The hosted CUDA-docs MCP endpoint connects and authenticates fine, but every single tool call fails with an HTTP 500 originating from an internal service.
Endpoint
https://api.copilot.nsight.ngc.nvidia.com/mcp/cuda-docs
Registered with Claude Code:
claude mcp add --scope user --transport http nvidia-cuda-docs
What works
- OAuth completes: “Authentication successful. Connected to nvidia-cuda-docs”
- claude mcp list → nvidia-cuda-docs: … (HTTP) - ✔ Connected
- GET https://api.copilot.nsight.ngc.nvidia.com/ → 404 (expected)
- GET …/mcp/cuda-docs → 405 Method Not Allowed (expected for a POST-only MCP endpoint)
- DNS + TLS + connect in ~0.7 s
What fails
Every search_cuda_docs call:
Error calling tool ‘search_cuda_docs’: HTTP error occurred:
Server error ‘500 Internal Server Error’ for url
‘http://cudarag.bodhi-tree.svc.cluster.local:8000/retrieve?skip_tool_call_planning=true’
I tried six queries over ~15 minutes, from two-word keyword searches (shared memory bank conflicts, CUDA programming guide memory coalescing) up to the long descriptive form the tool description recommends. All returned the identical 500. A retrieval service that fails the same way on a two-word query points at the backend being unhealthy rather than anything query-specific.
Since the transport layer, auth and routing are all healthy, this looks like the Bodhi Tree RAG service behind the gateway being down or misconfigured.
Secondary issue: the error body exposes an internal Kubernetes service URL (cudarag.bodhi-tree.svc.cluster.local:8000) to clients. Probably worth masking that in the gateway’s error handling regardless of the root cause.
Environment: Claude Code, HTTP transport, user scope. Linux x86_64.
