NotImplementedError: Could not run 'torchvision::nms' with arguments from the 'CUDA' backend. This could be because the operator doesn't exist for thi
NotImplementedError: Could not run ‘torchvision::nms’ with arguments from the ‘CUDA’ backend. This could be because the operator doesn’t exist for this backend, or was omitted during the selective/custom build process (if using custom build). If you are a Facebook employee using PyTorch on mobile, please visit Internal Login for possible resolutions. ‘torchvision::nms’ is only available for these backends: [CPU, Meta, QuantizedCPU, BackendSelect, Python, FuncTorchDynamicLayerBackMode, Functionalize, Named, Conjugate, Negative, ZeroTensor, ADInplaceOrView, AutogradOther, AutogradCPU, AutogradCUDA, AutogradXLA, AutogradMPS, AutogradXPU, AutogradHPU, AutogradLazy, AutogradMeta, Tracer, AutocastCPU, AutocastCUDA, FuncTorchBatched, BatchedNestedTensor, FuncTorchVmapMode, Batched, VmapMode, FuncTorchGradWrapper, PythonTLSSnapshot, FuncTorchDynamicLayerFrontMode, PreDispatch, PythonDispatcher].
CPU: registered at C:\actions-runner_work\vision\vision\pytorch\vision\torchvision\csrc\ops\cpu\nms_kernel.cpp:112 [kernel]
Meta: registered at /dev/null:440 [kernel]
QuantizedCPU: registered at C:\actions-runner_work\vision\vision\pytorch\vision\torchvision\csrc\ops\quantized\cpu\qnms_kernel.cpp:124 [kernel]
BackendSelect: fallthrough registered at …\aten\src\ATen\core\BackendSelectFallbackKernel.cpp:3 [backend fallback]
Python: registered at …\aten\src\ATen\core\PythonFallbackKernel.cpp:154 [backend fallback]
FuncTorchDynamicLayerBackMode: registered at …\aten\src\ATen\functorch\DynamicLayer.cpp:498 [backend fallback]
Functionalize: registered at …\aten\src\ATen\FunctionalizeFallbackKernel.cpp:324 [backend fallback]
Named: registered at …\aten\src\ATen\core\NamedRegistrations.cpp:7 [backend fallback]
Conjugate: registered at …\aten\src\ATen\ConjugateFallback.cpp:17 [backend fallback]
Negative: registered at …\aten\src\ATen\native\NegateFallback.cpp:19 [backend fallback]
ZeroTensor: registered at …\aten\src\ATen\ZeroTensorFallback.cpp:86 [backend fallback]
ADInplaceOrView: fallthrough registered at …\aten\src\ATen\core\VariableFallbackKernel.cpp:86 [backend fallback]
AutogradOther: registered at …\aten\src\ATen\core\VariableFallbackKernel.cpp:53 [backend fallback]
AutogradCPU: registered at …\aten\src\ATen\core\VariableFallbackKernel.cpp:57 [backend fallback]
AutogradCUDA: registered at …\aten\src\ATen\core\VariableFallbackKernel.cpp:65 [backend fallback]
AutogradXLA: registered at …\aten\src\ATen\core\VariableFallbackKernel.cpp:69 [backend fallback]
AutogradMPS: registered at …\aten\src\ATen\core\VariableFallbackKernel.cpp:77 [backend fallback]
AutogradXPU: registered at …\aten\src\ATen\core\VariableFallbackKernel.cpp:61 [backend fallback]
AutogradHPU: registered at …\aten\src\ATen\core\VariableFallbackKernel.cpp:90 [backend fallback]
AutogradLazy: registered at …\aten\src\ATen\core\VariableFallbackKernel.cpp:73 [backend fallback]
AutogradMeta: registered at …\aten\src\ATen\core\VariableFallbackKernel.cpp:81 [backend fallback]
Tracer: registered at …\torch\csrc\autograd\TraceTypeManual.cpp:297 [backend fallback]
AutocastCPU: registered at C:\actions-runner_work\vision\vision\pytorch\vision\torchvision\csrc\ops\autocast\nms_kernel.cpp:34 [kernel]
AutocastCUDA: registered at C:\actions-runner_work\vision\vision\pytorch\vision\torchvision\csrc\ops\autocast\nms_kernel.cpp:27 [kernel]
FuncTorchBatched: registered at …\aten\src\ATen\functorch\LegacyBatchingRegistrations.cpp:720 [backend fallback]
BatchedNestedTensor: registered at …\aten\src\ATen\functorch\LegacyBatchingRegistrations.cpp:746 [backend fallback]
FuncTorchVmapMode: fallthrough registered at …\aten\src\ATen\functorch\VmapModeRegistrations.cpp:28 [backend fallback]
Batched: registered at …\aten\src\ATen\LegacyBatchingRegistrations.cpp:1075 [backend fallback]
VmapMode: fallthrough registered at …\aten\src\ATen\VmapModeRegistrations.cpp:33 [backend fallback]
FuncTorchGradWrapper: registered at …\aten\src\ATen\functorch\TensorWrapper.cpp:203 [backend fallback]
PythonTLSSnapshot: registered at …\aten\src\ATen\core\PythonFallbackKernel.cpp:162 [backend fallback]
FuncTorchDynamicLayerFrontMode: registered at …\aten\src\ATen\functorch\DynamicLayer.cpp:494 [backend fallback]
PreDispatch: registered at …\aten\src\ATen\core\PythonFallbackKernel.cpp:166 [backend fallback]
PythonDispatcher: registered at …\aten\src\ATen\core\PythonFallbackKernel.cpp:158 [backend fallback]
Encountered this error while running a model. It was running fine few days back but suddenly got this error
This is a torch question. I don’t think you will find much help here. You may get better help on a torch forum, such as discuss.pytorch.org There are NVIDIA experts that patrol that forum.
