (II) UnloadModule: “mga”
[ 17.644] (II) Unloading mga
[ 17.644] (EE) Failed to load module “mga” (module does not exist, 0)
[ 17.644] (II) LoadModule: “nvidia”
[ 17.645] (WW) Warning, couldn’t open module nvidia
[ 17.645] (II) UnloadModule: “nvidia”
[ 17.645] (II) Unloading nvidia
[ 17.645] (EE) Failed to load module “nvidia” (module does not exist, 0)
[ 17.645] (II) LoadModule: “nouveau”
[ 17.645] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 17.648] (II) Module nouveau: vendor=“X.Org Foundation”
[ 17.648] compiled for 1.19.5, module version = 1.0.15
[ 17.648] Module class: X.Org Video Driver
[ 17.648] ABI class: X.Org Video Driver, version 23.0
[ 17.648] (II) LoadModule: “modesetting”
[ 17.648] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 17.649] (II) Module modesetting: vendor=“X.Org Foundation”
[ 17.649] compiled for 1.19.5, module version = 1.19.5
[ 17.649] Module class: X.Org Video Driver
[ 17.649] ABI class: X.Org Video Driver, version 23.0
[ 17.649] (II) LoadModule: “fbdev”
[ 17.649] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 17.649] (II) Module fbdev: vendor=“X.Org Foundation”
[ 17.649] compiled for 1.19.3, module version = 0.4.4
[ 17.649] (II) LoadModule: “vesa”
[ 17.649] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 17.649] (II) Module vesa: vendor=“X.Org Foundation”
[ 17.649] compiled for 1.19.3, module version = 2.3.4
[ 17.649] (==) Matched mga as autoconfigured driver 0
[ 17.649] (==) Matched nvidia as autoconfigured driver 1
[ 17.649] (==) Matched nouveau as autoconfigured driver 2
[ 17.649] (==) Matched mga as autoconfigured driver 3
[ 17.649] (==) Matched modesetting as autoconfigured driver 4
[ 17.649] (==) Matched fbdev as autoconfigured driver 5
[ 17.649] (==) Matched vesa as autoconfigured driver 6
[ 17.649] (==) Assigned the driver to the xf86ConfigLayout
[ 17.649] (II) LoadModule: “mga”
[ 17.649] (WW) Warning, couldn’t open module mga
[ 17.649] (II) UnloadModule: “mga”
[ 17.649] (II) Unloading mga
[ 17.649] (EE) Failed to load module “mga” (module does not exist, 0)
[ 17.649] (II) LoadModule: “nvidia”
[ 17.649] (WW) Warning, couldn’t open module nvidia
[ 17.649] (II) UnloadModule: “nvidia”
[ 17.649] (II) Unloading nvidia
[ 17.649] (EE) Failed to load module “nvidia” (module does not exist, 0)
[ 17.649] (II) LoadModule: “nouveau”
[ 17.649] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 17.649] (II) Module nouveau: vendor=“X.Org Foundation”
[ 17.649] compiled for 1.19.5, module version = 1.0.15
[ 17.649] (II) UnloadModule: “nouveau”
[ 17.649] (II) Unloading nouveau
[ 17.649] (II) Failed to load module “nouveau” (already loaded, 0)
[ 17.649] (II) LoadModule: “modesetting”
[ 17.649] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 17.649] (II) UnloadModule: “modesetting”
[ 17.650] (II) Unloading modesetting
[ 17.650] (II) Failed to load module “modesetting” (already loaded, 0)
[ 17.650] (II) LoadModule: “fbdev”
[ 17.650] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 17.650] (II) Module fbdev: vendor=“X.Org Foundation”
[ 17.650] compiled for 1.19.3, module version = 0.4.4
[ 17.650] Module class: X.Org Video Driver
[ 17.650] ABI class: X.Org Video Driver, version 23.0
[ 17.650] (II) UnloadModule: “fbdev”
[ 17.650] (II) Unloading fbdev
[ 17.650] (II) Failed to load module “fbdev” (already loaded, 0)
[ 17.650] (II) LoadModule: “vesa”
[ 17.650] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 17.650] (II) Module vesa: vendor=“X.Org Foundation”
[ 17.650] compiled for 1.19.3, module version = 2.3.4
[ 17.650] (II) UnloadModule: “vesa”
[ 17.650] (II) Unloading vesa
[ 17.650] (II) Failed to load module “vesa” (already loaded, 0)
[ 17.650] (II) NOUVEAU driver Date: Fri Apr 21 14:41:17 2017 -0400
[ 17.650] (II) NOUVEAU driver for NVIDIA chipset families :
[ 17.650] RIVA TNT (NV04)
[ 17.650] RIVA TNT2 (NV05)
[ 17.650] GeForce 256 (NV10)
[ 17.650] GeForce 2 (NV11, NV15)
[ 17.650] GeForce 4MX (NV17, NV18)
[ 17.650] GeForce 3 (NV20)
[ 17.650] GeForce 4Ti (NV25, NV28)
[ 17.650] GeForce FX (NV3x)
[ 17.650] GeForce 6 (NV4x)
[ 17.650] GeForce 7 (G7x)
[ 17.650] GeForce 8 (G8x)
[ 17.650] GeForce GTX 200 (NVA0)
[ 17.650] GeForce GTX 400 (NVC0)
[ 17.650] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 17.650] (II) FBDEV: driver for framebuffer: fbdev
[ 17.650] (II) VESA: driver for VESA chipsets: vesa
[ 17.650] (II) [drm] nouveau interface version: 1.3.1
[ 17.650] (II) modeset(0): using drv /dev/dri/card0
[ 17.650] (WW) Falling back to old probe method for fbdev
[ 17.650] (II) Loading sub module “fbdevhw”
[ 17.650] (II) LoadModule: “fbdevhw”
[ 17.650] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 17.650] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 17.650] compiled for 1.19.5, module version = 0.0.2
[ 17.650] (WW) Falling back to old probe method for vesa
[ 17.650] (II) modeset(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 17.651] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 17.651] (==) modeset(0): RGB weight 888
[ 17.651] (==) modeset(0): Default visual is TrueColor
[ 17.651] (II) Loading sub module “glamoregl”
[ 17.651] (II) LoadModule: “glamoregl”
[ 17.651] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 17.673] (II) Module glamoregl: vendor=“X.Org Foundation”
[ 17.673] compiled for 1.19.5, module version = 1.0.0
[ 17.673] ABI class: X.Org ANSI C Emulation, version 0.4
[ 17.673] (II) glamor: OpenGL accelerated X.org driver based.
[ 18.011] (II) glamor: EGL version 1.4 (DRI2):
[ 18.011] EGL_MESA_drm_image required.
[ 18.011] (EE) modeset(0): glamor initialization failed
[ 18.011] (II) modeset(0): ShadowFB: preferred YES, enabled YES
[ 18.011] (II) modeset(0): Double-buffered shadow updates: on
[ 18.013] (II) modeset(0): Output VGA-1 has no monitor section
[ 18.014] (II) modeset(0): EDID for output VGA-1
[ 18.014] (II) modeset(0): Printing probed modes for output VGA-1
[ 18.014] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 18.014] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 18.014] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 18.014] (II) modeset(0): Modeline "848x480"x60.0 33.75 848 864 976 1088 480 486 494 517 +hsync +vsync (31.0 kHz e)
[ 18.014] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 18.014] (II) modeset(0): Output VGA-1 connected
[ 18.014] (II) modeset(0): Using exact sizes for initial modes
[ 18.014] (II) modeset(0): Output VGA-1 using initial mode 1024x768 +0+0
[ 18.014] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 18.014] (==) modeset(0): DPI set to (96, 96)
[ 18.014] (II) Loading sub module “fb”
[ 18.014] (II) LoadModule: “fb”
[ 18.014] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 18.014] (II) Module fb: vendor=“X.Org Foundation”
[ 18.014] compiled for 1.19.5, module version = 1.0.0
[ 18.014] ABI class: X.Org ANSI C Emulation, version 0.4
[ 18.014] (II) Loading sub module “shadow”
[ 18.014] (II) LoadModule: “shadow”
[ 18.015] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 18.015] (II) Module shadow: vendor=“X.Org Foundation”
[ 18.015] compiled for 1.19.5, module version = 1.1.0
[ 18.015] ABI class: X.Org ANSI C Emulation, version 0.4
[ 18.015] (II) Loading sub module “dri2”
[ 18.015] (II) LoadModule: “dri2”
[ 18.015] (II) Module “dri2” already built-in
[ 18.015] (–) NOUVEAU(G0): Chipset: “NVIDIA NV134”
[ 18.015] (==) NOUVEAU(G0): Depth 24, (–) framebuffer bpp 32
[ 18.015] (==) NOUVEAU(G0): RGB weight 888
[ 18.015] (==) NOUVEAU(G0): Default visual is TrueColor
[ 18.015] (==) NOUVEAU(G0): Using HW cursor
[ 18.015] (==) NOUVEAU(G0): Allowed maximum DRI level 2.
[ 18.015] (==) NOUVEAU(G0): GLX sync to VBlank enabled.
[ 18.015] (==) NOUVEAU(G0): Page flipping enabled
[ 18.015] (==) NOUVEAU(G0): Swap limit set to 1 [Max allowed 2]
[ 18.015] (==) NOUVEAU(G0): Page flipping synced to vblank by kernel.
[ 18.015] (II) NOUVEAU(G0): Initializing outputs …
[ 18.016] (II) NOUVEAU(G0): Output DVI-D-1-1 has no monitor section
[ 18.080] (II) NOUVEAU(G0): Output DP-1-1 has no monitor section
[ 18.144] (II) NOUVEAU(G0): Output DP-1-2 has no monitor section
[ 18.145] (II) NOUVEAU(G0): Output HDMI-1-1 has no monitor section
[ 18.208] (II) NOUVEAU(G0): Output DP-1-3 has no monitor section
[ 18.208] (II) NOUVEAU(G0): 5 crtcs needed for screen.
[ 18.228] (II) NOUVEAU(G0): Allocated crtc nr. 0 to this screen.
[ 18.228] (II) NOUVEAU(G0): Allocated crtc nr. 1 to this screen.
[ 18.228] (II) NOUVEAU(G0): Allocated crtc nr. 2 to this screen.
[ 18.228] (II) NOUVEAU(G0): Allocated crtc nr. 3 to this screen.
[ 18.229] (II) NOUVEAU(G0): EDID for output DVI-D-1-1
[ 18.292] (II) NOUVEAU(G0): EDID for output DP-1-1
[ 18.356] (II) NOUVEAU(G0): EDID for output DP-1-2
[ 18.357] (II) NOUVEAU(G0): EDID for output HDMI-1-1
[ 18.420] (II) NOUVEAU(G0): EDID for output DP-1-3
[ 18.420] (==) NOUVEAU(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 18.420] (–) NOUVEAU(G0): Virtual size is 1024x768 (pitch 0)
[ 18.420] () NOUVEAU(G0): Mode “1024x768”: 63.5 MHz (scaled from 0.0 MHz), 47.8 kHz, 59.9 Hz
[ 18.420] (II) NOUVEAU(G0): Modeline "1024x768"x59.9 63.50 1024 1072 1176 1328 768 771 775 798 -hsync +vsync (47.8 kHz)
[ 18.420] (==) NOUVEAU(G0): DPI set to (96, 96)
[ 18.420] (II) Loading sub module “fb”
[ 18.420] (II) LoadModule: “fb”
[ 18.420] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 18.420] (II) Module fb: vendor=“X.Org Foundation”
[ 18.420] compiled for 1.19.5, module version = 1.0.0
[ 18.420] ABI class: X.Org ANSI C Emulation, version 0.4
[ 18.420] (II) Loading sub module “shadowfb”
[ 18.420] (II) LoadModule: “shadowfb”
[ 18.420] (II) Loading /usr/lib/xorg/modules/libshadowfb.so
[ 18.470] (II) Module shadowfb: vendor=“X.Org Foundation”
[ 18.470] compiled for 1.19.5, module version = 1.0.0
[ 18.470] ABI class: X.Org ANSI C Emulation, version 0.4
[ 18.470] (II) UnloadModule: “fbdev”
[ 18.470] (II) Unloading fbdev
[ 18.470] (II) UnloadSubModule: “fbdevhw”
[ 18.470] (II) Unloading fbdevhw
[ 18.470] (II) UnloadModule: “vesa”
[ 18.470] (II) Unloading vesa
[ 18.470] (==) Depth 24 pixmap format is 32 bpp
[ 18.508] (II) NOUVEAU(G0): Channel setup complete.
[ 18.531] (II) NOUVEAU(G0): [COPY] async initialised.
[ 18.559] (II) NOUVEAU(G0): Hardware support for Present enabled
[ 18.559] (II) NOUVEAU(G0): [DRI2] Setup complete
[ 18.559] (II) NOUVEAU(G0): [DRI2] DRI driver: nouveau
[ 18.559] (II) NOUVEAU(G0): [DRI2] VDPAU driver: nouveau
[ 18.559] (II) Loading sub module “exa”
[ 18.559] (II) LoadModule: “exa”
[ 18.559] (II) Loading /usr/lib/xorg/modules/libexa.so
[ 18.566] (II) Module exa: vendor=“X.Org Foundation”
[ 18.566] compiled for 1.19.5, module version = 2.6.0
[ 18.566] ABI class: X.Org Video Driver, version 23.0
[ 18.566] (II) EXA(256): Driver allocated offscreen pixmaps
[ 18.566] (II) EXA(256): Driver registered support for the following operations:
[ 18.566] (II) Solid
[ 18.566] (II) Copy
[ 18.566] (II) Composite (RENDER acceleration)
[ 18.567] (II) UploadToScreen
[ 18.567] (II) DownloadFromScreen
[ 18.567] (==) NOUVEAU(G0): Backing store enabled
[ 18.567] (==) NOUVEAU(G0): Silken mouse enabled
[ 18.567] (II) NOUVEAU(G0): [XvMC] Associated with Nouveau GeForce 8/9 Textured Video.
[ 18.567] (EE) NOUVEAU(G0): [XvMC] Failed to initialize extension.
[ 18.567] (==) NOUVEAU(G0): DPMS enabled
[ 18.567] (II) NOUVEAU(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 18.567] (==) modeset(0): Backing store enabled
[ 18.567] (==) modeset(0): Silken mouse enabled
[ 18.567] (II) modeset(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 18.567] (==) modeset(0): DPMS enabled
[ 18.567] (–) RandR disabled
[ 18.576] (II) SELinux: Disabled on system
[ 18.576] (II) AIGLX: Screen 0 is not DRI2 capable
[ 18.576] (EE) AIGLX: reverting to software rendering
[ 18.675] (II) IGLX: enabled GLX_MESA_copy_sub_buffer
[ 18.675] (II) IGLX: Loaded and initialized swrast
[ 18.675] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 18.675] (II) NOUVEAU(G0): NVEnterVT is called.
[ 18.676] (II) modeset(0): Damage tracking initialized
[ 18.676] (II) modeset(0): Setting screen physical size to 270 x 203
[ 18.713] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 18.713] (
) Power Button: Applying InputClass “evdev keyboard catchall”
[ 18.713] (II) LoadModule: “evdev”
[ 18.713] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 18.740] (II) Module evdev: vendor=“X.Org Foundation”
[ 18.740] compiled for 1.19.3, module version = 2.10.5
[ 18.740] Module class: X.Org XInput Driver
[ 18.740] ABI class: X.Org XInput driver, version 24.1
[ 18.740] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 18.740] () Power Button: always reports core events
[ 18.740] (
) evdev: Power Button: Device: “/dev/input/event0”
[ 18.740] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 18.740] (–) evdev: Power Button: Found keys
[ 18.740] (II) evdev: Power Button: Configuring as keyboard
[ 18.740] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input0/event0”
[ 18.740] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 18.740] (
) Option “xkb_rules” “evdev”
[ 18.740] () Option “xkb_model” “pc105”
[ 18.740] (
) Option “xkb_layout” “us”
[ 18.741] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event6)
[ 18.741] (II) No input driver specified, ignoring this device.
[ 18.741] (II) This device may have been added with another device file.
[ 18.741] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event7)
[ 18.741] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event8)
[ 18.741] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event9)
[ 18.742] (II) config/udev: Adding input device American Megatrends Inc. Virtual Keyboard and Mouse (/dev/input/event4)
[ 18.742] () American Megatrends Inc. Virtual Keyboard and Mouse: Applying InputClass “evdev keyboard catchall”
[ 18.742] (II) Using input driver ‘evdev’ for ‘American Megatrends Inc. Virtual Keyboard and Mouse’
[ 18.742] (
) American Megatrends Inc. Virtual Keyboard and Mouse: always reports core events
[ 18.742] () evdev: American Megatrends Inc. Virtual Keyboard and Mouse: Device: “/dev/input/event4”
[ 18.742] (–) evdev: American Megatrends Inc. Virtual Keyboard and Mouse: Vendor 0x46b Product 0xff10
[ 18.742] (–) evdev: American Megatrends Inc. Virtual Keyboard and Mouse: Found keys
[ 18.742] (II) evdev: American Megatrends Inc. Virtual Keyboard and Mouse: Configuring as keyboard
[ 18.742] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-14/3-14:1.0/0003:046B:FF10.0004/input/input4/event4”
[ 18.742] (II) XINPUT: Adding extended input device “American Megatrends Inc. Virtual Keyboard and Mouse” (type: KEYBOARD, id 7)
[ 18.742] () Option “xkb_rules” “evdev”
[ 18.742] (
[ 18.742] () Option “xkb_layout” “us”
[ 18.742] (II) config/udev: Adding input device American Megatrends Inc. Virtual Keyboard and Mouse (/dev/input/event5)
[ 18.742] (
) American Megatrends Inc. Virtual Keyboard and Mouse: Applying InputClass “evdev pointer catchall”
[ 18.742] () American Megatrends Inc. Virtual Keyboard and Mouse: always reports core events
[ 18.742] (
) evdev: American Megatrends Inc. Virtual Keyboard and Mouse: Device: “/dev/input/event5”
[ 18.742] (–) evdev: American Megatrends Inc. Virtual Keyboard and Mouse: Found 3 mouse buttons
[ 18.742] (–) evdev: American Megatrends Inc. Virtual Keyboard and Mouse: Found scroll wheel(s)
[ 18.742] (–) evdev: American Megatrends Inc. Virtual Keyboard and Mouse: Found relative axes
[ 18.742] (–) evdev: American Megatrends Inc. Virtual Keyboard and Mouse: Found absolute axes
[ 18.742] (–) evdev: American Megatrends Inc. Virtual Keyboard and Mouse: Found x and y absolute axes
[ 18.742] (–) evdev: American Megatrends Inc. Virtual Keyboard and Mouse: Found absolute touchscreen
[ 18.742] (II) evdev: American Megatrends Inc. Virtual Keyboard and Mouse: Configuring as touchscreen
[ 18.742] (II) evdev: American Megatrends Inc. Virtual Keyboard and Mouse: Adding scrollwheel support
[ 18.742] () evdev: American Megatrends Inc. Virtual Keyboard and Mouse: YAxisMapping: buttons 4 and 5
[ 18.742] (
) evdev: American Megatrends Inc. Virtual Keyboard and Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 18.742] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-14/3-14:1.1/0003:046B:FF10.0005/input/input5/event5”
[ 18.742] (II) XINPUT: Adding extended input device “American Megatrends Inc. Virtual Keyboard and Mouse” (type: TOUCHSCREEN, id 8)
[ 18.742] (WW) evdev: American Megatrends Inc. Virtual Keyboard and Mouse: touchpads, tablets and touchscreens ignore relative axes.
[ 18.742] (II) evdev: American Megatrends Inc. Virtual Keyboard and Mouse: initialized for absolute axes.
[ 18.743] (
) American Megatrends Inc. Virtual Keyboard and Mouse: (accel) keeping acceleration scheme 1
[ 18.743] () American Megatrends Inc. Virtual Keyboard and Mouse: (accel) acceleration profile 0
[ 18.743] (
) American Megatrends Inc. Virtual Keyboard and Mouse: (accel) acceleration factor: 2.000
[ 18.743] () American Megatrends Inc. Virtual Keyboard and Mouse: (accel) acceleration threshold: 4
[ 18.743] (II) config/udev: Adding input device American Megatrends Inc. Virtual Keyboard and Mouse (/dev/input/js0)
[ 18.743] (II) No input driver specified, ignoring this device.
[ 18.743] (II) This device may have been added with another device file.
[ 18.743] (II) config/udev: Adding input device American Megatrends Inc. Virtual Keyboard and Mouse (/dev/input/mouse1)
[ 18.743] (II) config/udev: Adding input device SIGMACHIP USB Keyboard (/dev/input/event1)
[ 18.744] (
) SIGMACHIP USB Keyboard: Applying InputClass “evdev keyboard catchall”
[ 18.744] (II) Using input driver ‘evdev’ for ‘SIGMACHIP USB Keyboard’
[ 18.744] () SIGMACHIP USB Keyboard: always reports core events
[ 18.744] (
) evdev: SIGMACHIP USB Keyboard: Device: “/dev/input/event1”
[ 18.744] (–) evdev: SIGMACHIP USB Keyboard: Vendor 0x1c4f Product 0x2
[ 18.744] (–) evdev: SIGMACHIP USB Keyboard: Found keys
[ 18.744] (II) evdev: SIGMACHIP USB Keyboard: Configuring as keyboard
[ 18.744] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.0/0003:1C4F:0002.0001/input/input1/event1”
[ 18.744] (II) XINPUT: Adding extended input device “SIGMACHIP USB Keyboard” (type: KEYBOARD, id 9)
[ 18.744] (
[ 18.744] () Option “xkb_model” “pc105”
[ 18.744] (
[ 18.744] (II) config/udev: Adding input device SIGMACHIP USB Keyboard (/dev/input/event2)
[ 18.744] () SIGMACHIP USB Keyboard: Applying InputClass “evdev keyboard catchall”
[ 18.744] (
[ 18.744] () evdev: SIGMACHIP USB Keyboard: Device: “/dev/input/event2”
[ 18.744] (–) evdev: SIGMACHIP USB Keyboard: Found 1 mouse buttons
[ 18.744] (–) evdev: SIGMACHIP USB Keyboard: Found scroll wheel(s)
[ 18.744] (–) evdev: SIGMACHIP USB Keyboard: Found relative axes
[ 18.744] (II) evdev: SIGMACHIP USB Keyboard: Forcing relative x/y axes to exist.
[ 18.744] (–) evdev: SIGMACHIP USB Keyboard: Found absolute axes
[ 18.744] (II) evdev: SIGMACHIP USB Keyboard: Forcing absolute x/y axes to exist.
[ 18.744] (II) evdev: SIGMACHIP USB Keyboard: Configuring as mouse
[ 18.744] (II) evdev: SIGMACHIP USB Keyboard: Adding scrollwheel support
[ 18.744] (
) evdev: SIGMACHIP USB Keyboard: YAxisMapping: buttons 4 and 5
[ 18.744] () evdev: SIGMACHIP USB Keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 18.744] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.1/0003:1C4F:0002.0002/input/input2/event2”
[ 18.744] (II) XINPUT: Adding extended input device “SIGMACHIP USB Keyboard” (type: KEYBOARD, id 10)
[ 18.744] () Option “xkb_rules” “evdev”
[ 18.744] (
[ 18.744] () Option “xkb_layout” “us”
[ 18.744] (II) evdev: SIGMACHIP USB Keyboard: initialized for relative axes.
[ 18.744] (WW) evdev: SIGMACHIP USB Keyboard: ignoring absolute axes.
[ 18.744] (
) SIGMACHIP USB Keyboard: (accel) keeping acceleration scheme 1
[ 18.744] () SIGMACHIP USB Keyboard: (accel) acceleration profile 0
[ 18.744] (
) SIGMACHIP USB Keyboard: (accel) acceleration factor: 2.000
[ 18.744] () SIGMACHIP USB Keyboard: (accel) acceleration threshold: 4
[ 18.745] (II) config/udev: Adding input device YSPRINGTECH USB OPTICAL MOUSE (/dev/input/event3)
[ 18.745] (
) YSPRINGTECH USB OPTICAL MOUSE: Applying InputClass “evdev pointer catchall”
[ 18.745] (II) Using input driver ‘evdev’ for ‘YSPRINGTECH USB OPTICAL MOUSE’
[ 18.745] () YSPRINGTECH USB OPTICAL MOUSE: always reports core events
[ 18.745] (
) evdev: YSPRINGTECH USB OPTICAL MOUSE: Device: “/dev/input/event3”
[ 18.804] (–) evdev: YSPRINGTECH USB OPTICAL MOUSE: Vendor 0x10c4 Product 0x8108
[ 18.804] (–) evdev: YSPRINGTECH USB OPTICAL MOUSE: Found 3 mouse buttons
[ 18.804] (–) evdev: YSPRINGTECH USB OPTICAL MOUSE: Found scroll wheel(s)
[ 18.804] (–) evdev: YSPRINGTECH USB OPTICAL MOUSE: Found relative axes
[ 18.804] (–) evdev: YSPRINGTECH USB OPTICAL MOUSE: Found x and y relative axes
[ 18.804] (II) evdev: YSPRINGTECH USB OPTICAL MOUSE: Configuring as mouse
[ 18.804] (II) evdev: YSPRINGTECH USB OPTICAL MOUSE: Adding scrollwheel support
[ 18.804] () evdev: YSPRINGTECH USB OPTICAL MOUSE: YAxisMapping: buttons 4 and 5
[ 18.804] (
) evdev: YSPRINGTECH USB OPTICAL MOUSE: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 18.804] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0/0003:10C4:8108.0003/input/input3/event3”
[ 18.804] (II) XINPUT: Adding extended input device “YSPRINGTECH USB OPTICAL MOUSE” (type: MOUSE, id 11)
[ 18.804] (II) evdev: YSPRINGTECH USB OPTICAL MOUSE: initialized for relative axes.
[ 18.804] (
) YSPRINGTECH USB OPTICAL MOUSE: (accel) keeping acceleration scheme 1
[ 18.804] () YSPRINGTECH USB OPTICAL MOUSE: (accel) acceleration profile 0
[ 18.804] (
) YSPRINGTECH USB OPTICAL MOUSE: (accel) acceleration factor: 2.000
[ 18.804] (**) YSPRINGTECH USB OPTICAL MOUSE: (accel) acceleration threshold: 4
[ 18.804] (II) config/udev: Adding input device YSPRINGTECH USB OPTICAL MOUSE (/dev/input/mouse0)
[ 18.804] (II) No input driver specified, ignoring this device.
[ 18.804] (II) This device may have been added with another device file.
[ 19.408] (II) modeset(0): Disabling kernel dirty updates, not required.
You can attach files to existing posts. When hovering the mouse over it, a paperclip icon appears.
How did you install the driver, using ubuntu packages or the .run installer?
Please run nvidia-bug-report.sh as root and attach the resulting tar.gz file to your post.
