NPP unresolved external symbol issues
I am running Windows 10 Pro 64-bit and Visual Studio 2015 with CUDA SDK Toolkit 9.1 installed properly. I can open all Sample Projects, build them, and then successfully execute them.
However, when I try to complete any simple NPP program using any number of the NPP Geometry Transforms, at:
https://docs.nvidia.com/cuda/npp/index.html
I get unresolved external symbol errors in linking, such as the following:
Error LNK2019 unresolved external symbol nppiFilter_8u_C1R referenced in function
Error LNK2019 unresolved external symbol nppiMirror_8u_C1R referenced in function
Error LNK2019 unresolved external symbol nppiRotate_8u_C1R referenced in function
I have this document, as well, and the declarations in this PDF match the web site (above)
https://www.clear.rice.edu/comp422/resources/cuda/pdf/NPP_Library.pdf
I can also open successive includes: npp.h, nppi.h, nppi_geometry_transforms.h – and the declarations are there. For example:
NppStatus
nppiRotate_8u_C1R(const Npp8u * pSrc, NppiSize oSrcSize, int nSrcStep, NppiRect oSrcROI,
Npp8u * pDst, int nDstStep, NppiRect oDstROI,
double nAngle, double nShiftX, double nShiftY, int eInterpolation);
NppStatus
nppiMirror_8u_C1R(const Npp8u * pSrc, int nSrcStep,
NppiSize oROI, NppiAxis flip);
I have (even) gone to the extremes of commenting out all code in a sample, jpegNPP for instance (which successfully compiles and executes correctly) and entered in my code and these unresolved externals appear.
In order to save some time, consider a simple example. I have used the following code from StackOverflow:
Forget (for now) that the code referenced (at Stack Overflow) might not produce a correct result, none of the simple code examples I have will (even) build because of the link errors.
Does anyone know how to fix these errors ?
You need to link against all the cuda npp libraries that you are using. you may need to link against:
libnppc
libnppial
libnppicc
libnppicom
libnppidei
libnppif
libnppig
libnppim
libnppist
libnppisu
libnppitc
libnpps
depending on which functions you are using.
If you’re not sure how to add a library to VS linker, this roughly outlines the steps:
https://stackoverflow.com/questions/13570285/how-to-link-library-e-g-cublas-cusparse-for-cuda-on-windows/13588857#13588857
Thank you for your help. However, since I placed my code in a working CUDA sample (jpegNPP), and simply commented out the existing (shipped) code, these libraries are already included (it seems) because they were inherited from some previous project.
This includes: nppisu.lib, nppicom.lib, nppig.lib, nppc.lib, cudart_static.lib, kernel32.lib, user32.lib, gdi32.lib, winspool.lib, comdlg32.lib, advapi32.lib, shell32.lib, ole32.lib, oleaut32.lib, uuid.lib, odbc32.lib, and odbccp32.lib. Beyond that, freeimage.lib is included in the Additional Dependencies field.
I get these errors in VS 2015:
Error LNK2019 unresolved external symbol nppiFilter_8u_C1R referenced in function “void __cdecl test_nppiFilter(void)” (?test_nppiFilter@@YAXXZ) jpegNPP C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.1\7_CUDALibraries\jpegNPP\jpegNPP.obj 1
Error LNK2019 unresolved external symbol main referenced in function “int __cdecl invoke_main(void)” (?invoke_main@@YAHXZ) jpegNPP C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.1\7_CUDALibraries\jpegNPP\LIBCMTD.lib(exe_main.obj) 1
Error LNK1120 2 unresolved externals jpegNPP C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.1\bin\win64\Debug\jpegNPP.exe 1
Note: Although I am sure you noticed, the ones at the end of each error indicate Line #1 in the code, which
is the #include <npp.h> directive
That is only 4 of the libraries I listed:
Those libraries were apparently sufficient for the npp functions used by the jpegNPP project. They are apparently not sufficient for the npp functions you are using.
Let’s take one example:
That function is provided by the nppif library. Your project does not link against that library (and presumably, neither does the jpegNPP project) so you’re getting that undefined reference error.
I suggest you follow my advice. Add the nppif library to the list, like so:
…, nppif.lib, nppisu.lib, nppicom.lib, nppig.lib, nppc.lib, …
and see if that particular unresolved symbol error goes away.
Well, that worked. Thank you. I am quite certain that I tried that previously. Perhaps, a clean before the rebuild fixed things, and perhaps a reboot (which I did for Windows updates) fixed things. Once I returned to your advice, not only did the sample from Stack Overflow work, but my other examples work.
Do you know the proper method for copying a CUDA Samples project to a new project so that all of the Project Properties get copied to the new project ?
Is there a template for a new CUDA project that serves this same purpose ?
