Now with R38.2.1 my Thor still freezes and does not accept any input from keyboard or mouse for 2 to 3 seconds. I will keep typing and after a delay of 2 to 3 seconds what I just typed will appear. If I attempt to up scroll in Firefox nothing will happen for 2 to 3 seconds and then it will unfreeze and move up. If I touch the keyboard up arrow three to four times; after the browser unfreezes it will launch to the top of the webpage. Typing this short paragraph took an additional 10 seconds due to the repeated timeout/freeze of
the Thor.
The freeze occurs about 7 times a minute. It is a significant problem.
When ssh into Thor this freezing does not occur.
from syslog:
2025-09-18T17:10:30.393290-07:00 chithor gnome-session[2811]: gnome-session-binary[2811]: GnomeDesktop-WARNING: Could not create transient scope for PID 2825: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
2025-09-18T17:10:30.393331-07:00 chithor gnome-session-binary[2811]: GnomeDesktop-WARNING: Could not create transient scope for PID 2825: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
It occurs when I am locally logged on to the Thor in the gui. At first I was only attaching to Thor via ssh and there were no problems. A week ago I attached local keyboard, mouse, displayport display and logged on to the gui. I encounter the problem when in gui.
I spoke too soon. Still getting input delays in Firefox. and still, but reduced, amount of delays in a terminal.
Iāve run nvstart-weston.sh on Orin and it cleanly implmented Weston for that logon session.
I ran it earlier today on Thor and it ruined the display and locked the computer. Had to reset power to Thor to get a respond
hi team, just to add more folks experiencing same symptoms and errors. Tried even wihout any monitor/mouse/keyboard and issue still remains (less but still).
Immediately after the first boot. 2 hours ago I re-flashed the thor from the usb drive installation media. When thor did oem setup it immediately started freezing stuttering pausing for a couple seconds about 9 times a minute. The first time I flashed from sdkmanager.
Nothing was running beyond system processes and terminal at that time.
jetson_clocks does not improve it.
After that I did apt update / apt install nvidia-jetpack nvidia-jetpack-dev when I rebooted it showed the nvidia boot screen then there was not graphics or prompt or any activity indicating that thor was live. I can ssh into it and that works fine no freezing.
As someone previously noted, running following in a terminal stops the freezing.
nvidia-smi dmon
I re-flashed my Thor again this morning with sdkmanager r38.2.1. Iāve attached some files that might be helpful. They were acquired either at first boot of my fully flashed Thor or shortly thereafter. Nothing additional had been installed other than nano and python3-pip. No browser at that time.
Just enabled WIFI for the first time. I still have a momentary freeze but the duration is significantly diminished. If I turn off wifi the longer duration freezing returns.
but now my dmesg is flooded with following every second:
Subsequent to running ānvidia-smi dmonā and enabling wifi, Thor has a little lessened number of stutters and with a shortened time period. Tried to do video of webpage stutters and just tried again. When I start the video recording that is another process that lessens the number and severity/time of stutters. I just tried again and got the same results. Closed recording application and now am back to prior more significant pause/stutter.
Hereās a short video showing the cursor stopping blinking. It is the best I can get now. If needed Iāll flash Thor again to get a better representation of what happens.
xpcs_lane_bring_up dmesg every second only started after enabling wifi yesterday. And is still occurring.
