Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
We are using a camera simulator to feed data into the hardware. When using “nvsipl_camera -c “TN_IMXXXX_IMXXXX_ISXXXX” -m ‘0x0000 0x0000 0x0001’ --showfps -0 -1 -R” to open raw stream, everything works just as fine.
However when we enable NITO ISP file, and try to convert raw camera stream into YUV420, it gives us “NOTIF_ERROR_ISP_PROCESSING_FAILURE”.
My question is what could possibly result “NOTIF_ERROR_ISP_PROCESSING_FAILURE” ? What things will NITO file check in my simulated camera raw stream and return this error?
Dear @steven.song,
Could you share the used camera module?
I am using a camera simulator to feed the camera data. Therefore the error probably is on my side, where the data I fed is not matching the actual camera output. I want to know which part of data (maybe Embedded data line) will cause this “NOTIF_ERROR_ISP_PROCESSING_FAILURE”, therefore I can change the data to avoid this error. Anyway the actual camera module I am simulating is IMX728.
Dear @steven.song,
Are you using DRIVE AGX platform or other platform?
Unfortunately, Issues with custom camera modules can not be supported via DRIVE forum. The NOTIF_ERROR_ISP_PROCESSING_FAILURE indicates bad input parameter. Could you double check the input parameters to APIs in the conversion.
Hi @SivaRamaKrishnaNV ,
Yes, I am using DRIVE AGX platform. When I connect a real IMX728 camera sensor and run the same command, everything runs without issue. As mentioned above, when I switched the real IMX728 sensor to a camera sensor simulator hardware, it will give me the “NOTIF_ERROR_ISP_PROCESSING_FAILURE” error. Therefore I want to get some hints on whether the error is caused by the camera data I simulated (e.g. maybe this command will check the value from the first line “embedded data” of every camera frames) or this error is irrelevant.
