Nsight Eclipse nvcc not found in Path Error
I’m trying to create from scratch a “Hello World” nvidia Nsight Eclipse project on my Host machine but having problems with the identity of the nvcc compiler.
I’ve followed the Installation instructions in the CUDA Toolkit v10.0.130 documentation. At the command prompt, I can type the following command and receive information about the driver so it appears to be linked properly.
:~$ nvcc -V
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Mon _Mar_11_22:07:30_CDT_2019
Cuda compilation tools, release 10.0, V10.0.326
When I start Nsight (Version: 10.0) from the command line, the following file errors occur but Nsight opens.
:~$ nsight
OpenJDK 64-Bit Server VM Warning: ignoring option MaxPermSize=256m; support was removed in 8.0
CompilerOracle:exlude java/lang/reflect/Array.newInstance
### Excluding compile: static java.lang.reflect.Array::newInstance
Managed Build system manifest file error: Duplicate identifier nvcc.linker for element type Tool.
Managed Build system manifest file error: Duplicate identifier nvcc.linker.option.linkgl for element type Option.
Managed Build system manifest file error: Duplicate identifier nvcc.archiver for element type Tool.
<A few more “Duplicate identifier” messages appear. All having a problem with nvcc>
I’ve verified that I have one version of the Cuda driver installed. (/usr/local/cuda-10.0)
I’ve created 2 projects in Nsight Eclipse(A CUDA project and a basic C Project). When I try to build the projects, the following Error message occurs.
Program “usr/local/cuda-10.0/binnvcc” not found in PATH
What am I missing?
The information below was pulled from the .metadata/.log file.
[code]!SESSION 2020-03-05 09:31:19.066 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_242
java.vendor=Private Build
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.ui 4 4 2020-03-05 09:31:22.571
!MESSAGE Conflicting handlers for com.nvidia.nsight.debug.command.attach: {com.nvidia.cuda.ide.debug.handlers.AttachCommandHandler} vs {com.nvidia.cuda.debug.ui.launch.AttachCommandHandler}
!ENTRY org.eclipse.ui 4 4 2020-03-05 09:31:22.613
!MESSAGE Conflicting handlers for org.eclipse.ui.edit.delete: {com.nvidia.cuda.ide.debug.handlers.TogglePinnedStateHandler} vs {com.nvidia.cuda.debug.ui.util.TogglePinnedStateHandler}
!MESSAGE Conflicting handlers for com.nvidia.cuda.ide.debug.commands.breakOnLaunch: {com.nvidia.cuda.ide.debug.handlers.BreakOnHandlerLaunch} vs {com.nvidia.cuda.debug.ui.controls.BreakOnHandlerLaunch}
!ENTRY org.eclipse.jface 2 0 2020-03-05 09:31:23.673
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2020-03-05 09:31:23.673
!MESSAGE A conflict occurred for CTRL+SHIFT+T:
Binding(CTRL+SHIFT+T,
ParameterizedCommand(Command(org.eclipse.cdt.ui.navigate.opentype,Open Element,
Open an element in an Editor,
Category(org.eclipse.cdt.ui.category.source,C/C++ Source,C/C++ Source Actions,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@44d7e24,
,true),null),
com.nvidia.cuda.ide,
org.eclipse.ui.contexts.window,system)
,true),null),
!MESSAGE A conflict occurred for CTRL+SHIFT+F11:
Binding(CTRL+SHIFT+F11,
ParameterizedCommand(Command(com.nvidia.nsight.debug.command.attach,Attach…,
Attach to a running application,
Category(com.nvidia.nsight.debug.category.running,Start Debug Session,Commands for starting debug sessions,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@26c8b296,
,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,gtk,system)
,true),null),
!MESSAGE A conflict occurred for CTRL+SHIFT+H:
Binding(CTRL+SHIFT+H,
ParameterizedCommand(Command(org.eclipse.cdt.ui.navigate.open.type.in.hierarchy,Open Type in Hierarchy,
Open a type in the type hierarchy view,
Category(org.eclipse.ui.category.navigate,Navigate,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@1d289d3f,
,true),null),
,true),null),
!ENTRY org.eclipse.ui 4 4 2020-03-05 09:31:26.656
!ENTRY org.eclipse.egit.ui 2 0 2020-03-05 09:31:27.483
!MESSAGE Warning: EGit couldn’t detect the installation path “gitPrefix” of native Git. Hence EGit can’t respect system level
Git settings which might be configured in ${gitPrefix}/etc/gitconfig under the native Git installation directory.
The most important of these settings is core.autocrlf. Git for Windows by default sets this parameter to true in
this system level configuration. The Git installation location can be configured on the
Team > Git > Configuration preference page’s ‘System Settings’ tab.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!ENTRY org.eclipse.ui 4 4 2020-03-05 09:31:56.701
!ENTRY org.eclipse.core.variables 4 120 2020-03-05 09:36:05.699
!MESSAGE Dynamic variable extension from bundle ‘com.nvidia.cuda.toolchain’ overrides existing extension variable ‘cuda_tk_bin’ from bundle ‘com.nvidia.cuda.ide.build’
!ENTRY org.eclipse.core.variables 4 120 2020-03-05 09:36:05.700
!MESSAGE Dynamic variable extension from bundle ‘com.nvidia.cuda.toolchain’ overrides existing extension variable ‘cuda_samples_dir’ from bundle ‘com.nvidia.cuda.ide.build’
!MESSAGE Dynamic variable extension from bundle ‘com.nvidia.cuda.toolchain’ overrides existing extension variable ‘cuda_samples_common_lib_dir’ from bundle ‘com.nvidia.cuda.ide.build’
!ENTRY org.eclipse.cdt.core 4 0 2020-03-05 09:36:05.864
!MESSAGE Error: Cannot run program “/usr/local/cuda-10.0/binnvcc”: Unknown reason
!STACK 0
java.io.IOException: Cannot run program “/usr/local/cuda-10.0/binnvcc”: Unknown reason
at org.eclipse.cdt.utils.spawner.Spawner.exec(Spawner.java:349)
at org.eclipse.cdt.utils.spawner.Spawner.(Spawner.java:91)
at org.eclipse.cdt.utils.spawner.ProcessFactory.exec(ProcessFactory.java:91)
at org.eclipse.cdt.core.CommandLauncher.execute(CommandLauncher.java:194)
at org.eclipse.cdt.internal.core.BuildRunnerHelper.build(BuildRunnerHelper.java:263)
at org.eclipse.cdt.make.internal.core.scannerconfig2.DefaultRunSIProvider.invokeProvider(DefaultRunSIProvider.java:144)
at org.eclipse.cdt.build.internal.core.scannerconfig.jobs.CfgSCJobsUtil$1.run(CfgSCJobsUtil.java:94)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.core.runtime.Platform.run(Platform.java:867)
at org.eclipse.cdt.build.internal.core.scannerconfig.jobs.CfgSCJobsUtil.getProviderScannerInfo(CfgSCJobsUtil.java:105)
at org.eclipse.cdt.build.core.scannerconfig.ScannerConfigBuilder.build(ScannerConfigBuilder.java:206)
at org.eclipse.cdt.build.internal.core.scannerconfig.CfgDiscoveredPathManager.loadPathInfo(CfgDiscoveredPathManager.java:298)
at org.eclipse.cdt.build.internal.core.scannerconfig.CfgDiscoveredPathManager.getDiscoveredInfo(CfgDiscoveredPathManager.java:177)
at org.eclipse.cdt.managedbuilder.internal.dataprovider.ProfileInfoProvider.getEntryValues(ProfileInfoProvider.java:65)
at org.eclipse.cdt.managedbuilder.internal.dataprovider.BuildEntryStorage.getDiscoveredEntries(BuildEntryStorage.java:200)
at org.eclipse.cdt.managedbuilder.internal.dataprovider.BuildEntryStorage.putEntriesToLevel(BuildEntryStorage.java:190)
at org.eclipse.cdt.core.settings.model.util.AbstractEntryStorage.initCache(AbstractEntryStorage.java:71)
at org.eclipse.cdt.core.settings.model.util.AbstractEntryStorage.getEntries(AbstractEntryStorage.java:34)
at org.eclipse.cdt.managedbuilder.internal.dataprovider.BuildLanguageData.getEntries(BuildLanguageData.java:161)
at org.eclipse.cdt.core.settings.model.extension.impl.CDefaultLanguageData.getEntriesToCopy(CDefaultLanguageData.java:101)
at org.eclipse.cdt.core.settings.model.extension.impl.CDefaultLanguageData.createStore(CDefaultLanguageData.java:92)
at org.eclipse.cdt.core.settings.model.extension.impl.CDefaultLanguageData.copySettingsFrom(CDefaultLanguageData.java:85)
at org.eclipse.cdt.internal.core.settings.model.CLanguageSettingCache.copySettingsFrom(CLanguageSettingCache.java:47)
at org.eclipse.cdt.internal.core.settings.model.CLanguageSettingCache.(CLanguageSettingCache.java:36)
at org.eclipse.cdt.internal.core.settings.model.CFolderDescriptionCache.copyLanguageData(CFolderDescriptionCache.java:79)
at org.eclipse.cdt.core.settings.model.extension.impl.CDefaultFolderData.copyDataFrom(CDefaultFolderData.java:56)
at org.eclipse.cdt.internal.core.settings.model.CFolderDescriptionCache.(CFolderDescriptionCache.java:38)
at org.eclipse.cdt.internal.core.settings.model.CConfigurationDescriptionCache.copyFolderData(CConfigurationDescriptionCache.java:235)
at org.eclipse.cdt.core.settings.model.extension.impl.CDefaultConfigurationData.copySettingsFrom(CDefaultConfigurationData.java:113)
at org.eclipse.cdt.internal.core.settings.model.CConfigurationDescriptionCache.loadData(CConfigurationDescriptionCache.java:150)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescription.loadDatas(CProjectDescription.java:196)
at org.eclipse.cdt.internal.core.settings.model.xml.XmlProjectDescriptionStorage.loadProjectDescription(XmlProjectDescriptionStorage.java:500)
at org.eclipse.cdt.internal.core.settings.model.xml.XmlProjectDescriptionStorage.getProjectDescription(XmlProjectDescriptionStorage.java:237)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescriptionInternal(CProjectDescriptionManager.java:436)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:418)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:412)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:405)
at org.eclipse.cdt.internal.core.model.CProject.computeSourceRoots(CProject.java:585)
at org.eclipse.cdt.internal.core.model.CProject.computeChildren(CProject.java:606)
at org.eclipse.cdt.internal.core.model.CProject.buildStructure(CProject.java:570)
at org.eclipse.cdt.internal.core.model.Openable.generateInfos(Openable.java:273)
at org.eclipse.cdt.internal.core.model.CElement.openWhenClosed(CElement.java:427)
at org.eclipse.cdt.internal.core.model.CElement.getElementInfo(CElement.java:305)
at org.eclipse.cdt.internal.core.model.CElement.getElementInfo(CElement.java:295)
at org.eclipse.cdt.internal.core.model.Parent.getChildren(Parent.java:55)
at org.eclipse.cdt.internal.core.model.CProject.getSourceRoots(CProject.java:468)
at org.eclipse.cdt.internal.core.model.CModelManager.create(CModelManager.java:338)
at org.eclipse.cdt.internal.core.model.CModelManager.create(CModelManager.java:266)
at org.eclipse.cdt.internal.core.model.DeltaProcessor.createElement(DeltaProcessor.java:89)
at org.eclipse.cdt.internal.core.model.DeltaProcessor.traverseDelta(DeltaProcessor.java:460)
at org.eclipse.cdt.internal.core.model.DeltaProcessor.traverseDelta(DeltaProcessor.java:478)
at org.eclipse.cdt.internal.core.model.DeltaProcessor.processResourceDelta(DeltaProcessor.java:435)
at org.eclipse.cdt.internal.core.model.CModelManager.resourceChanged(CModelManager.java:904)
at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:291)
at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:285)
at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:149)
at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:378)
at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:1498)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:45)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
!ENTRY org.eclipse.cdt.core 4 0 2020-03-05 09:36:05.887
!STACK 0
!ENTRY org.eclipse.cdt.core 4 0 2020-03-05 09:36:05.909
!STACK 0
!ENTRY org.eclipse.cdt.core 4 0 2020-03-05 09:36:05.913
!STACK 0
!ENTRY org.eclipse.cdt.core 4 0 2020-03-05 09:36:05.930
!STACK 0
!ENTRY org.eclipse.cdt.core 4 0 2020-03-05 09:36:05.935
!STACK 0
!ENTRY org.eclipse.cdt.core 4 0 2020-03-05 09:36:05.969
!STACK 0
!ENTRY org.eclipse.cdt.core 4 0 2020-03-05 09:36:05.974
!STACK 0
!ENTRY org.eclipse.cdt.core 4 0 2020-03-05 09:36:05.996
!STACK 0
!ENTRY org.eclipse.cdt.core 4 0 2020-03-05 09:36:06.005
!STACK 0
at org
Hi there, looks like it’s a bad installation. The command lines seem to be malformed: (i.e: Program “usr/local/cuda-10.0/binnvcc” not found in PATH). Instead of usr/local/cuda-10.0/binnvcc it should be /usr/local/cuda-10.0/bin/nvcc.
Perhaps you can try reinstalling again ?
Let us know how it goes.
I followed the “Removing CUDA Tookit and Driver” instruction in the CUDA Toolkit v10.2.89 for the Ubuntu installation and verified that Nsight would not start and the references to CUDA was gone.
I tried re-installing CUDA 10.2.89 using the Ubuntu 18.04 runfile(local) download operation. I followed the instructs on the download site and have the following problem.
This was printed in the cuda-installer.log file.
[INFO]: Driver not installed.
[INFO]: Checking compiler version...
[INFO]: gcc location: /usr/bin/gcc
[INFO]: gcc version: gcc version 7.4.0 (Ubuntu 7.4.0-1ubuntu1~18.04.1)
[INFO]: Initializing menu
[INFO]: Setup complete
[INFO]: Components to install:
[INFO]: Driver
[INFO]: 440.33.01
[INFO]: Executing NVIDIA-Linux-x86_64-440.33.01.run --ui=none --no-questions --accept-license --disable-nouveau --no-cc-version-check --install-libglvnd  2>&1
[INFO]: Finished with code: 256
[ERROR]: Install of driver component failed.
[ERROR]: Install of 440.33.01 failed, quitting
Hi there, maybe this thread can help: https://devtalk.nvidia.com/default/topic/1069190/cuda-setup-and-installation/error-while-install-cuda-toolkit-10-2-on-ubuntu-18-04-3/
The solution in the post that you are referencing is almost verbatim of the procedure I documented. So this is not helpful.
This thread references the CUDA Toolkit v10.2.89 Installation procedure, which I specified. The error in the referenced thread is not the same issue that I’m having. In the referenced thread, the “Driver” is already installed but in my attempt, the driver simply says “Not Installed” with no further reasons.
Other than the “Uninstall Procedure” that’s documented in CUDA Tool v10.2.89, is their something else that needs to be done for a proper uninstall?
My log file reads “Driver Not Installed”. Is this the CUDA Driver or some other driver?
The reference thread indicates the deb(local) worked for him. Is their something wrong with the runfile(local) version?
Thank you
I believe I have an idea why I’m getting an error message in Nsight. I don’t know if this is the main reason but my Host system does not have a compatible Nvidia GPU.
Here’s what I’m trying to do… My goal is to develop applications using the Nvidia Eclipse IDE on an x86 Host but cross compile the executable for the Xavier AGX platform. I started researching cross-compile but all of the references that I found on the Nvidia website appear to be out of date and confusing.
The article I found to be the most relevant is in the link below.
https://devblogs.nvidia.com/cuda-jetson-nvidia-nsight-eclipse-edition/
This link references CUDA 8.0 but I found a post in the forum that specifies downloading the latest CUDA toolkit. As mentioned in this article, after downloading the latest CUDA kit, it links to this page in the CUDA Toolkit v10.2.89
https://docs.nvidia.com/cuda/cuda-installation-guide-linux/#ubuntu-installation
where step 1 of the procedure is the pre-installation actions.
The 1st bullet point in the Pre-Installation Actions is:
Verify the system has a CUDA-capable GPU
which I believe is causing my installation error.
I know cross compiling is possible but it is very unclear and the documentation seems to be contradict itself.
My first step that took was installing nvidia nsight using
sudo apt-get install nvidia-nsight
Is this correct and what are my next steps?
Hi there, have you tried the JetPack installer in order to get your Xavier board and development environment set up ?
https://developer.nvidia.com/embedded/jetpack
This should set you up with all the tools required to cross compile for your board.
