Hi Fabian.
I used the following document to configure step by step the Nsight Eclipse, to open a new project, and to build binaries:
https://developer.nvidia.com/drive/learn/tutorial-NsightEclipse
However, when I try to build, it doesn’t build any binaries.
Here is the output that I get (it doesn’t build any binaries):
3:59:20 PM Buildscript generation: dw_samples::build-host in /home/magna/nvidia/dw_samples/build-host
cmake -DCMAKE_BUILD_TYPE:STRING=Debug -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=ON -DCMAKE_BUILD_TYPE:STRING=Debug -G “Unix Makefiles” /home/magna/nvidia/dw_samples
– VIBRANTE_PDK = /home/magna/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-linux
– Vibrante version 5.1.0.2
– Found /home/magna/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-linux/lib-target/libEGL.so:
– - Includes: [/home/magna/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-linux/include]
– - Libraries: [/home/magna/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-linux/lib-target/libEGL.so]
– Found: /home/magna/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-linux/lib-target/libdrm.so
– Header at: /home/magna/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-linux/include
– DW_EXPERIMENTAL_FORCE_EGL set and EGL Support Enabled
– Cross Compiling for Vibrante
– Default - Building with TRT version 5.0.3.2 and cudnn version 7.3
– Building GLFW for X11 (static)
– VIBRANTE_PDK_BRANCH = 5.1.0.2
– Found vibrante lib: /home/magna/nvidia/dw_samples/3rdparty/linux-aarch64/vibrante/lib/libudev.so
– Found vibrante lib: /home/magna/nvidia/dw_samples/3rdparty/linux-aarch64/vibrante/lib/libusb-1.0.so
– Found vibrante_Xlib: /home/magna/nvidia/dw_samples/3rdparty/linux-aarch64/vibrante_Xlibs/lib/libXcursor.so
– Driveworks Samples install dir: /home/magna/nvidia/dw_samples/install
– Found Driveworks
– Configuring done
– Generating done
– Build files have been written to: /home/magna/nvidia/dw_samples
