I am getting this error in the title. I am following this example https://devblogs.nvidia.com/cuda-jetson-nvidia-nsight-eclipse-edition/
Do I have to install an earlier version of gcc?
May I know which JetPack version do you use first?
Suppose you can launch Nsight directly after the sdkmanager installation.
I was using the wrong Nsight version.
I was using version 9. Version 10 works.
Thanks. Good to know this.
I was having trouble opening Nsight 10 that came with the CUDA toolkit. So I installed Nsight 9 and was using that. I am able to use Nsight 10 now, and that error is not a problem. Thanks.
