Nothing appears in the media entity
Yes, if your use tegracamera framework. Otherwise reference to tc358840.c to report the sensor properties.
Let’s review that part first.
Currently, when the camera_common_find_pixelfmt function is commented out and then executed, a kernel panic occurs in the tegracam_set_privdata function. Can you give me some advice on this?
I would suggest using reference driver to modify and remove unnecessary function to avoid lost data cause problem.
I found out what causes it.
This occurs because tc_dev->s_data is a NULL value.
Can you tell me where to put the data for tc_dev->s_data?
Please check the …/kernel/nvidia/include/media/camera_common.h
Hi Shane,
After re-checking the code, I modified the necessary parts and confirmed that the driver was updated.
However, not only is nothing registered in “media-ctl -p”, but there is also no video driver installed in /dev.
Please follow the reference driver to implement those necessary properties and functions.
I’m not sure what’s missing now. I set it according to the imx185 reference, but the device is not registered. Any help on this would be greatly appreciated.
tegra-capture-vi {
		num-channels = <1>;
		ports {
			#address-cells = <1>;
			#size-cells = <0>;
			port@0 {
				reg = <0>;
				max96724_vi_in0: endpoint {
					port-index = <0>;
					bus-width = <4>;
					remote-endpoint = <&max96724_csi_out0>;
	host1x@13e00000 {
	// host1x{
	// 	status = "okay";
		// vi@15700000 {
		// // vi {
		// 	num-channels = <1>;
		// 	ports {
		// 		#address-cells = <1>;
		// 		#size-cells = <0>;
		// 		port@0{
		// 			reg = <0>;
		// 			max96724_vi_in0: endpoint {
		// 				port-index = <2>;
		// 				bus-width = <4>;
		// 				remote-endpoint = <&max96724_csi_out0>;
		nvcsi@15a00000 {
			num-channels = <1>;
			#size-cells = <0>;
			channel@0 {
				reg = <0>;
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						max96724_csi_in0: endpoint@0 {
							status = "okay";
							port-index = <0>;
							bus-width = <4>;
							remote-endpoint = <&max96724_out0>;
					port@1 {
						reg = <1>;
						max96724_csi_out0: endpoint@1 {
							remote-endpoint = <&max96724_vi_in0>;
	i2c@c250000 {
		max96724@27 {
			compatible = "nvidia,max96724";
			status = "okay";
			devnode = "video0";
			reg = <0x27>;
			physical_w = "3.674";
			physical_h = "2.738";
			reset-gpios = <&tegra_main_gpio CAM0_RST_L GPIO_ACTIVE_HIGH>;
			sensor_model ="max96724";
			/* Define any required hw resources needed by driver */
			/* ie. clocks, io pins, power sources */
			 post_crop_frame_drop = "0";
			/* Convert Gain to unit of dB (decibel) befor passing to kernel driver */
			use_decibel_gain = "true";
			/* if true, delay gain setting by one frame to be in sync with exposure */
			delayed_gain = "true";
			/* enable CID_SENSOR_MODE_ID for sensor modes selection */
			use_sensor_mode_id = "true";
			/* WAR to prevent banding by reducing analog gain. Bug 2229902 */
			limit_analog_gain = "true";
			mode0 {
				discontinuous_clk = "no";
				readout_orientation = [30 00];
				exposure_factor = "1000000";
				mclk_khz = "24000";
				phy_mode = "DPHY";
				default_gain = [30 00];
				dpcm_enable = "false";
				max_gain_val = "480";
				framerate_factor = "1000000";
				min_hdr_ratio = [31 00];
				num_lanes = [34 00];
				max_framerate = "30000000";
				min_gain_val = [30 00];
				pixel_phase = "rggb";
				mode_type = "bayer";
				pix_clk_hz = "74250000";
				step_gain_val = [33 00];
				cil_settletime = [30 00];
				default_exp_time = "33334";
				active_h = "1080";
				max_exp_time = "660000";
				dynamic_pixel_bit_depth = "12";
				active_w = "1920";
				min_exp_time = "30";
				max_hdr_ratio = [31 00];
				min_framerate = "1500000";
				mclk_multiplier = [32 00];
				step_exp_time = [31 00];
				default_framerate = "30000000";
				csi_pixel_bit_depth = "12";
				step_framerate = [31 00];
				inherent_gain = [31 00];
				embedded_metadata_height = [31 00];
				line_length = "2200";
				gain_factor = "10";
			ports {
				#size-cells = <0>;
				port@0{
					reg = <0>;
					max96724_out0: endpoint{
						port-index = <0>;
						bus-width = <4>;
						remote-endpoint = <&max96724_csi_in0>;
tegra-camera-platform {
		compatible = "nvidia, tegra-camera-platform";
		num_csi_lanes = <4>;
		max_lane_speed = <3000000>;
		min_bits_per_pixel = <10>;
		vi_peak_byte_per_pixel = <2>;
		vi_bw_margin_pct = <25>;
		isp_peak_byte_per_pixel = <5>;
		isp_bw_margin_pct = <25>;
		modules {
			module0 {
				badge = "max96724_rear";
				position = "rear";
				orientation = "1";
				drivernode0 {
					pcl_id = "v4l2_sensor";
					devname = "max96724 70-0027";
					proc-device-tree = "/proc/device-tree/i2c@c250000/max96724@27";
When I register the driver in demsg, it appears as shown below. Is this a problem?
You can check your driver if this error does matter with in the probe() function.
There is no possibility of an error in the probe driver.
I worked based on the reference, but I don’t know why it doesn’t appear in the video device and media-ctl.
I confirmed that the entity was captured in media-ctl by applying the overlay dtbo file for dts.
Thank you for your support
